Question about Acer Aspire E700 PC Desktop
Computer turns itself off
Acer Aspire E700, running vista, just turns itself off without warning - was happening when the hard drive was full, but I now have 104GB free of 234 and it still does it?
  • kingmarvin Sep 28, 2009
    thanks will give it a crack
  • 3,153 Answers
Your fan speeds up and slows down in response to temperature inside the computer. More so the CPU.
I would suggest getting a can of compressed air made for computers
take it outside, take of the side and blow all the gunk out of there, Really go to town around the fan (you might want to wear eye protection)
While you are in there just check that the CPU cooler itself is not loose
If it is it will have to be re-seated.
If it needs re-seating don't just take it off and put it back on as that might make things worse with your temperature problem they have to be cleaned and new thermal grease put on ($2-5)
DON'T remove the CPU just the fan/cooler assembly.
You must clean both the surfaces without scraping anything off. Use isopropynol alcohol and cotton bud sticks until both surfaces are clean, you can use your finger nail to scrape harder residue if you wish but nothing else.
DON'T pour the alcohol over the CPU
Now apply some new thermal grease (most computer shops have it)
Be careful about how much you put on
Here are
some basic instructions
Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
If everything went to plan you should now be back in business
Posted on Nov 18, 2009
  • 29 Answers
This can be caused due the Computer's software. So according to you that when the Computer got off then the Hard Drive was. Here lies the point. When the Hard Drive was full then the Computer must have experienced a Greater load and as for it the Hard Drive of the Computer crashed. Now you can't turn on the Computer because the whole Hard Drive is now dead and crashed. It can only be fixed by Changing the whole Hard Drive.
Thank you, Have a nice day.
Posted on Sep 28, 2009
    Problem Solver:
  • 7 Answers
This is probably due to a failing power supply.
  • 395 Answers
This is what you should do sir, back up your files and format your hard drive. Install back your programs and get an active anti virus for your computer. Run a comprehensive scan.
Then you are up for a go.
Kind Regards
    Problem Solver:
  • 19 Answers
The two most likely solutions that I can think of would be to
A) make sure that the power cord is inserted all of the way and not loose.
and
B) if option A is good, then I would back up my important files to CD/DVD, format the hard drive and reinstall windows. It can take some time, but your computer will run lots smoother if you do this once or twice a year.
Acer blue screen with warning
Please tell us the FULL brand number and model number of your Acer computer. Then tell us the happenings from the time you turn on the laptop until the blue screen shows. Then tell us what the blue screen warning says.
Aug 28, 2013 | Acer Aspire One 521 532H 533 D260 NAV50...
I'm running a Windows 7 netbook- acer aspire one. 32 bit Prossesor- Intel Atom BOOTING ERROR- I press power and the ACER logo pops up (normal) and then: For Atheros PCIE Ethernet Controller...
This message means that the computer cannot see the hard drive. Unofrtunately, this is usually caused by a failed Hard Disk drive. However, you could try removing and re-fitting the hard drive to see if this cures the problem.
Full instructions on removing and replacing the hard drive can be found here:
http://www.laptopmag.com/advice/how-to/aspire-one-hdd.aspx
Apr 12, 2011 | Acer Aspire One PC Notebook
My Acer Aspire 9302 laptop will not boot up. It worked perfectly until yesterday and I can hear the hard drive whirring but its green light only stays on for about a second and then nothing happens. I've...
The system disc probably did not come with the computer. You could burn one if the computer is functioning correctly. However, you may consider getting a full version of Windows 7 32 bit and trying to install it through the DVD drive.
You'll have to set the BIOS to boot from the DVD drive once you have the install DVD from Microsoft.
Luckily, Windows 7 can be used on many computers that came with Vista or XP originally, without upgrading the hardware.
The Windows 7 operating system costs about $119.99 depending on where you get it.
http://www.microsoft.com/windows/windows-7/compare/home-premium.aspx
This operating system can breath new life into your old laptop, which otherwise may require replacing.
If the hard disk drive actually crashed and is not recoverable, you may have to replace that hardware part, but hard drives aren't too expensive these days.
Good luck on this repair.
Jan 14, 2011 | Acer Aspire 9300 Notebook
Acer aspire 7730 running vista BSOD error startuprepairv2
At this point I would suggest to try a full system restore as the sytem files might be corrupted. You can restore the computer back to factory default,to do so, follow the below steps:
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Jun 26, 2010 | Acer Aspire 5500 5570-2609 Laptop
I got a friends acer aspire E700 and kids got to
just check with ram if there is 2 diffrent ram just remove one and try for installation.
Jan 25, 2010 | Acer Aspire E700 PC Desktop
Picture does not fill Screen
It is displays fine up unto the point where Vista loads, then it must only happen when Vista loads the display driver. I would go with your initial assumption and reinstall the display driver.
Jan 15, 2009 | Acer Aspire E700 PC Desktop
I have an Acer Aspire computer that was purchased in May of this year. It has suddenly become unuseable. It starts the Acer screen and then the small Microsoft bar then it goes blank except the cursor...
You may be correct about the hard drive failure.
But to make sure that it is the hard drive and not Vista, I would try to run the recovery cd that came with the unit. When the cd boots up, select "repair" and let it attempt to fix the problem. If the recovery fails, I would call the warranty Company for service.
Joe
Please remember to rate Techs who assist you for free :)
Oct 09, 2008 | Computers & Internet
Installation of Vista
most probably hard drive issue .you should get in touch with vendor to get it replaced
Sep 19, 2008 | Acer Aspire 5315 Notebook
MY VISTA WINDOWS WONT LOAD
Okay, I think I can help you but I need some more information. I'm assuming your Acer laptop currently has a version of Windows XP installed, yes? And Acer gave you a CD to upgrade your OS to a version of Windows Vista?
And when you mean that you go to your BIOS to access the CD, I'm assuming that you are talking about the boot options menu (selecting the cd drive vs the hard drive or floppy drive or what not) correct?
When you select the CD drive to boot from, what exactly happens? Do you get any error message? Does the computer turn off? Does it appear to try to load from the CD and then switch to your hard drive instead (and load your existing operating system)?
Nov 08, 2007 | Acer Aspire 3680 Laptop
Hard disk problem
If your Wundows vista is a full install program you should have deleted and created the partion then formatted the new partition before installing windows vista. Try this again if you hard drive is stuffed you will need a new one Im afraid but windows vista will tell you this before it installs itself. Goodluck!!!!!
Sep 10, 2007 | Acer Aspire 3100-1405 Notebook
Acer Aspire E700  PC Desktop Logo
188 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
