Question about Intel D102GGC2 Motherboard
NO DISPLAY I HAVE ONE MAINBOARD HAVING NO DISPLAY
    President:
  • 4,402 Answers
Can you put in a video card and try it see if it gives you error message?
Posted on Dec 18, 2007
The display screen on M475 dw is blank but peripheral lights on. Computer doesn't find printer. What to do?
well, this issues it seems formatter issues..and sometimes its causes on relay between primary / secondary having crudded contack or unable to switch to secondary section under on mainboard.
note : scanner function,formatter or usb interface and high voltage ground were connected on secondary circuit.
Jul 08, 2014 | HP LaserJet Pro 400 M401DN Laser Printer
Temp display is flashing "ee" but seems to be cold inside.
EE mean that the cable between the mainboard and the display have a problem. I think it doesn't affect the coldness of the unit.
There are an explanation manual behind the back bottom panel.
In my case soon after having reset this error, the cable melted and took in fire.
How to check:
There is a black panel under the two drawer with 2 screws (left/right). The board is behind, the cable which melted in my case was a grey one connected to a black one.
Aug 28, 2013 | Haier Dd400rs Refrigerator
On the temp display it is flashing EE. Any thoughts on what I should do?
unplug unit wait a few secounds then plug it back in and try it may reset.
Aug 06, 2013 | Haier Dd400rs Refrigerator
My dell pc laptop is not coming on
If power is not coming in the notebook try following:
1.Remove the battery and check on ac mode if coming battery faulty.
2.If then also no response means mainboard is having the issue.
If the power is there and no display:
1.Refix the RAM once and RAM chamber willl be on the backside.
2.If the lights are not responding then the issue is with mainboard.
Thanks
Dec 10, 2009 | Dell Computers & Internet
Lineings on the screen
This is most likely a sign of a failing mainboard or a video adapter. On some cases it may be a issue with just the display.
If the lines dissapear when the display is moved open or closed the issue could be the cables between the lcd display and the mainboard.
Unless its a cable problem this repair won't be cheap. I'd recommend you get a professional to look at the laptop to confirm the fault, if you are in warranty send it to acer repair.
Sep 11, 2009 | Acer Aspire 4720 Notebook
MY COMPUTER SCREEN LOOKS LIKE IT WENT THROUGH A SHREADER
Sounds like either a driver problem or a defective graphics chip. Is this a new or older notebook? Determine your graphics manufacturer and try downloading their latest driver for your video graphics software or hardware driver.
If it is a defective chip, you will need to contact the notebook manufacturer to get repair service. If the notebook is less than a year old you should be able to get the service for free. If you have an extended warranty then it should cover your situation.
Hope this helps.
Sep 04, 2009 | Compaq Presario Notebook
Hp nx8220 display problems
I think I came across to a similar situation, try resetting the RAM by pulling it out and inset it back properly. If it does not work, try replacing the RAM from a working Laptop and see. Normally after disassembling the laptop assembling it again the RAM does not sits down properly causing the no display or a faulty RAM either.
Aug 10, 2009 | Computers & Internet
If i charge my phne contact service is display
you need to replaced the phone mainboard or try having the phone reflash
Jun 01, 2009 | Nokia 6610i Cellular Phone
The motherboard could not display
Please try these......
1. If it happens after appearing the windows logo, Your RAM is working fine. Normally it happens when the HDD fails(Bad Sector or Faulty Head) or the MBR(Master Boot Record) got corrupted.
2.Check whether any noice is coming from HDD on Booting.If YES...then the problem with your HDD
3.Try with a fresh or working HDD
Mar 02, 2009 | Computers & Internet
No display and no connectivity to the computer
Replace all electrolytic capacitors in power supply section on mainboard. caused by poor quality lower voltage caps being used in powersupply. Problem will reoccur every 2 to 3 years if 105oC caps are not used. If mainboard is replaced with new mainboard problem will reoccur within same timeframe. Fix old mainboard using higher voltage and higher temp caps and problem will be gone for good.
Dec 29, 2008 | Samsung ML-2551N Laser Printer
Intel D102GGC2 Motherboard Logo
26 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
