Saya Punya Masalah waste Ink Counter reset pada canon ip 4200,
Lampu menyala berwarna kuning, yang tampak pada layar monitor waste ink counter reset
  • Anonymous Mar 22, 2014
    lampu start menyala tapi monitor mati
Bagaimana cara mengatasi code P07 pada canon MG2170
Saya mengalami masalah di printer yang sekarang sedang saya gunakan yaitu pixma canon mg2170. Setiap kali saya nyalakan tombol power, di lampu LED nya terdapat numberic "P", "0", "7" begitu seterusnya berganti-gantian dan lampunya kedap kedip. Solusinya bagaimana?
Aug 26, 2013 | Canon Office Equipment & Supplies
Printer canon mx 366 saya. error 5B00. tidak bisa berpungsi ketika di hidupkan muncul error 5B00. sudah dilakukan reset manual tapi tak ada hasi. masuk ke menu tidak bisa. mhn petujuk untuk masalah ini....
I have best solution for reset error 5b00 Canon MX366 about waste ink absorber full :
1. Fisrt step : entering service mode, using this method (dont use other method!) press & hold "stop" button and than press "power" button, release "stop" button and still hold "power" button and than press "stop" button about 5 times ( 1, 2, 3 , 4, 5) and release "power" & "Stop" button.
2. Printer will be entering to Service Mode with indicators " Printer LCD to become full drak and CPU detecting new hardware (dont do anything).
3. Download Servicetool V 1074 for Canon IP2770, download and entering to this Sofware.
4. prepare paper on the printer and Clik "MAIN" on the Menu Servicetool V1074, if success canon MX366 printing "D=000.0
5. turn off Canon MX366 and remove power cord, wait about 60 second, reinsert power cord and turn on your printer,....... o la la la your printer was normal,..... ( ngono ae kok mumet)
6. if you have any qustion, send your email to : alfa_centrino@yahoo.co.id, thanks God bless U
May 15, 2012 | Office Equipment & Supplies
Lampu warning,lampu handbrake menyala,apa masalah
Ada dua kemungkinan yang terjadi,pertama masalah di switch handbrake,kedua check kondisi minyak rem.Pada masalah yang pertama adalah check switch,kabel dan koneksinya,apakah semua berada dalam kondisi yang baik.Anda dapat menggunakan multitester untuk mengecheck nya.Pada masalah yang kedua adalah,periksa level minyak rem,karena apabila minyak rem berada pada level tertentu (Min) akan membuat lampu handbrake menyala sebagai tanda peringatan (Warning).Mudah2an penjelasan ini dapat membantu teman2,terima kasih.
Aug 20, 2011 | 2007 Toyota Camry
Power on lensa tidak mau keluar.muncul tulisan turn the power off and on again
Error: TURN THE POWER OFF AND ON AGAIN ditampilkan pada layar LCD saat Mekanisme Lensa macet atau ketika terpengaruh oleh kerusakan apapun. Jika memutar power on dan off lagi tidak menyelesaikan pesan kesalahan, coba lakukan reset kekuasaan dan Inisialisasi pilihan.
Melakukan reset tenaga manual
Matikan kamera.
Keluarkan baterai.
Tekan terus tombol daya selama 30 detik.
Biarkan kamera untuk tetap tanpa listrik selama 60 detik.
Masukkan kembali baterai.
Hidupkan kamera.
Untuk mengatur ulang Kamera kembali ke default pabrik, pilih Opsi Initialize dari Menu Utama Pengaturan 1 dari Kamera ke OK.This akan mengatur pengguna menentukan pengaturan kembali ke default pabrik. Gambar-gambar dan video tidak akan bisa dihapus.
Jika masalah berlanjut, mungkin diperlukan layanan.
Terima kasih telah menghubungi FixYa.
Feb 23, 2011 | Sony Cyber-shot DSC-W90 Digital Camera
Mesin fax saya merk canon FAX JX-201,,masalahnya tidak bisa untuk email keluar dan masuk,dilayar terdapat tulisan !!CHECK!! 5100... bagaimana cara untuk memperbaiki tanpa harus pergi untuk service??
saya mau bertanya.
mesin fax diakntor saya tidak bisa menerima fax yang mau masuk, ketika ada fax masuk lampu penerima fax menyala tetapi data fax yang dikirim dari pengirim tidak mau tercetak.
bagaimana solusi nya? mohon bantuan jawaban nya, pak.
terimakasih banyak sebelumnya.
Dec 06, 2010 | Canon Office Equipment & Supplies
Reset canon pixma MP 486
saya punya printer canon 486 baru berapa buala sudah minta direseter dimana saya harus dapatkan soft ware resetter nya
Jan 18, 2010 | Canon Office Equipment & Supplies
Mesin menyala tapi tidak kuat bekerja,kemudian layar touch screen mati
saya pernah mengalami hal seperti itu, biasanya masalah pada voltase listrik yang kurang dari 220Volt. Jadi mesin tidak bisa bekerja secara normal. Apabila voltase listrik normal berarti ada masalah pada power supply mesin sehingga tidak dapat mencukupi daya yang dibutuhkan seluruh komponen.
Dec 18, 2009 | Canon NP 6035 Copier
I have my canon pixma 1980 series... error says ink absorber is full and need to reset... please give me a resetter software.... thanks
Manual reset for canon pixma iP 1980 it easy and like resetting canon ip 1880.If found problem in your printer canon iP 1980 maybe this methode can be use. This reset manual be used to reset waste ink counter in canon pixma iP 1980.
Here how :
  • Turn on your printer Canon Pixma iP1980
  • now Press and hold Resume button for two (2) minutes and then release Resume button.
  • Turn off the printer and turn on again, the Printer will back to normal again.
May 02, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
339 people viewed this question
jasbo
jasbo
