Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
8 hrs ago I do scanned a doc to pdf file into my flash drv Checked to confirm complete, removed flash and now its empty except the 3 default files that comes on drive....what happened to all my files?
  • 153 Answers
Check the files in the command prmt.
first find out iwhat is the pen Drive (E: or F: or G: and sonn)
go to run from start menue type "cmd" press enter
type the following step by step:-(press enter every command)
cd\
if your drive is g: etc....
G:
dir *.* /a/s/p
by this command you can see if there is any files or not ...if yes all files are hidden ....if you cannot see any files ..then it may be deleted or erased
Next step is to use Restoration software for retriving it .........(if you copy any other files old files in the pen drive will be permanentaly removed ---do try restoration and then proceed)
download it from following URL below:-
http://download.softpedia.com/dl/a7870ec5e56e2553a7089389d39b77ba/4ac06371/100019260/software/system/Restoration.zip
Posted on Sep 28, 2009
    Scholar:
  • 142 Answers
It is simply lost. do you use safety remove function? it is good thing this type of error is less, you can use any recovery soft which supports USB drives, Recovery my files, undelete or other. It will recover you lost documents.
Universal serial bus virus delete
Start ->run -> type cmd -> type attrib -r -a -s -h *.* and press enter.
What this basically does is removes the read only, archive, system and hidden file attributes on the files so that the virus or the container of virus will be shown.
Within the command prompt you will run the delete command to delete these suspicious files as the are shown up, example type del Autorun.inf or del New Folder.exe.
When you have finished doing that unplug your flash drive, update your anti-virus and scan your entire system.
Last but not least plug back your flashdrive into your computer and scan it with your anti-virus.
Viruses on flash drives are usually spread because windows has the Autorun feature set automatically run by default and this needs to be disabled.
Here is the easiest and fastest way by far to disable the autorun feature.
Download Disable_autorun.reg registry key.
Click Save to your computer ->Rigt click on file -> click run
Click Yes to confirm addition to the registry
http://www.majorgeeks.com/Kingsoft_Free_Antivirus_d6512.html
Kingsoft provide a complete and powerful security solution for personal users. Kingsoft Free Cloud Antivirus defends against viruses, spywares and malwares real-time.
Detect all type of virus and threats with multiple guards.
It include USB device protection, disk cleaner, History cleaner, process supervisor, LSP repair tools and system repair.
hope this helps
Sep 09, 2012 | Targus Acp45us1 Docking Station. Docking...
I scanned to pdf but how do I get document to my document file?
A PDF file can be placed in any folder on your computer and opened with a PDF viewer like Adobe Reader. You can convert a PDF to a document (DOC) file but you cannot open a PDF file with a document editor like Microsoft Word. You may want to scan your document as an image file like TIFF or JPG then use the Insert Picture function to get it into a DOC file.
I hope this helps.
Jun 16, 2011 | Office Equipment & Supplies
When I try to print a pdf file from reader 9 its
I know you have, but I have to ask, have you set the printer as windows default? Do you have MS word installed, and can you create a PDF file from your DOC? In reader 9 have you checked the printer setup and checked the properties there for your printer. Then if it fails again I would uninstall reader 9 and reboot and reinstall, after my printer was installed and working as planed.
Feb 11, 2010 | Computers & Internet
Don't know how to use OCR scan function.
Greetings,
i beleive we have the complete setting detail with us.
1. Press the [Send] tab.
2. Press [Address Book] ([File] or [E-mail] also acceptable).
3. Choose an e-mail address. Press [OK].
4. Press [File Format]. Set to [PDF OCR]. Scan Settings
default to 300 x 300 dpi.
5. Choose [Send Settings]. Add [Name] and [Subject]
to the e-mail.
6. Or choose [Doc. Name OCR] to automatically name
document using initial characters of document text.
