Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
False printer detection
I don't use the Brother 240 anymore, I have uninstalled it, but I keep getting the message "found new hardware, printer".
My op sys is XP.
Thanks
Installation
uninstall the printer completely and then try installing it back
Aug 23, 2008 | Canon PIXMA MP470 All-in-One Printer
I keep getting a scanner failure error message. I have uninstalled & reinstalled the drivers.
Hardware failure - the scanner reading head (the one that detects the image) has failed.
This is terminal since it will be cheaper just to buy a new one than to replace the head.
May 16, 2011 | HP Office Equipment & Supplies
Ain order to get rid of an error message I had to install three new color cartridges, even though they had visible ink levels in them. The unit will copy now, but will only allow me to scan to e-mail!!...
Have you tried rocking the cartridges from front to back to evenly distrbute the toner? If you tip the printer to clear a papre jam, the toner in the cartridge will often clump and cause a false error message.
The scan only to email problem is probably related to printer configuration. Look here for guidance: http://www.brother-usa.com/modeldocuments/consumer/users%20manual/um_mfc_5440cn_5840cn_en_108.pdf
There is an uninstall utility on the brother site. Windows usually will not properly uninstall the brother drivers. Use the uninstall utility, reinstall the printer, and see if the Win 7 problem is gone.
Feb 27, 2011 | Brother MFC-5840CN All-In-One InkJet...
Brother printer will not print because I keep getting manual feed
thios means the job you sent to print was detected as a differant size then the paper in the tray.
you would have to put a page in the front slot of the machine until it clears out this job
Mar 24, 2010 | Brother HL-4050CDN Printer
Are brother hl 2040 printers compatible with windows 7 - 32bit operating system
I find that windows 7 prefers to download it's own drivers.
If you installed any drivers, uninstall them, unplug the USB of the printer and reboot.
When you get back into windows plug back in the USB cable to your printer
You will see "found new hardware" This time you want to let Windows to go online and download the drivers for you.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Thank you
Mar 13, 2010 | Brother HL-2040 Laser Printer
When I replace the cyan cartridge with a new one I keep getting the message"No Cartridge"
hi!!! in that kind of problem maybe the sensor of the cartridge was damage thats why the sensor cannot detect when you install the cartridge. Try another cartridge or maybe try the to re-install old one if the printer detect the old cartridge that means the new cartridge was defective. Thanks
May 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother HL5250DN red status light, no printing even with driver reinstall
I had this exact same problem
I just had mine repaired at an authorized Brother service center...It was the "Main PCB Assy". or the "main board. Total cost with tax....$100.
I'll try another brand before I buy Brother again.
Oct 27, 2008 | Brother HL 5250DN Laser Printer
Install printer via internet
If you cant install from CD, Plug in your printer to the laptop, It should detect new hardware, If it's drivers your looking for it's easy enough to go to Device Manager and press update driver, If that doesnt workgo to the brother website and download drivers from there.
Brother should also have an online installer. Check out their website :)
Aug 26, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
