Question about Meade ETX-125EC (500 x 127mm) Telescope
Can't focus my meade etx-125. have turned focusing control more than 80x in both directions. Is there an stop on the focusing system. Originally had the electric focusing system on the scope couldn't focus then either. I have tried both indoors and out doors.
  • rnwilke Sep 28, 2009
    I just called Meade and they won't repair my model of Scope, because it's backend was made of plastic instead of medal.
  • 48 Answers
Yup there is a mechanical stop to prevent you from cracking the mirror by retracting or extending it too far.. once you break the pin off it needs to go to the factory for dis-assembly as they have to remove the primary to get to it and realign it my 105 did same thing....word of advise use a cable extender for focus not an electric focuser they fail to tell you that it can over run the built in stops making your scope useless...i may be mistaken but i believe the max turns is 25 or about for end to end focusing adjustment on the 125
Posted on Sep 28, 2009
Need a focus knob for a MEADE ETX-70 TELESCOPE
You can try calling Meade here:
http://www.meade.com/support/index.html
Apr 15, 2010 | Meade ETX-70 (240 x 70mm) Telescope
MEADE ETX 125 Motors have stopped
The ETX125 is notorious for bad motor control. Weasner's Mighty ETX web site has links to repair centers that are more reasonable than Meade. They also have a QA section to assist with diagnostics.
Jul 23, 2009 | Meade ETX-125EC (500 x 127mm) Telescope
Can't focus
Unless you can find another "used broken" ETX of same model-- to get the focus off of-- your only recourse will be to send it back to Meade for repair--
Here is their customer service phone number-- and their manuals
http://www.meade.com/manuals/index.html
http://www.meade.com/support/contact.html Contact number
Feb 10, 2009 | Meade ETX-125EC (500 x 127mm) Telescope
Can't Focus
The focus screw can come out if run too far. Point it straight up, give the side of the optical tube some light 'thumps' and turn the focuser clockwise. You should be able to see the mirror moving backwards in the cell.
Jan 25, 2009 | Meade ETX-125EC (500 x 127mm) Telescope
Etx cant focus
The LPI camera will HIGHLY magnify the image-- about like a 6mm -8mm eyepiece-- tiny adjustments are needed to focus. You can buy a .5 or .3 focal reducer which will widen the field of view and make it easier to focus--
On my LX90 --- it takes about 20 TURNS of the focus knob to go between the eyepiece view and the camera view!
Jan 11, 2009 | Meade ETX-125EC (500 x 127mm) Telescope
Can't focus on anything at all
Here is the manual-- read it cover to cover--
http://www.meade.com/manuals/TelescopeManuals/ETXtelescopes/ETX-90%20w-autostar%20man.pdf
1. Take off the lens cap
2. Put your lowest magnification eyepiece into the telescope on the TOP eyepiece port-- there is a lever on the side which rotates the diagonal mirror between the top and rear ports --- can you see light through the telescope? If not turn the lever.
3. During the day practice focusing on a distant object at least 100 yards away-- the image will be upside down -- this is not a problem-- no UP or Down in space.!
4. The lowest magnification eyepiece is the one with the LARGEST number on it.
Jan 02, 2009 | Meade ETX-125EC (500 x 127mm) Telescope
LOOSE FOCUS SHAFT
OK, that model has an internal adjustment. A good source for all kinds of information and tips on the ETX series is available from:
http://www.weasner.com/etx/menu.html
Jun 20, 2008 | Meade ETX-125EC (500 x 127mm) Telescope
ETX 125 Loose image when focusing
The ETX family (and other Meade LX telescopes), use a moving mirror system for focus. The focus knob moves the main mirror in and out. For smooth operation, there is some slack on the central tube that allows the mirror to rock slightly as it moves. That is a normal condition, and the movement is magnified, the greater the magnification of the eyepiece.
Jun 15, 2008 | Meade ETX-125EC (500 x 127mm) Telescope
Focusing problem
it could be the grub screw on the knob needs tightening. If it is loose, the knob will just turn but the shaft wont.
Dec 22, 2007 | Meade ETX-125EC (500 x 127mm) Telescope
Focus Issues
Try tightening the grub screw that fastens the knob onto the shft that it turns.
Better still, buy a flexible extended focusser which makes focussing much easier. Check on eBay for "Meade flexible focus"
Sep 27, 2007 | Meade Telescope
Meade ETX-125EC (500 x 127mm) Telescope Logo
435 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
