Question about Toshiba Satellite A105 Notebook
My laptop gets so hot it blows hot air alot- whats wrong???
  • Toshiba Master
  • 5,660 Answers
On the bottom of your laptop is an Air Intake Duct. There is a small fan inside the laptop that draws air in through this duct, and distributes it to a Cooling Tube. The Cooling Tube is directly connected to a Heatsink, and the Heatsink is directly connected to the Processor.
As a processor works it creates heat. Electrons moving across tiny circuitry that is measured in Nanometers, makes heat. (Caused by resistance. Resistance creates heat)
The Heatsink is a block of metal with fins protruding. Heat from the processor is absorbed into the fins, and air blowing over the fins transfers heat out of the laptop.
Since the Air Intake Duct is located on the bottom of the laptop, this is a very good(?) area to draw up foreign debris. Anything other than air, is foreign debris. Dirt, Dust, Hair, Food Crumbs, Lint, and other debris is drawn inside the cooling components of the laptop.
The fan blades, center fan hub, and the outside structure around the fan, collects this debris. Eventually the debris adds up, makes the path of the air smaller, and the cooling capacity is dropped tremendously.
More heat is collected inside, and cannot be transferred outside the laptop. The air becomes hotter.
Solution is to clean the Air Intake Duct, with a can of compressed air for computers. This is done with ALL electrical sources for the laptop removed! AC adapter, (Charger), and Battery. The laptop is rested on it's side on a table, held with one hand, or a helper holds it. I rest them on a lint free soft cloth, so that the laptop does not become scratched, nor the tabletop.
Attach the plastic 'straw' that comes with the can of air, to it's nozzle. Use Short Bursts when cleaning the Air Intake Duct!! A Short Burst is squeezing the trigger in all the way, then letting go.
Reason for short bursts is the small fan inside the laptop. The fan is only designed to spin so fast. Spinning it faster than it was designed for, may lead to premature failure of the fan's bearings.
Sometimes the Air Intake Duct, and fan components are very clogged, and a can of compressed air for computers simply won't do it. The laptop needs to be taken to a competent computer repair shop, where the tech will open the laptop. The foreign debris is then removed with tools for the job, in addition to using a can of compressed air.
Also the laptop should be kept on a hard flat surface. It is very easy to accidentally block off the Air Intake Duct. If you put the laptop on your lap, your clothes may block it off. Same thing with having it on a bed, or couch, or directly on a carpet floor.
Using a laptop cooling pad helps also. There are some relatively cheap ones available. A $20 to $25 laptop cooling pad may be all you need. You can look these up online.
The following is just for Information purposes, and is designed in mind, to show you the internals of your laptop. Just so you can see the hardware components that I have been referring to. It is NOT a suggestion to open the laptop yourself!
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
(At the bottom of the main page you will see Page 1::Page 2::Page 3. The main page is Page 1. To go to Page 2 and 3, just click on them. You can click on each photo to enlarge them)
Posted on Sep 28, 2009
    President:
  • 942 Answers
Hot spot, fan always runs? Many laptop brands and models have characteristic hot spots, like a particular corner of the keyboard or over the battery compartment. Before proceeding with the more invasive cleaning techniques that involve opening up the laptop (and potentially breaking something), spend some time searching the web for user feedback on your make and model. The bothersome hot spot on your laptop that none of your friends or colleagues have ever hear of may be a characteristic issue with your particular model and not worth a major panic.Similarly, if the fan always runs, or almost always runs, it may be a characteristic of the particular model that it simply gets hot in normal operation, or the fan control software might be poorly conceived. As long as the laptop isn’t overheating, I’d probably learn to live with a fan that seems to run too much if it’s typical for the model, and only get worried when I don’t hear it anymore.