7. Press [Done].
8. Place the document on the platen glass or in the ADF.
9. Press [Start] to send document.
Regards,
TechSup1
May 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon mp630 scanner
You can save the scanned data on a USB memory or a memory card by using the control panel.
IMPORTANT
- You can not use USB memory card and memory card simultaneously.
1 .Select Scan (Scan) on page HOME (HOME) and then press the OK button.
The screen where you select where the data should be saved is displayed.
2 .Turn the USB memory card direct print port or memory card into the slot.
3 .Select USB flash drive (USB flash drive) or memory card (Memory card) and then press the OK button.
4 .Select Save on USB disk (Save to USB flash). The screenshot Scan documents (Scan document) is displayed.
5. State the necessary settings and then press the OK button.
6. Place the original on the glass plate as shown on the LCD screen.
7. Press the [color] (Color) for scanning in color, or button [Black] (Black) for scanning in black and white.
When the preview is enabled, press the OK button after viewing the preview pane on the LCD screen.
The machine starts scanning and the scanned data is stored either on the USB memory card. Remove the original from the glass plate, the scan is complete.
REFERENCE
- You can only scan images continuously when you select PDF. Continue to scan the confirmation screen. You can save up to 100 pages of images in a PDF file.
- If the USB memory card or memory card becomes full while images are scanned, saved only images that are already scanned.
- You can save up to 2000 files of scanned data in both JPEG and PDF formats.
- Folder and filename of the scanned data stored on USB memory or memory card is as follows:
• Folder Name: (extensions: PDF): CANON_SC \ DOCUMENT \ 0001
• Folder Name: (File Extension: JPG): CANON_SC \ IMAGE \ 0001
• Filename: Serial number, starting from "SCN_0001"
• File dates: 01/01/2008
Mar 28, 2009 | Canon Office Equipment & Supplies
Converting doc to pdf with link reference
Try to download save as PDF converter for office application.
Mar 25, 2009 | Microsoft OFFICE 2003 BASIC OEM ENGLISH MS...
Printer / Scanner won't scan to pdf
Hello! I had this exact same issue or question, I guess you can call it. And unfortunately, the CD-ROM user guide was a lot more helpful for me than the Book guide. But anyway, to answer your question and anyone else who has this same question ...
What you need to do is locate the ControlCenter3 software on your computer for a little configuration. This automatically installs when you install the printer's complete Pro Suite drivers on your computer.
You might be able to find it somewhere on your start bar (left or right side of the start bar). It's a small blue icon with the acronyms "CC3" on it. Anyway, click to open the software. Once opened, you'll need to make some configurations so that when you scan to file, it'll be "PDF" by default.
So once you have this software open, "right-click" on the circle button that says "File" and choose the option that says "Control Center Configuration". Up pops a dialog box with two tabs - Software Button and Device Button.
Now in order to scan to pdf from your Brother MFC 9840 CDW, you simply need to change the "File Type" in the drop-down box to "PDF" under both tabs. You can optionally also change the "File Name" to a recognizable default file name of your choosing (I chose to change it to say "PDF File") and you can also set your default "Destination Folder" (otherwise your scanned PDF files will automatically be saved in your "Scan" folder). That's it! No need to mess with anything else.
Most importantly, you need to make sure that these exact same configurations are made under both the "Device Button" tab AND the "Software Button" tab as well.
Click "Okay" and now try to re-scan your document as a File. It should automatically scan it as a PDF file to your computer.
I hope this helps solve your problem if you haven't already been able to figure it out.
Mar 22, 2009 | Brother MFC-9840CDW Laser Printer
How to set output of scanned docs to default to PDF format using Canon irc3380
hello, go additional function,next programming communications,next common TR, next send out file,choose file to pdf
Dec 21, 2008 | Canon imageRUNNER 2200
MF5650
you have to save it as a pdf file so you can save it all in one doc
Aug 14, 2008 | Canon LaserBase MF5650 All-In-One Printer
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
