Question about Dishwashers
I have a whirlpool dishwasher thats a quiet partner 2. the cancel drain light keeps blinking and nothing else is happening. i try to unlock it and then the normal light starts blinking also and still nothing happens. i called a local repair shop and they said i need to change the control board so i did and its still does the same thing. can you give me an idea of where i need to start to fix my problem?
  • nerkdawg Sep 28, 2009
    when you cut the pwoer back on to the dw nothing happens except for the lights blinking. no noise or anything. just the lights.
  • 142 Answers
Can you here the pump running or check to make sure there is no water in the base...
Posted on Sep 28, 2009
  • quady Sep 28, 2009
    The first thing to to run on any programe is the drain pump so if there is no noiseit could be the drain pump. Also check door switch and wiring harness in door good luck....
SOURCE: Whirlpool Quiet Partner II
Thank you so much!!! heated dry & hi temp buttons worked!!
Posted on Feb 13, 2008
  • 126 Answers
SOURCE: Whirlpool dishwasher Quiet Partner II:
shut down the circuit breaker that controls the dishwasher for 20 - 30 minutes then turn it back on.
Posted on Dec 29, 2008
  • 18 Answers
SOURCE: whirlpool gold quiet partner 3 wont drain.
The new garbage disposer comes with a plastic cap in the drain port. Disassemble the drain pipe assembly and remove the cap/plug.
Posted on Jan 13, 2009
jsrock516
  • 5911 Answers
SOURCE: clean light is flashing
This can be a common issue with some Whirlpool manufactured dishwashers. This information may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now, keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Posted on Nov 02, 2009
Testimonial: "Worked perfectly! Thank you."
SOURCE: whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Posted on Dec 29, 2009
My quiet partner 111 whirlpool dishwasher is flashing clean
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
The "clean" button is flashing & none of the other cycles work.
heated dry and high temp wash
toggle till all the lights light up
then hit cancel
you should be able to turn dishwasher back on
you probably have a bad heater
is it flashing 7 times
take kick panel off and look to the rear of the dishwasher
is anything burned
if the clean light keeps blinking replace your heater
Feb 09, 2010 | Dishwashers
Whirlpool quiet partner III. Clean light keeps flashing clean.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
I have a whirlpool Quiet Partner I. HELP Drain light flashing
This may or may not help in your situation, but the following link explains how you can clear the blinking clean light problem:
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
If you have any questions, please let me know. I hope this fixes your problem.
Jul 11, 2009 | Whirlpool DU1055XTS Built-in Dishwasher
Quiet partner IV will not start. green light keeps blinking. pushed button, nothing happens.
Hold Air Dry button down for 4 seconds and it will unlock the other buttons. Mine was accidentally locked and therefore none of the cycle buttons would work.
Jun 21, 2009 | Whirlpool Dishwashers
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 26, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
279 people viewed this question
Top Dishwashers Experts