On the other hand, if the settings are all on the defaults, the fan never comes on, and the system is overheating, it’s either a fan failure or a problem with the control circuit. The fan itself is a replaceable DC fan that usually can be replaced without removing the heatsink (if it’s mounted directly on the CPU or graphics processor). One simple test for notebook fans is to blow on them. If the fan doesn’t spin, either the bearing has failed or something is melted or jammed, because the motors are tiny. Testing the control circuit is an open-unit bench job that I don’t recommend unless you are an experienced technician. It’s easier to just replace the fan with a known good unit, and if it still doesn’t work the problem is in the controller or the power supply to the fan.
Regards
PCmania
  • 72 Answers
Hi!
Actually your laptop configuration donot support the heavy programmes you have installed in it. This results in lower processing speed and more use of fan and this blows the hot air out very soon to complete the going processes without any problem.
So you please turn to a higher configuration laptop with latest specifications that supports your programme.
Thanks
With regards
Lakshay
  • 153 Answers
If the system hangs frequently after long time use .....you internal fan needs replacement
if it notmally working ....and no trouble is there....then use your laptop on the flat desk
Do not use it on any cloth type substance because it obstructs ventelation......
regards
I have a 2006, Skoda Octavia, TDI 1.9 elegance 100,000 Kms on the clock.I'm having trouble with cold air coming out of my vents when it should be hot air. My mechanic can't find anything wrong. Help
check the heater core hoses after the engine is hot both should be hot but if i am right one will be hot the other cold and if so heater core is plugged and is an easy fix with some compressed air and CLR. you will have to remove the hoses to the core and blow air into the cold side to get junk out of it then put CLR in the core for a bit to clean it then blow out again and do not use alot of air just low pressure then rinse out with water and hook back up hoses and run engine and top back up fluids, I have have to do this 20 times to diff vehicles in the past few months
Mar 20, 2016 | Skoda Cars & Trucks
How come I get hot air from my cars vents when I turn the air conditioner on.
If the hot air only comes from the defrost it is probably the Control Head. Can be rebuilt for 100 or replaced quick for $235. The Blend door is expensive because of the labor to get to it. Alot of places will diagnose your problems for $25 to $85. They can check the vacum pressure from under the dash and let you know what is wrong. https://www.youtube.com/watch?v=hAqE-oYnvlQ
Jun 23, 2014 | 2003 Mercury Grand Marquis
Hey, i had my laptop for like 10 mounths now, i use to watch movies and use it for some computer games, after like 5 mounths my fan start to work alot, and now its working alot and geting to a point when...
your laptop is under 1 year warrenty. So, take it to the store you purchage it, they will either repair it or replace it. Alternative, A laptop cooler can be found now a days in very cheap.
Jul 02, 2011 | ASUS Computers & Internet
Fan running alot and laptop gets pretty hot
try using a can of compressed air to blow out any dust build up. also unscrew the panel(s) on the bottom and dust those out too but don't physically touch the parts inside. Also do not tip the can of compressed air upside down or anywhere close to a 60 degree angle which would cause foam to come out of the can.
Apr 26, 2010 | Gateway 450SX4 Notebook
Lg s1 pro express dual is getting very hot
Put your hand by the exhaust, if you cant feel air at all, the fan might need replaced, if you barely feel anything, it may just be clogged, try blowing it out with compressed air.
Oct 08, 2009 | LG Computers & Internet
Air Condition problem
it sounds like its something wrong with your condensor or possibly water pump. Im not the best person on this yet, I am currently studying for a HVAC license, but when the pressures betw. hot and cold flows are off, u will see stuff like that. I would wait for an expert, but you can learn alot of stuff by just researching how car systems work. I know I did. well....and still am.
May 11, 2009 | 1995 Nissan Maxima
96 Jeep Grand Cherokee will not blow out hot air
It's possible you are not getting enough coolant flow to your heater core. Try pulling the hoses off the core, blowing it out with air compressor, fill with water and blow out again. Try this about five times and see what happens. Alot of times these cores will plug up or have restricted flow. They will blow warm at low speed but it won't flow enough hot coolant through to stay hot on high blower speed.
Feb 09, 2009 | 1997 Jeep Grand Cherokee
Toshiba Satellite A105 Notebook Logo
3,701 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
