When ever i open tally 7.2 it gets hang !!! when i click, then there is an error message ''NOT RESPONDING''!!! pl advive me how solved the problem Regards Vasu
    Problem Solver:
Just add this line to your tally.ini file:
sound= No
And it'll solve your problem immediately.
Posted on Jul 11, 2012
Whenever i open tally 7.2 it get hang showing checking balance
Posted on Nov 27, 2010
How to export in tally 7.2
This applies to Tally 7.2 and above.
1. You can export only registers and not masters
2. In any view register mode the export / import option becomes availble.
3. Click export.
4. Tally prompts you for a file name. The default name is always Tally.txt.
5. Pl rename the file to represent the ledger you are exporting else Tally will over write an existing file.
6. Tally will always save the file in the same drive / folder where Tally data resides. You cannot change this.
7. The file saved is the CSV file.
8. Open this file with Excel and map the fields.
Jan 20, 2015 | Tally Office Equipment & Supplies
I have installed Tally 9 in my laptop. The operating system is Windows 7. Now when I try ti create a Company, it gives error massage " Exiting Tally ! Error in TDL. Part:Basic Company, Insufficient...
on any pc if you get error "insufficient height to allocate".. then just set the dpi of your pc/laptop to 100%, (you can adjust dpi from display settings) and try to use tally, this might solve ur problem.
if the above doesn't solve ur problem, then go to screen resolution setting and select 800 x 600 resolution. this might solve ur problem to most extent.
if still u are facing the prob then go to display setting of windows and reduce the font size of menu, message box, active title bar, non-active title bar and etc... reduce fonts of all..
tats all
May 02, 2011 | Computers & Internet
EXITING TALLY!! Internal Error. Contact Tally
My tally 5.4 not open when to try open tally when see exiting tally! file not found. Please give the solution immediately
Apr 27, 2010 | Tally T2245 Matrix Printer
Tally Data Problem
EXITING TALLY!!
INCORRECT VERSION.
DATA OF INCORRECT VER.(10)
CAN ONLY RUN VERSION 9!
Jun 27, 2009 | Tally T2245 Matrix Printer
Tally 5.4 exiting tally error
i want to install tally 5.4 in my computer. I am using Window7. Does tally5.4 compatible with windows7? Plz give me solution for install tally5.4 in my computer with windows 7
Jun 22, 2009 | Microsoft Windows XP Professional
Tally 5.4 error
try to configure your configuration setting. change the data source where you data saved.
Exp (from program files, configuration setting) :
;; Tally eis 5.4 workstation specific parameters file
[Tally]
; Specify location of Data files
Data = D:\data tally\Tally 2\DATA
;; Specify list of companies to preload
; ** TO STOP DEFAULT LOADING set the following line to NO
Default Companies = Yes
Load = 0001
;Load = 0002
; Specify list of TDL files for user defined reports and changes
; ** TO STOP LOADING TDL FILES, set the following line to NO
User TDL = Yes
;TDL = <TDL file 1>
; Specify location of TALLY.SAV (saved configuration of Tally)
Config = c:\TALLY
; Specify Color details of local monitor
Color = Yes
a bold letter is the source of data that you must change.
Jun 22, 2009 | Computers & Internet
Tally 7.2 problem
We surrendered license for changing SERVER . But could not get the license number to the new server. But message box of the tally wrote as license activate successfully. But now we want to operate to old server. But the message box written “ surrender license and try again”. We will be very thankful if you solve our problem.
Apr 23, 2009 | Computers & Internet
Software Exception c0000005
to solve this type of problem first of all take backup of your tally data then right click on ur tally icon on desktop go to properties then click on findtargate open ur tally configuration file see the line
load comony=yes (change yes into no) save the file & exit start ur tally pres ctr+alt+r selct the company which was giving error press enter tally will ask to rewrite the company press y to yes let the finish rewrite task then start working on tally
try this this works
RAKESH RANA
98682225794
Feb 02, 2009 | Computers & Internet
Error in tally 7.2
This is vishu
Solutions to these problems needs common sense rather than tallyexpertise. Lets understand some feature and working of tally. Tallyprovides a backup and restore utility which collects all files of tallycompany into one file named tbk500.001. This way of tally backup iseasier to restore as this one file can be kept save and easily can berestored instead of all files in that folder. If any of the file getsmissing or gets corrupted tally data wouldn't work.
when data gets corrupted while working on tally and we are unable toopen the company then data can simply rewritten. Come to Companyselection menu. Press "Ctrl + Alt + R". Now select the company for re writing. 90% chance is that you problem would be get solved.
Mail me Your response.
Dec 21, 2007 | Computers & Internet
Recover tally data
Dear Sir/Madam,
I am getting the following error,
Existing TALLY file damaged File:C:/Tally/0001/Tr01298.500
Position:149760
Chars:128(done 128)
Please give me a solution to get my data and I am using Tally7.2 version...
Thanks & Regards,
S.Prasada Rao
Sep 10, 2007 | Tally T2250 Matrix Printer
Computers & Internet Logo
875 people viewed this question
David Payne
David Payne
