Question about Kitchen Ranges
Right front electric stove is stuck on high without shutting off, regardless if knob is switched to off. Needed to unplug the stove completely from electricity.
  • 736 Answers
It depends on the model and manufacturer of your stove .. some have solid state relays that could be shorted (usually computer controlled stove) or a conventional relay (for cycling) that may have a stuck contact .. if its a conventiional stove with spiral cooking surface (not smoothtop) .. then you can make sure the burner is not hot and the stove is unplugged .. then you can simply lift and pull the burner out of its socket .. that will get you working temporarily on the other burners until ;you can fix the problem .. that burner could have an internal short to ground .. easy to check with an ohm meter or by substitution of one of the other burners .. if another burner does the same thing then suspect the relay or control switch ... if the substitute burner works properly then replace the defective one ..
Posted on Sep 28, 2009
The stove surface unit does not heat properly as I turn the knob
The resistance in the switches could be at fault.
Jun 23, 2015 | Kitchen Ranges
HOW DO I CHANGE THE BURNER SWITCH ON MY RA524
Unplug unit. Remove knobs, if they interfere with lifting the stove top. Lift stove top from front of oven, proceed to inspect dials for damage. Repair or replace as needed.
Aug 22, 2014 | General Electric Cooktops
How to shut off the ignition switch on wolf stove
there is no way to do so. If it is continually clicking it is usually due to a boil-over or excessive water usage while cleaning. The water gets into the spark switch and completes the circuit. One suggestion is to unplug the unit for a few days to allow time to dry out. Another is to use compressed air and blow it into the spark switches (located at base of knob shaft).If neither of these correct it, a replacement switch may be needed.
Aug 21, 2014 | Kitchen Ranges
One heater in Samsung glasstop electric range just remains on Hi heat even when I turn the knob to low(Model FTQ352IWUX)
I believe there is an update for this range. The relais board in the back is defective. Contact Samsung abt. this and they will replace it no charge.
Apr 11, 2013 | Kitchen Ranges
I've used you guys once before - right the first time so trying again for a different problem. I've got a Frigidaire glass-top electric range (model PLEF398CCD) and 2 of the four burners stay on...
Thanks for using Fixya once again we appriciate it!
The problem with your stove is going to be with the infinate switch(what ya are calling knob) for the burners that giving ya trouble are shorted and the contacts inside of it are welded so they permanantly are stuck on the HIGH setting. To repair that the switches for the affected burners would need to be replaced.
The part number for those switches is 316095503 they could be purchased at your local appliance partstore or online at;
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
partselect.com
GENE
Oct 02, 2011 | Kitchen Ranges
The largest element on my stove; when set on HIGH for some time period, will remain heating on HIGH even when the knob is moved to any lower setting. I have had to turn the element OFF and wait a couple...
sounds like the switch is bad.i looked up you stove and it looks like the front left is the largest burner.you can call your parts store,give them the model number,tell them what burner you're having a problem with and they will sell you the correct infinite switch,when you get it,unplug the stove,remove the top back panel,pull off the knob,remove the two screws that hold the switch in place,pull one wire off at a time and connect it to the new switch,should take you no more than 30 minutes
Feb 17, 2011 | Whirlpool RF378LXKS Electric Kitchen Range
How do you replace a burner switch on a Frigedaire Glasstop Stove
The repair on this stove will be relatively easy then. All you are going to have to do is pull out the stove from the wall and remove the upper part of the back panel where the burner switches are.
Remove the knob and take out the screws that hold the switch to that front panel. Then from there just match up the wires to the new switch off the old one.
This repair will turn out to be pretty cut and dry for you. If you have anymore questions please ask.
Thanks Again,
Bill
Jan 10, 2009 | Frigidaire FEF366DC Electric Kitchen Range
My right front burner will not turn off on my electric stove top?
Hello, the switch controls the element ,if the element is staying on replace the switch.Please note any electrical repairs should be performed by an authorized service technician. good luck
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
279 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
