Question about Quad Cycling
Hi there ,i purchaced a 110cc chineese import quad bike 4 months ago. the thing is i cant get a spark. ive bought new plug n tried that to no avail .?? any tips plzzz
Try checking the ignition coil, or the CDI.
Posted on Oct 13, 2009
3days ago I bought a110cc auto quad. It's sat for over a year, I have cleaned carburetor,has new spark plug fuelfilter &battery,unstuck the clutchandbrakes.runs, is sluggish only ?ofpower.whatsmissing
Hi Jesse, and the usual suspects are:
1. Idle speed improperly adjusted.
2. Inlet system air leak.
3. Damaged or restricted fuel tank venting system.
4. Dirty or damaged air cleaner element.
5. Accelerator pump inoperative.
6. Vacuum piston assembly malfunction.
7. Enrichner valve not seated or leaking.
8. Restricted fuel supply tract.
9. Plugged bowl vent.
10. Loose or plugged fuel and air jets or passages.
11. Improper fuel level.
12. Worn or damaged needle or needle jet.
13. Loose or plugged main jets or passages.
For more information about your issue please visit the websites below. Good luck and have a nice day.
http://canadattatv.com/wpcontent/media/book/110cc%20&%20125cc%20Service%20Manual.pdf
Sep 30, 2015 | Motorcycles
Spark plug gap for lonchi 110cc quad
Hi usually it is .7 bet would be a saw blade to guage the gap. that is usually the best size for a good spark
Feb 26, 2015 | ITP T-9 Pro Front Wheel-10x5 4/110 Silver...
Weak fire on pocket bike
Hi, I do a lot with these bikes, I think if you are getting a weak spark there is a couple things to check. First, do you understand how it builds the power to create the spark? The magnet in the flywheel has to be very close to the magnito or coil, if the gap is too much it will cause a weak spark, if the magnet is weak, weak spark, if the coil is shorting internally, weak spark. If the plug wire is damaged, weak spark. I hope this helps you.
Jan 25, 2015 | Quad 47 cc / 49 cc Pocket Mini Bike...
Only running on rear cylinder
You are Not getting spark to ur front cylinder. Swap your spark plug, if not then replace your front plug wire. if this is still not the problem ad you are sure the coil is good then look into the wire that gives the coil signal to fire
Apr 22, 2014 | 1985 Honda VT 500 C Shadow
Modle not listed Honda Vision nfme 50 I have had My honda Vision 1986 model for around 18 month. It flew its last mot around 12 month ago. However About 4 month ago returning from work on my scooter...
Its either not getting fuel, poss blocked mainjet, or float needle valve, do you have a constant flow of fuel from the tank, is the bike smoking exsessivly, sounding quieter than it used to do? Maybe the exhaust has become blocked, this was a common factor on this bike, remove exhaust look up exhaust port towards piston, with the piston at the top clean the port with a sharp object scrapeing away all the unburned carbon, start bike up without exhaust and check how it runs,
Aug 29, 2011 | Honda Fusion Motorcycles
How to make my quad bike faster it is a conti 110cc and like new got it from a frend that did not ride it. The quad is starting and goes forward when on a flat road or down hill but when driving it up the...
Hello. It sounds like your carburator is gummed up. Go to any auto parts store and get a bottle of a product called seafoam. This is a fuel additive. Just follow the directions on the bottle and add the proper amount to the fuel tank. Then run your bike and as you go you will notice the engine running smoother and the bike going faster. Also be sure the spark plug is new and the air filter too! Regards, Joe
Dec 23, 2009 | kawasaki Quad Bikes
I have no spark on a ducar 110cc quad
test all connections,for strength by bending them
Sep 22, 2009 | Quad 47 cc / 49 cc Pocket Mini Bike...
We bought a brand new Dirt bike, 110cc SSR and it will not start. I dont think we are getting a spark.
check the spark plug , and the ignition system for loose wires then connect , don't forget the battery if there is no current then charge.
Jul 09, 2009 | Pit SSR 110CC Pro Beginner Bike
Cycling Logo
331 people viewed this question
Top Quad Cycling Experts
shaun taylor
Charles T Nevin
Charles T Nevin
Are you a Quad Cycling Expert? Answer questions, earn points and help others
