Question about iLO 2600 Television
Ilo-32HD TV will not come out of standby mode or power on.
The red light comes on but will not come out of standby mode. I have tried both the remote and tv power buttons plus unplugging it and waiting a long while before trying to power on again. Red light stays on but nothing else happens.
SOURCE: ilo 32hd tv
yes you can turn on the power botton . it will send the tv to standby. then just press the far left botton to turn on the set
Posted on Sep 02, 2007
SOURCE: TV WONT TURN ON
I have the same issue, the tv does not turn on
Posted on Nov 24, 2007
  • 4 Answers
SOURCE: won't turn on. unplugged, waited, tried again,
make sure u cycle main power switch before u unplug then unplug wait 30 seconds and repeat one more time
Posted on Jan 24, 2010
SOURCE: my ilo tv seem like
Icould use s fix for this too tv use to last more than 3 years no luck for mr
Loretta
Posted on Nov 22, 2010
SOURCE: MY ILO LCT27HA36 TV won't come on, it just stays in standby mode/
Just FYI, I have fixed 3 of them and on all 3 of them it was the capacitors on the power board. The capacitors I changed on all 3 I got at mouser.com. They were: (3)-1000uf 16v PT#667-EEU-FC1C102, (2)-470uf 35v PT#667-EEU-FC1V471, (2)-1000uf 35v PT#667-EEU-FC1V102, and (2)-220uf 25v PT#667-ECA-1EHG221 the last two are located under a heat sink that you have to remove to replace them. The cost was around $15.00 with shipping for them. This is all I had to change on the ones I fixed but yours may not be the same i would not know without looking at it. Good luck and I hope it all works out for you all as it did for me. If it works for you feel free to contact me and say thank you at thanks@robbob.net
Posted on Oct 13, 2011
ILO-32HD Is stuck in Standby
Look for swollen caps on the power supply and replace if needed. If caps look good, then replace your main board
Jun 22, 2012 | iLO Televison & Video
Power went out no power to ILO-32hd
yes posible power supply is defective if fuse blow then could be defective fet transisters as well shorting best way is to replace complete board if it was surge from electicity.
Mar 02, 2012 | iLO 3200 32 in. LCD Television
Ilo LCT32HA32 tv wont turn on, no red standby light
It could be the power or main board that is giving issues...if your able pull the back off and look for a pin on connector marked PSON or PON...that is line that tells the power board to come out of sleeping and go to work, you should see a change in the voltage when the on button is pushed, if you do then the main is doing its work and its the main if you don't see a voltage change then chances are its the power board
Dec 14, 2017 | iLO LCT32HA36 Television
Only standby red light comes on. power button or
There is a failure on one of the circuit boards, and or the power supply itself. The main uPC, or the power supply controller is putting the main power supply in to protect mode.
You would have to send the set for factory service to resolve this issue.
Jerry G.
Oct 10, 2009 | iLO 3200 32 in. LCD Television
ILO-32HD
Normally this is a good indication of a stuck button on the set. With the set off, try working each of the control buttons. You should be able to feel teh button engage. If one feels like it does not work, that is the likely culprit and it should be replaced.
Let me know your results.
Dan
Sep 07, 2008 | Televison & Video
Ilo-32hd tv only 1 chanel
dude it just happened to mine it sucks!
Aug 16, 2008 | iLO V27DMBX Television
Ilo 26hd lcd tv
I unplugged mine over night and plugged it back in this morning but it still will not turn on. It is still in standby mode
Dec 17, 2007 | iLO 2600 Television
TV WONT TURN ON
try pressing the channel or volume buttons. They turn on the tv as well. Maybe the the remotes might cooperate with the tv.
Jul 22, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
191 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
