Question about Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis top load model 580 error F51
The washer goes for awhile and then stops with alternate flashiing F and 51. I have to disconnect the machine from electrical power and then reattach to get the lid lock to release
  • 909 Answers
There is no reason or condition that will requir having to doing that for correct operation. That indicates the board as being defective. Just asking if your water is draining correctly? When you start cycle, after it finnishes loading the water, can you get it to drain at all. If you can, the board is the problem.
Posted on Sep 28, 2009
  • Terence Fourie
    Terence Fourie Sep 28, 2009
    There is no reason or condition that will requir having to do doing that for correct operation. That indicates the board as being defective. Just asking if your water is draining correctly? When you start cycle, after it finnishes loading the water, can you get it to drain at all. If you can, the board is the problem.
F51 error
Hello, the F51 code is a motor rotor position sensor failure. It's best to call in the warranty service as there is a bunch of tests that need to be run to determine if it's the sensor or control board. If the tech wasn't any help, contact the store for a replacement.
Thanks
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I OWN A KENMORE ELITE OASIS HE TOP LOAD WASHER AND I AM HAVING PROBLEMS WITH RUNNING A FULL CYCLE WITHOUT HAVING TO ADJUST THE LOAD A F 51 CODE APPEARS AND THE MACHINE STOPS. PLEASE TELL ME WHAT I NEED TO...
F51 MEANS BAD READING ON THE RPS SENSOR. COUPLE OF THINGS YOU NEED TO CHECK. IT'S A LITTLE COMPLCATED. IF YOU ARE A LITTLE MECHANICALLY INCLINE, I CAN WALK YOU THRU IT WITH WITH NO PROBLEM
BOYNISMO@YAHOO.COM 714-334-1998
Dec 06, 2009 | Kenmore Elite HE4 Electric Dryer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
What does a code f51 stand for on a kenmore oasis elite washer
F-51 ERROR CODE IS DEALING WITH THE SPIN CYCLE. THE CONTROL DOES NOT DETECT IT SPINNING.THE RPS SENSOR ON THE BOTTOM OF THE UNIT NEEDS TO BE TAKEN OFF AND PUT BACK ON ABOUT 10 TIMES. SOUNDS WEIRD BUT USUALLY FIXES IT. THEY DO HAVE A KIT ALSO FOR THE RPS TO BE REPLACED. UNPLUGGING FOR A FEW HOURS IS A TEMP FIX.
Jul 17, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis model 27082605 type 580 has f51 code what can i do
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer full and then stops and gives a beep while flashing F 51
On Kenmore F51 means Motor RPS Failure, the motor is not spinning or the motor sensor detects a fault.First unplug the power cord for one hour or so to check if it is a jammed sensor, and see if reset.
Dec 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
513 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
