My passport 500gb external just stopped working. It froze up so I removed it and plugged it back in. When I plugged it back into my computer it starts spinning but then makes a click sound and stops.
  • 438 Answers
I guess its tym for u to buy a new passport!!!!!
Posted on Sep 28, 2009
  • Computers & ... Master
  • 5,660 Answers
I have found through the course of time in repairing computers, and delving with associated computer peripherals, that it is a small circuit board inside an external harddrive that fails.
The basic solution, would be to tell you that you just have to replace the external harddrive.
However, what about the information that is on it? What if it's information that you Must have?
The next solution, would be to tell you to take it to professionals, that do this for a living.
Cost?
Around $75 an hour on up. Average time span? Depends on how much info is on the harddrive. 1 hour minimum, up to 3-1/2 hours, generally.
With a little patience, a basic tool, and a new External Enclosure, you may be able to use the harddrive inside that WD Passport again, and not have to take it anywhere, or buy a new external harddrive.
There is a risk however. It may be that the harddrive inside that WD Passport has failed, and it isn't the small circuit board inside the enclosure case.
A new external enclosure is around $20. This and your time is what you risk. I leave it up to you.
Inside that external harddrive case is an average harddrive. The outside shell, or case is called an External Enclosure.
This is an example of an average harddrive,
http://en.wikipedia.org/wiki/File:Hdd.jpg
At the end of the harddrive are Male connectors. These are metal pins that protrude out of the harddrive.
These metal pins plug into a socket in the External Enclosure case. This part is called the Interface.
This socket is directly connected to a small circuit board.
This is the way the WD Passport is made.
For a problem like yours, most of the time it is components on this circuit board that have failed. The harddrive is okay, but the Interface is not.
(Circuit board connected to socket)
IF, this Western Digital Passport 500GB External Enclosure is still under warranty, it can be replaced.
Problem is, that any information you may want to retain that is on the harddrive, will not be saved.
They will warranty the hardware, (External Harddrive), but not the data on it. (Information)
My solution entails you buying another External Enclosure, removing the harddrive that is in your external harddrive now from it's enclosure, and installing it in the new enclosure. (Apologize for the run-on sentence)
Harddrives come in two sizes. 2.5 inch in width, and 3.5 inch in width.
2.5 is for laptops, 3.5 is for desktop computers.
Your WD Passport 500GB external harddrive, has a 2.5 inch harddrive inside.
Harddrives come in two styles. IDE (PATA), and SATA. Your harddrive in side that case is a SATA unit.
If you purchase a 2.5 SATA external enclosure, you can remove the harddrive from yours, and easily install it this new external enclosure.
I apologize that the information seems to be complicated, beforehand. The transference of the harddrive out of your WD Passport, into the new enclosure is very simple though, however.
The external enclosure of your WD Passport is nothing more than a tin can shell. It separates into two halves. A top, and a Bottom half.
The following is a video on YouTube, that shows a person opening a WD Passport External Harddrive's case. I wish I could give you a more professional video showing you, but this is not the case. It however, does show you in detail.
http://www.youtube.com/watch?v=ITObQxytdH4&feature=related
The following is also for information purposes, and is not advertising for the following website, or for the manufacturer of the product. It is just to show you the type of external enclosure you need.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3743049&CatId=2781
There is also a video on the link above, that may give you more information.
2 Suggested Answers
  • 4 Answers
SOURCE: My passport 500gb external just stopped working.
The clicking sound is caused by the spindle inside the hardrive, because it was not removed properly. Just connect you external hardrive to your computer, if it makes the clicking sound again dont remove it yet, just restart your computer properly. In that way all the devices connected to the computer will be refreshed and properly shut down. If it is not detected still, unplug the haardrive then try another USB port. Recommended ports are at the back of the CPU if your using a desktop. These USB ports have higher voltage output that can power up all external hardrives properly.
Posted on Jan 13, 2011
Removing all my data from wd my passport essential
You plug it in. Right click the drive on windows explorer, then select format. Perform a full format and your data should be gone.
Nov 02, 2012 | Western Digital My Passport Essential...
Jan 13, 2011 | Western Digital My Passport Essential...
I put about 30 Gigs of pictures on my wd 500gb hard drive and am trying to "safely remove hardware". but it says there is a program running that is using the hard drive and to close it. There...
The quickest route would be to go through the shut down process on the computer. That will close out any processes that are still running. I would only do this if you are absolutely sure all the data has been transferred to the external drive. If you're not sure, leave it for a little while and check again later. Hope this helps : )
Jan 01, 2011 | Western Digital My Passport Essential...
I am using the passport essential 500gb on my macbook pro. I dont use time machine...i just backup files manually. I tried to transfer an item to the passport and it told me that it couldnt be moved...
i almost have the same problem, i bought the
Western Digital My Passport Essential 500GBfrom a week ago and i left the drve connected to the laptop and copying data from an old WD drive and after couple of hours i found an error appearing.......then i clecked okay and restarted the laptop and from then my
Western Digital My Passport Essential 500GBdoesn't appear in my computer drive list nor in the device manager.
i just cut my precious data from the other drive.
PLZ help
Mar 29, 2010 | Western Digital My Passport Essential...
Harddrive not being acknowledged by laptop
This is a hard one, as 7 is so new. But it sounds like the very next thing to do is to plug the drive into another computer to see if the drive is working properly. If it works well, make sure that your drive is not trying to grab a drive letter that is already being used by another device. Do a search on the MS website for known issues and instructions on how to check for drive letter management issues. Good luck.
Feb 26, 2010 | Western Digital My Passport Essential...
How to format WD Passport 1TB to FAT32 I have used WD external 500GB passport drive with my samsung 1080p9 dvd player successfully WD 1TB passport drive is not recognised by dvd player
Plug the drive into your PC.
Right Click on My Computer (or Computer in Vista/Windows 7) and select Manage.
Click on Disk Management.
Right Click the Volume in question and select Format. Select FAT32 in the options.
Dec 24, 2009 | Western Digital My Book Essential Edition...
Need help with REPAIRING Western Digital Passport...please!!!!!
Those little disks are susceptible to damage by minute pieces of dust; they are assembled in clean rooms. I advise against your plan. The electronics in the 500GB drive will be looking for a 500GB capacity.
Oct 06, 2009 | Dell Latitude D800 Notebook
WD Passport 500GB - My Computer Panel Freezes trying to recogniz
i know this wont help you, but i am having the exact same problem, so at least you not alone. if you have found anything out i would appreciate the feed back and visa versa if i figure it out.
Sep 29, 2009 | Western Digital Computers & Internet
WD Passport Drive Lights Up But Compu Does Not Find the Drive
Does your drive make any unusual sounds like any of these: http://datacent.com/hard_drive_sounds.php ?
If yes then you got a problem - it's something mechanical with the heads.
If it sounds normal or doesn't spin up at all - try to connect it to another computer and if still no go - remove the internal drive from enclosure and connect directly to PC via SATA port.
Sep 29, 2008 | Western Digital Caviar SE WD1600AAJS 160...
Computers & Internet Logo
1,238 people viewed this question
David Payne
David Payne
