Question about Arris SURFboard SB5120 Modem
Change from usb to ethernet
Hi I have my computer hooked up on the usb port , but now I need to hook up another computer to the system how can I make the ethernet port active
I know longer need the usb port help
  • 41 Answers
The ethernet port will already be active
Posted on Dec 19, 2007
Do you have a diagram on how to hook up the router to the Desktop Computer. Computer is ready for the router but not sure how to hook it up. I presently have internet on my existing computer and am...
Hi, you can hook the router to your computer using a standard Ethernet cable (the one with connectors that look similar to phone jack connectors, but a little wider). You should have an Ethernet port on the back of your computer, and you can connect the cable from there to the Ethernet LAN port on the router.
Jan 19, 2011 | Linksys Wireless-G WRT54G Router
Ethernet port is ''locked'' dsl modem
reset your router to factory default....look for a small button on the router and keep pressing it until all the lights blink together at once.....do reply back
Nov 11, 2009 | Computers & Internet
Can i hook this up to a wireless rourter. it
Without an ethernet port, you can't connect to a router. However, adapters are available which can adapt usb to ethernet. Check your local computer store.
Oct 23, 2009 | HP PSC 1610v All-in-One Printer
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Usb hook up to computer
Hi dpelcowitz: You have to remove the rear right panel located on the right rear of the machine. When you remove the panel you will see the following. 3. Power cord connection 4. Power switch 5. Parallel port connection (8400 series only) 6. USB connection 7. Configuration card 8. Ethernet 10/100 Base-T connection. Hope this helps
Jun 09, 2009 | Xerox Phaser 8560MFP Laser Printer
Hi,could some one walk me through setting up my Billion modem wirelessly to my Dell Desk top running XP home. I get confused with firewalls,LAN settings etc Ethernet cable is being used at the moment. Do...
I am not familliar with that brand, so I do not know if it is a cable/dsl modem, a router, or a combination of the 2. I will assume it is the cable or dsl modem since you said modem.
The thing we need to do first is give you a basic understanding of whats what, and how it works.
Imagine a 3 tier water fountain. Water flows from the top, to the center, to the bottom.
Your home network is the same way. Signal flows from the MODEM to the ROUTER to the COMPUTER CLIENTS in that order. Keep this in mind. Also, remember you never, NEVER setup a router from a wireless computer client. you ALWAYS use an ethernet connected client in port 1 2 3 or 4.
Quick education about Firewalls: They are programs and devices that are designed SPECIFICALLY to BLOCK TRAFFIC. Think of them like Toll Roads. YOU have to open each virtual port for inbound, outbound, or both. Since that is such a painstaking thing, most firewalls come with default port settings, blocking the most typically unused traffic ports and monitoring the common ones, such as port 80 (the internet port) port 110 (the sending mail POP port) and port 25 (the receiving mail SMTP port). That is why typically, people who can get online (but cant send or receive email) have to disable their firewall or antivirus (security) suite, because the program is closing the ports making them useless. IF you have a router, theres a 99.9% chance that YOU WILL NOT need a firewall. Routers are firewalls by nature.
Quick education about LAN (LAN means Local Area Network, meaning a router inside your house or inside your office or a series of switches and ports setup in your apartment, your "local area") settings: Most lans are DHCP, which means nothing to you, but, in lamens terms it means that you hook it up, turn it on, and it auto configures itself. In the olden days, you had to tell your computer its address, and tell the router its address and the address of each computer, and so forth. Thanks to dhcp, they can now negotiate a lease and assign that info automatically. SO, make sure DHCP is ENABLED. and make sure your lan settings are set to "Obtain ip address and dns server automatically".
Quick education about drivers. you DO need drivers for the wireless devices, you DO need drivers for the ethernet devices, but you DO NOT need drivers for the router, and YOU DO NOT need drivers for the modem. DO NOT HOOK THE MODEM TO THE COMPUTER THRU USB! USB is never to be used unless you do not have ethernet capability, it's like a spare tire. Remove any USB wires from the modem and put them away please! The ONLY wires you want in the modem are POWER and ETHERNET. (they dont make USB routers because USB is not a networking device, USB is a peripheral device)
You will be using Ethernet connection. An ethernet connection requires that you only have the ethernet drivers. So:
YES you need to make sure your ethernet drivers are installed and that your ethernet ports are enabled and working, and:
YES you need to make sure that your wireless card is enabled and functioning, and radio is switched to ON.
