NO SOUND SPEAKER - Computers & Internet
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 83 Answers
Unistall the sound driver from device manager and Reinstall it by restarting the Notebook /computer
Posted on Oct 12, 2009
  • 46 Answers
Please check if your sound device drivers are installed or not.
Posted on Sep 28, 2009
Right speaker has no sound
Check R cable from source to speaker, No power used in L or R cable, they only receive the signal from SOURCE to speaker, You onlly have 2 ends of each cable, 1 to source other end to speaker
Mar 13, 2015 | JBL Pebbles 2.0 Speaker System 2-Piece
My volume buttons on my compaq presario c769us are not working , is there a combination for the volume buttons
From the manual:
http://h10032.www1.hp.com/ctg/Manual/c01114193.pdf
Hotkeys are combinations of the fn key (lower left of keyboard) and one of the function keys:
Mute and restore speaker sound. fn+home
Increase speaker sound. fn+pg up
Decrease speaker sound. fn+pg dn
To use a hotkey command on the computer keyboard, follow either of these steps:
Briefly press the fn key, and then briefly press the second key of the hotkey command.
- or -
Press and hold down the fn key, briefly press the second key of the hotkey command, and then
release both keys at the same time.
Muting speaker sound (fn+home)
Press fn+home to mute speaker sound. Press the hotkey again to restore speaker sound.
Increasing speaker sound (fn+pg up)
Press fn+pg up to increase speaker sound. Hold down the hotkey to increase speaker sound incrementally.
Decreasing speaker sound (fn+pg dn)
Press fn+pg dn to decrease speaker sound. Hold down the hotkey to decrease speaker sound incrementally.
More manuals for this model:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=3678775&
Jan 25, 2013 | HP Compaq Presario C769US Notebook
Speaker buttons don't function correctly
The Speaker A and Speaker B buttons select pairs of speakers. If you have connected a pair of speakers to the "SPEAKER A" terminals on the rear of your Onkyo receiver, you will hear stereo sound when the Speaker A button is pressed on the front panel. If, for some reason, you wanted to connect a second set of speakers in the same room or perhaps another room you would connect those speakers to the "SPEAKER B" terminals on the rear. Pressing both buttons on the front panel would send sound output to both sets of speakers
Jan 17, 2013 | Onkyo Quartz Synthesized Tuner Amplifier...
No sound
Hello
If picture is OK and there is no sound output from your tv, means either its speaker or the Sound output Ic is not working. The case of speaker fault can be easly detected without opening the TV. You just place your ear very near to the speaker side and switch on the TV by AC mains [not with remote control]. You may hear a "thumb" SOUND OR A "HUM" sound from it. If any one is there the internal speaker is working fine. The fault lies in audio output Ic stage. If there is no sound said above, speaker can be suspected. Befor confirming that the speaker is faulty, if your TV has an earphone or headphone jack in front, insert the earphone or headphone socket into it, and check whether there is any sound heard from it. If there is sound from headphone, means that the headphone socket is faulty, it does not bypass the sound to the speaker. When head phone is connected, the connection to the speaker will automatically cut of. When it is pulled out from the socket, the speaker connection will resume. If the changeover switch inside the earphone socket also show this kind of trouble. If the speaker inside is found faulty, unscrew it out of place after opening the TV, go for a same type and number, impedence and shape.
If there comes the above said "HUM" sound from the speaker, surely the Sound Output Ic is faulty. Replacing it will solve the probelm. Before replacing it, check it soldering points for any loose contact. It is best to resolder all suspected point is sound section before replacing the ic.
Note: In modern TVs there will be any trace of sound, without a video signal. Without video, sound is muted. ok.
Nov 07, 2010 | Toshiba CF19H25 TV
The horn works but not the 15" you can hear the
Hi, problem can be solved. The problem can be from two places,
From the speaker and,
also the cross over.
I might be from the speaker if the wire connected from the cross over inside the speaker has cut or has removed.,it can make the speaker (15),not to make any sound..
The cross over might also be the fault too. The cross over is located inside the speaker and it makes the 15 speaker makes sound..
'There are capacitors on the crossover that control and makes the 15 speaker make sound.If the capacitor gets damaged it can make the sound stop. Also you will need to check the fuse inside the speaker, you will find the fuse on the cross over of the speaker.
Troubleshoot the above, and problem solved,...
Hope that helped..
Thanks fro using fixya.....
Oct 29, 2010 | JBL EON 15-G2 Powered DJ Speaker With EQ...
The speaker of my computer have no sound when i bought it it have sound and when i change the speaker to head phone the head phone have sound and then when i plug the speaker and unplug the head phone the...
If you can get sound from the headphone from the same audio output and not getting any sound from the speaker, it is obvious that the speaker is not working
Jul 18, 2010 | Computers & Internet
5130c-2 ear sound
Hi you should change the speaker because it is faulty thats why you can't hear any sound.
Jul 12, 2010 | Nokia 5130 Cellular Phone
Speaker ok but i cannot hear sound from speaker
speaker ok samsung e 1081 problam same
Sep 30, 2009 | Nokia 1100
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Computers & Internet Logo
David Payne
David Payne
