Question about HP Deskjet D4260 Printer
D4260Deskjet will not print. The lights flashing are the down arrow and the 1/3 light on from this. I have lost the disc and instruction book thanks Carole
I am wanting to know how to get who had called on my caller ID and how to delete them. I have lost my book. Thank you for your help.
HI there.
To view the Call History you have to do the following:
  1. On your handset, press the arrow down button (CID) to view the call history.
  2. Use the arrow up and arrow down buttons to scroll through.
If you want to delete a specific call:
  1. Locate the record you want to delete from call history.
  2. Press the DELETE key to delete. You'll hear a confirmation beep.
To delete all calls:
1. With the handset in idle (off) mode, press and hold the DELETE key to delete. The screen displays
ERASE ALL NO YES. The current choice flashes.
2. Press arrow up button until YES flashes.
3. Press SELECT. You'll hear a confirmation beep.
Hope this helps you. If you wish to download a manual, you can get it from here.
Thank you for using Fixya!
Apr 19, 2011 | Vtech ia5864 Cordless Phone
On operating my remote the garage door opens but when l try to shut the door it shuts then opens straight away the only way l can stop it is to press the remote again .There is a green light that keeps...
It sounds like the door is traveling too far, hitting the floor and then reversing to the open position. If this is the case you need to locate the 'down limit' control on the side of the motor unit and turn it a bit in the opposite direction of the arrow printed on the cover. Some tweaking may be necessary to get it just right.
It is normal for that small green light to flash randomly. It can also assist in diagnosing some problems by flashing a code. It will flash a number of times and then pause and then repeat. If this is the case, post the number of flashes.
Jul 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Panasonic DP8020E Black and White Copier error message 13
panasonic dp8020e copier / the wrench light and another light to the far left side that looks like lined paper are on and cannot print. I had some instruction but did not get them all. They start with;
press and hold the function key
original size and the #3 key
f1 self test 9 hit down arrow
f9 hit down arrow
hit down arrow to 06 hit set button r/paper code
func reset
set yes to see if paper prints, can you correct and complete the instructions for me. Thanks MShea
Jul 04, 2010 | Panasonic Office Equipment & Supplies
How do you check the memory when solid green light
svmtony --
Here are the instructions for at least printing what is in your memory, and how to delete the memory as well.
You can download the entire user manual (in PDF format) from the link below (the download is on the right-side of the page, about 1/3 of the way down the page):
Here are the instructions for retrieving the fax's from the memory:
(I found this at: http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
�� Printing a List of Documents in Memory
The machine can print a list of documents stored in memory (the memory list) showing the
transaction number (TX/RX NO.), transaction mode, recipient, number of pages, date, and
transmission time of each document. When printing or deleting documents in memory, specify a
document by its transaction number.
1 Press the FAX button, then press the Menu button.
2 Press the [ or ] button to select MEMORY REFERENCE.
3 Press the OK button two times.
The memory list is printed.
�� Printing or Deleting a Document in Memory
3 Press the OK button.
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
Jul 31, 2009 | Canon PIXMA MX310 All-In-One Printer
Xerox Phaser 8500 not printing black
Here are the directions to enable and disable Jet Substitution. This may very well help.
Some of the print head jets will not unclog for you. If that does not work then most likely the print head needs to be replaced.
o enable the Jet Substitution mode:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. If necessary, select [Print Light Stripes Test] to make a Light Stripes Test print that shows any weak or missing jet and its jet number.
  5. Press the [Up] or [Down] arrow button to select [Jet Substitution Mode], and then press the [OK] button.
  6. Press the [Up] or [Down] arrow button to select the color for the weak or missing jet, and then press the [OK] button to select the color.
  7. Press the [Up] or [Down] arrow button to select the number of the weak or missing jet (1 to 309), and then press the [OK] button to confirm the selection.
    NOTE: If necessary, press the [Up] or [Down] arrow button to select [Save Change and Select Another Jet] to substitute more jets.
  8. Press the [Up] or [Down] arrow button to select [Save Change and Exit] and then press the [OK] button to complete the procedure.
To disable the Jet Substitution mode:
  4. Press the [Up] or [Down] arrow button to select [Jet Substitution Mode], and then press the [OK] button.
  5. Press the [Up] or [Down] arrow button to select [Turn Jet Substitution Mode Off], and then press the [OK] button.
Feb 16, 2008 | Xerox Phaser 8500/DN Printer
Darken print
Read your instruction book its all in there.
We all need to learn how to do these things but sometimes its best just to sit down a read the book for 1 hour or so.
Anyway to make a document or photo print darker;
Go into Printer preferences
Effects
Check the box; Simulate illustration
Then move the contract bar to you setting you require
You have other option in the as well such as;
Vivid photo
Image optimizer
Photo Optimizer pro
Photo Noise Reduction
Jan 26, 2008 | Canon PIXMA MX310 All-In-One Printer
Light Stripe Problem
Try the jet substitution mode.
Here are the instructions.
To enable the Jet Substitution mode:
Nov 07, 2007 | Xerox Phaser 8500/DN Printer
Canon i250 printer
I need more details.  Does it act like it's printing and the paper comes out blank?  Does the paper come out at all?  Or does do nothing?
Oct 10, 2007 | Computers & Internet
Red Light on front of Filter Queen Defender
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking. It cured my problem.
Mar 06, 2007 | Filter Queen Defender Air Purifier
HP Deskjet D4260 Printer Logo
157 people viewed this question
Seeker5211
Seeker5211