Now, remember the fountain? We are going to build it here. The trick is that we have to reset the DHCP list. (if we dont, then it wont work because DHCP will be stubborn and try to talk to the other items, not knowing they were removed). So, we will need to unplug power to the modem and router and shut down each pc client... after you print these directions of course.
While everything is off, hook the main computer into PORT 1 on the router. Make sure that PORTS 2 3 and 4 are empty. (fyi, you can use those for xbox, ps2/3 or wii, or any extra computers). Now, look for a port that says "LAN" or "ETHERNET" or UPLINK on the router. (it will be an ethernet port that doesnt have a number). hook that to the cable/dsl modem. You should now have the modem, hooked to the router, the router hooked to the main pc. Lets start the water flow.
plug power into the modem and wait 1 minute for DHCP synch with the company. (usually you see a sync light or a ready light).
once the modem is synched with the ISp, plug power to the router and wait 1 minute. (so the router can get the dhcp from the modem)
If your modem and router are combined in 1 device, then just wait for synch with isp.
Now start the main computer and try the internet. If you can get online, you have a good network connection. The rest will have to be done by the wireless router mfr, but it isnt hard. In fact, by default, you should be able to start your wireless and get online through it now, but you may want to consider wireless security, (WEP WPA) settings. Call the rtr mfr for those. (its not hard, just tedious and this post is long enough already).. lol. Quick note about wifi: its flaky. If you have a 2.4 ghz phone in your area you may drop connection (wireless only). try different wifi channels to resolve the issue, (call router mfr).
Mar 11, 2009 | Dell Computers & Internet
Trouble with paradyne or linksys
Just saw your post, so please accept my apologies for being almost a month late in responding, as I only joined this service on March 26th.
1. When a modem has both usb and ethernet, only ONE of the two should be used as most isp modems will allow one or the other.
2. Your Vonage should be discreet and not intermingled with the rest of your system. It would be better to connect the Vonage to a router, and not the router to the Vonage. iow, do not connect the Vonage modem between the isp's modem and your router.
3. denigration of service or slowdown is typical with VOIP if more than 2 systems whether telephone or other systems are connected, due to the ringer voltage splitting that occurs when you put more units on the Vonage, or any other Voip modem. One ISP solves this by providing separate outputs for Voip and Ethernet.
Observation of these rules should speed up your system.
Mar 01, 2009 | Paradyne 6381 ADSL2+/ReachDSL Router...
Hooking ethernet to broadband router and cable modem
Hi Sherry - The etherport port on your modem should be connected to the WAN port on your router. You then connect your pc to one of the 4 ethernet ports on the router. If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
Jul 10, 2008 | SMC Universal Wireless Broadband Router...
Hi, My family recently purchased a Brother MFC-210 and brought it home thinking you could hook it up with a USB cord. To our surprisement, no USB slot was on the printer and could only be hooked up with a...
You need to use a category 5 Ethernet cable, not a standard phone cord. A Cat5 cable has 8 wires, where a phone cord only has 4. Surprising that you got anything to print. Look at the connector to verify that it has 8 connecting pins. It is also wider than a phone connector plug. You need to plug the printer into a Ethernet Hub or Switch which in turn connects to your ethernet (network) card or port on the computer. It will most likely not work if you plug it directly into your computer.
Mar 18, 2008 | Computers & Internet
Ethernet for my dell 4600 pc
No, you don't need a card, as long as you have an Ethernet to USB adapter, you should be just fine.
Feb 19, 2008 | Dell Dimension 4600 PC Desktop
Arris SURFboard SB5120 Modem Logo
140 people viewed this question
Top Arris Computers & Internet Experts
jimmy Leo
Greg Ulan
Chris Larocque
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
