Question about Cuisinart DCC-2000
ON/Off switch not working
For the last 3 weeks i have to constantly play with the switch to get it to turn on tonight went to use it spent the last 30 mins and nothing I think its officially broke. Im very upset it's only 1.5 old. too much money for such little tie
    President:
  • 3,433 Answers
What does the on/off switch control? 30 min is a long time to mess with a switch. Ok, I see the picture on the left. If you dare attempt to replace the switch you can more than likely find one at radio shack. Make sure you unplug the unit before openining it up..
Posted on Sep 28, 2009
Lincoln Impinger 2 Double Conveyor oven temperature unstable
It looks like a thermostat problem, but if the thermostat had already been replaced, remain to check the valve and the pressure switches.
When the valve is defective, gas will turn off and not restart, Check and eventually replace the pressure switch , but it can also be a control problem.
Let see if I can find support and repair in your area.
Oct 08, 2008 | Lincoln Conveyor Oven - 1133-000-A
I brought my ps3 home from my office and it was working fine there but will only turn on and nothing will display on the tv. I use hdmi on the tv in the office and was trying to use the 3 prong at the...
You must go back to the origional place you used the HDMI last, and do all the setting up & hook up again, to get a picture, THEN set it to component, or AV, and THEN turn off shut down, Now it will work at the other place OK.
Feb 23, 2010 | Sony Playstation 3 (PS3) Console
Have a Crate V50-112.Have had it for 1 year. Replaced tubes 2 weeks ago, turned amp on tonight, started to play, amp went dead. Checked fuses, they're good. Any ideas?
Check for bad tube... it HAPPENS that brand new ones fail... USUALLY if they last 50 hours, they will last for the expected life. The bad tube would likely NOT be the main power tubes, as the amp would still run on one cylinder...
Feb 02, 2010 | Crate Music
Ice not working now fridge warming up
may be a timer(timer can be anywhere,inside or out by compressor or behind toe kick it has 5-6 wires and a 1/4 inch hole with a flat screw head in it. use flat screw driver,turn it until it clicks...it will turn one way only...that should put in defrost and in 30 minutes or less the timer should turn compressor back on if not replace timer...when it is in defrost se if element works if not ...check element with meter...also termination switch...open above 32degreeFclose under 32
Aug 25, 2009 | Refrigerators
Turtle Beach Ear Force X1 Headset with very low sound output
Try playing the X1 from an iPod or MP3 player. If it works better on that, then the problem is probably the Stereo Splitter Cable connecting the X1 to your Xbox audio outputs. If the X1 sounds bad from the MP3 player too, then you should tell Turtle Beach tech support about this. support@turtlebeach.com.
Apr 09, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Coffee Makers & Espresso Machines Logo
815 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
