Question about Toshiba Satellite A100-S8111TD Notebook
Shows #1 IDE error on start - Toshiba Satellite A100-S8111TD Notebook
  • 29 Answers
This is a BIOS Fatal Error. This is not an error which comes occasionally and without a reason. Did you change anything. A CD/DVD Drive or something like it. If yes the problem is here. You must have got the Jumper on the Rom wrongly. There are 2 options MASTER and SLAVE. You must applied the Slave option which is causing it. You need to take it to Toshiba, they will reset the Drive and the Bios.
Thank you, Have a nice day.
Posted on Sep 28, 2009
Pc
start pc press F2 or Delete enter Bios, check boot priority is dvd-rw od hdd set to suit, change ide/sata cable to hdd they do burn out... make sure sata 1 hdd / or ide 1 master, for C drive. hope this helps. I/O errors can occur usually swapping order of boot can fix this...
May 30, 2013 | Acer Aspire Computers & Internet
IDE #1 Error
the hard drive is malfunctioning./ pls chesk the power connector and replug
also data cable
the hard drive controller overheating ? pls check and go to bios and detect again
Jul 17, 2017 | Toshiba Satellite 2800-S202 PC Notebook
In the boot device menu, drive 1: no ide device what does this mean?
test for secure dust free connections or replace the 40 pin ide lead from mother board to hard drive
include electrical extensions
operating system cant find ide hard drive
hope it helps
Nov 12, 2011 | Dell Dimension 3000 PC Desktop
Why my pc show IDE #0 ERROR?
this error is shown cause the hard disk ide connection is not proper or defectuous ..check the HDD to see if it is functional ..and also check it to be inserted proper..
Also ..go to BIOS settings by pressing the F2 on start ..and in there choose the "optimal factory defaults" and save the changes with F10 after ...
If any strange setting had been done in Bios and caused this error ..this will bring it back to the factory settings and will make it work ..
Dec 21, 2010 | Computers & Internet
Hi I have a Toshiba Tecra M2 laptop with Windows XP Pro SP3. My CD-RW/DVD-ROM/CD-ROM drive is not working. When I try to burn a disc, it says no recorder, or no disc in drive. Also, Windows doesn't seem to...
>> it says IDE #1 error when it boots up.
IDE #0 is your disk-drive.
IDE #1 is your CD/DVD drive.
So, take your computer to a qualified technician, to first check that the connectors (power, data) from the motherboard to the CD/DVD drive are good, and then, if necessary, to remove & replace the "dead" drive.
Oct 27, 2009 | Toshiba Tecra M2 Notebook
Toshiba satellite error code ide #0 error
IDE #0 is where your hard drive connects to your computer's motherboard. You may be able to connect your hard drive to IDE#1 or you will have to have your motherboard replaced.
Jun 28, 2009 | Toshiba P000392200 - Satellite A40, A45...
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to conti
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
GOT I/O ERROR AND DRIVE WILL NOT READ DISK?
The Windows error "I/O Device Error" means there is an error in the computer's ability to read data when you try to install a program or to copy data from your CD or DVD drive. This issue is likely to occur when Windows tries to use a transfer mode that your CD drive cannot use or does not recognize. To resolve this issue, you will need to change the transfer mode in your IDE channel properties.
Steps To Change IDE Properties if (!window.netshel_ord) { netshel_ord=Math.random()*10000000000000000; } if (!window.netshel_tile) { netshel_tile=1; } document.write(''); netshel_tile++; window.google_render_ad();
  1. Click the Start button
  2. Right click My Computer
  3. Select Manage from the resulting menu
  4. In the Computer Management window, select Device Manager
  5. In the right pane, click to expand IDE ATA/ATAPI controllers
  6. Identify your CD/DVD drive in the expanded menu and right click the appropriate drive
  7. Select Properties
  8. In the Properties windows, click the Advanced Settings tab
  9. In the Transfer Mode box that represents your CD/DVD drive (typically Device 1); open the dropdown menu and select PIO Only
  10. Click ok and exit all windows
If this does not resolve your issue, then you will need to go back using the above procedure and change the Device 1 in step #9 back to "DMA if available". Then, change Device 0 to "PIO Only" in the Transfer Mode box.
For reference, the Device 0 is the Primary IDE Channel and the Device 1 is the secondary IDE Channel.
After you change your settings, make sure you restart your system so that the computer recognizes the changes you have made. After you reboot, check the settings to make sure they are in effect. If they are, your device should now work properly.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Oct 08, 2008 | Panasonic Televison & Video
Drive is not accessible. I/O Device Error
Method 1: Change the transfer mode for your CD drive in IDE Channel Properties
1. Click Start, right-click My Computer, and then click Manage.
2. Under Computer Management (Local), click Device Manager.
3. On the right side, expand IDE ATA/ATAPI controllers.
4. Right-click the channel where your CD drive is connected, and then click Properties. Typically, this channel is Secondary IDE Channel.
5. On the Advanced Settings tab, in the Transfer Mode box for the device that represents your CD drive, click PIO Only. Typically, this device is Device 0. Then, click OK.
If the issue is not resolved after you change the transfer mode for the secondary IDE channel device 0, your CD drive may not be located there. Use the same procedure to change the transfer mode back to DMA if available. Then, repeat these steps to change the transfer mode for IDE devices in the following order until the issue is resolved:
• Primary IDE channel, device 1
• Secondary IDE channel, device 1
Note Primary IDE channel, device 0 is connected to your boot disk. This is the hard disk that typically contains your operating system.
OR
Make sure that all cables are connected correctly
If you have another cable, try to use it. For USB devices, try to use another USB port. If it is internal dirve is there then Reseat it that means remove it and reinstal that
Then Set the BIOS as Default for that restart the system and before windows screen it gives the instructions how to boot in setup once you are in setup, on the bottom it says press F9 or F10 to set as default; different BIOS have different options so do the as the on screen instructons says.
OR
Try to access the media or device on another computer; try it on your friend or family computer
if it is not working contact your H/W Vendor
Aug 14, 2008 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Toshiba Satellite A100-S8111TD Notebook Logo
134 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
