Question about Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television
I would like to know if I can connect a HDMI cable from My tv model WS-65315 to a Direct TV HD receiver?
    Genius:
  • 1,112 Answers
NO> If your TV supports and have HDMI connections and your HD receiver has an HDMI output then you should have no problem displaying Video. Just make sure you change the input signal of your television to HDMI input. After looking at the spec's of this model these are the following inputs you have. your best picture quaity would be to use componet cables instead, which can show full screen 1080i format, your television does not show at 1080p whis is what HDMI is known for.
Connectors
Rear Input Connectors S-Video x 2 - Component x 3 - Composite x 2 - DVI x 1 - RF x 2 - 1 x RS-232C - Audio (RCA) x 6
Front Input Connectors S-Video x 1 - Composite x 1 - Audio (RCA) x 1
Rear Output Connectors Composite x 1 - Audio (RCA) x 1 - RF x 1
Another good option is use to use a DVI to HMDI connector and hook it up this way. But note: you will have to use audio cables for the DVI input.
Posted on Sep 28, 2009
  • Mitsubishi Master
  • 8,617 Answers
Yes youre model is HD capable through the HDMI input
Posted on Sep 30, 2009
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
Hi, how can you connect my Mitsubishi ws-73909 to HD? Do I need some sort of an adapter? HDMI - VGA adapter , HDMI - RGB adapter, or etc...? Thanks for you help!
Are you trying to connect this tv to an HD device like a satalite receiver or a cable box. If so you will need an HDMI cable which cose between $20- $60 and your cable or satalite received must be HD ready.
Jul 21, 2011 | Mitsubishi Televison & Video
How to hook up direct tv box,samsung hd tv,pioneer vsx-820 receiver,samsung blue ray bd-c5500
If you're using HDMI cables, which I suggest you do, this is how you set it up.
From the TV, you'll connect an HDMI cable to your receiver.
Connect the blu-ray player to your receiver.
There's a small amount of setup required with the receiver, but it's self explanatory.
Mar 12, 2011 | Pioneer Televison & Video
I have directv hd but i cant find the code for my mitsubishi remote to work my direct tv
not always available for all makes and models but you  can check the mfg. website for any updates...
Jul 27, 2010 | Mitsubishi WS-65315 65" Rear Projection...
I have a yamaha receiver with HDMI outputs for direct tv, and a DVD player. How do I hook up the direct tv, HD DVD, and yamaha receiver? Where do the inputs go?
Does the Yamaha have HDMI inputs? Usually you would connect the directv and dvd player via individual HDMI cables to the Yamaha (input)and then the Yamaha (output) to your TV also via HDMI.
Dec 21, 2009 | Yamaha HTR-5640 Receiver
I have a tv model # WS-65315. I would like to know if I can hook up a Blueray player and still get HDMI quality?
No, your tv is strictly a Standard Definition one. Even it can receive a HD signal, it is downscaled internally to SD so the image would look exactly like from a low quality dvd player (that's because the internal converter is a cheap one) For best image quality use the converter from the BluRay and the Component connectors.
Nov 29, 2009 | Mitsubishi WS-65315 65" Rear Projection...
I am about to receive an LG32LF4700 Freesat/HD TV If I disconnect the SKY Box and connect the TV direct to the Dish cable will I receive Freesat HD channels. Also can I connect an extra bedroom TV into the...
Yes you can split the signal out from the back of the Freesat/HD (not the TV)to the second TV.
Look what outputs are on the Freesat box - the RF (standard cable) output should go to the 2nd TV (TV set to CH3) and the a/v cables,HDMI or DVI cable should go to the new TV - Note:To receive HD the output from the Freesat should be either HDMI,DVI or Composite output (RGB video jacks) with red White for audio. If you have HDMI this is best - it also provides audio.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Mitsubishi WS-65315 plug in HD comp shows as 480i
Greetings,
In the input assignment menu make sure that the DTV (the only 1080 input on this tv) is set to Y/Pb/Pr and see if that fixes your issue with at least the HD-DVR.
BTW- the HDMI information "1080i HD can only be selected if TV has HDMI inputs". is not correct.
Feb 25, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Hoe to set my tv to hd
You don't set your TV to HD, you connect an HD source to it via either a component input or HDMI or DVI connection. I fyour TV has its own HD tuner, then you'll need to connect a good antenna or cable system to it.
michtech
Feb 19, 2009 | Mitsubishi WS-65315 65" Rear Projection...
No Video
have you gone through the menu to assign which signals the receiver recognizes?  I had to change the source when i switched to the Dish Network HD receiver.
Aug 24, 2007 | Pioneer VSX-1016 Receiver
Mitsubishi WS-65315 65" Rear Projection HDTV-Ready Television Logo
634 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
