Question about HP PSC 1401 All-In-One Printer
I have a HP PCS 1401 All-In-One Printer. When it starts printing the top half come out very clear working fine then as the page prints to bottom it breaks up and fades
Prints half page
Printing half a page with an Inkjet machine is not normally a computer issue. So windows 10 would not normally have any effect on the printing for a printer that has been accepted by the Windows 10 Operating System. If there was an issue in the software it would be printing gibberish or not printing at all.
Printing half a page is quite possably something stuck in the printer stopping the ink from getting to that half a page if it is printing down once side but not the other.
Printing half a page being that the top half is printed but not the bottom half (Or the other way around) it could be an air bubble in the feed line which can be cleared with a printhead clean or two.
Printing half a line rather than a full line such as the top half of each letter is clear but the bottom half of each letter is not visable is a blocked printhead. A couple of printhead cleans can also fix this.
Also check to see if the printer is not confused and actually has empty cartridges even if the printer thinks they are full. Brother printers can easily get confused about ink levels. If the cartridges are actually empty, replace them and away it should go again.
Hope that helps
Mar 09, 2016 | Brother MFC-490cw All-In-One Inkjet...
My HP printer prints half on one page and half on another how can i fix it?
Pl share printer model number for better solution.. try this# go to printer menu select default settings..check# check paper size in system..select proper size# un install existing drivers, re install once again..check# print from word or excel format..checkif no result share printer model number... for better solution...Vinay
Mar 30, 2012 | Office Equipment & Supplies
My printer only prints the top half of a page clearly. The bottom half is feint and blurry or missing altogether.
Your inks are gradually drying out. You should have them refilled or replaced. When inks begin to finish up in the cartridge, each time you print, part of ink that has settled at the bottom prints, and if the the material you are printing is sizable the bottom part will come out faint or faded out.
Good luck & God bless!
Nov 23, 2010 | HP Officejet 6310 All-In-One InkJet...
My printer is not printing all the horizontal lines
First try to copy and if copy works fine, means the hardware is fine and issue with the driver.
Do right-click on printer icon and select delete.
Once deleted, run the installation disc and click on add a device, follow onscreen instructions to complete the installation. Open printers and faxes window and then do right click on printer icon and select properties, click on print test page.
Check if it prints fine, if yes try to print from other application. I hope it will work.
May 26, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
My printer is only printing half of the page
half page? just half top page (top-bottom), or left and right. If just left half page, set page setup as actually paper wide that inserted. because, if actually paper wide is smaller than page setup, some epson printer jsut print half. before starting printing, the paper sensor measure paper wide first.
Jun 08, 2009 | Epson Stylus Photo 925 InkJet Printer
My dymo starting printing only the bottom half of my labels, do i just need a new ink cartridge or is this a different problem? the bottom half seems just fine...
Take out tape cartridge, make sure tape is going THROUGH both top and bottom tape guides. Clear all.
This should work. You also may have set up for second line printing. Go through all settings and clear.
May 06, 2009 | Dymo LetraTAG Thermal Label Printer
Printing not proper
Adjust the printing properties from normal to best.
Mar 28, 2009 | HP DeskJet 3940 InkJet Photo Printer
My HP PSC 1402 won't print!
my system ever thing is ok,but once i put paper displaying a out of paper,how 2 resolve this problem
Jan 07, 2009 | HP PSC 1401 All-In-One Printer
Poor print quality - top half page okay, bottom print faded and skips top half page okay, bottom print faded and skips problem Just installed a new cartridge
check the wright cartridge model you installed and well pluged to the printer
if it is ok
try to change printer properties and fix it correct options with there tabs ( ex: paper, print quality etc)
all are well try to reinstall the printer driver
Jul 16, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1401 All-In-One Printer Logo
116 people viewed this question
Seeker5211
Seeker5211
