Question about HP DeskJet F4280 All In One Printer InkJet
HP 4288 does not print strainght.
My HP 4288 printer does not print strainght vertically. This has started happening after refilling the black color cartridge. Hope this is not the problem.
How can I get my HP 6500a plus printer to PERMANENTLY default to black printing? I am needlessly using too much color and the default setting is only for a single document.
Hi
Go to right click at the printer icon on your computer and choose printer properties or printing preferences and from there choose the color setting to print in black alone. Regards
Jun 23, 2011 | HP Officejet 6500 Wireless All-in-One...
What is problem when a ink jet printer (hp psc 2410xi photosmart) has a red stripe in the black print?
Using HP56, 56 cartridge for your printer?
Well, when you are out of black ink, that's what it happens.
Pls refill your cartridge or replace with new one.
How you refill? very easy.
f you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 12, 2011 | HP Office Equipment & Supplies
I have HP deskjet F4488 printer which is all in one method. but i have problem that whenever i am trying to print the color(document)page in black & white type but i cant get the black & white...
hi..
in when you click on the print botton a dialogue box opens which shows the print properties. in that you have to select the grey scale then only it prints in black and white
if my answer was usefull please vote me
Jul 14, 2010 | HP Office Equipment & Supplies
Refilled cartridges problem
Acctualy some types of cartidges have problems after refilling, so if it is not working, you should get another new one.
Jan 31, 2010 | HP Office Equipment & Supplies
I have hp 4288 printer. Refilled cartridge does not work
ur cartidge nosel is jammed. get some drop of water on ur finger tip put it on nosel then put the cartidge nosel on newspaper because it is a good absorber it wiil help the ink to come out try for some times if it not work replace ur cartidge...
Nov 29, 2009 | HP DeskJet F380 All-In-One Printer
Vertical lines on every page being printed
dear friend
you have burned your teflon
well its not ur fault
it just happens
earlier if using refilled or other company toners
later even if using hp originals
if your printer is in warranty go for rma, ( but dont forget to clean in from inside)
if not get a printer repair repair technician to replace its teflon
in india i replace it at mere 20 dollars
thanks
Apr 11, 2009 | HP LaserJet 1320 Printer
HP officejet 7210 hortizontal white lines
I would suggest you get a set of original HP cartridges .. I have clients trying to save $ all the time by buying refilled and/or refilling themselves to only go and get HP brand. Refills just don't cut it .. leaks, poor print quality, unrecognized cartridges .. there are so many things that I can point out .. save yourself the hassles .. get HP
Mar 30, 2009 | HP Officejet 7210 All-In-One InkJet...
HP Laserjet IIIP starting printing thin vertical black line
Was this happening before you swapped toner?
Is there toner streaks on the drum? Yes? Defective.
What if you stop the printer (open cover) as it passes through the fuser to determine if image is from drum or fuser?
But really....isn't it time to move on anyway???
Mar 20, 2009 | HP LaserJet IIIp Printer
How to fill the ink catridge of desk jet hp 4288
u must go to a retailer who does the work for u
he wil refil the ink for some cost
Mar 01, 2009 | HP xw6600 Workstation with 650W 80 PLUS...
Zebra 110xi plus not printer strainght across label
* do full manual calibration
* reduce the print speed & try
* set back feed as before instead of default
* try with little big labes
Jul 28, 2008 | Zebra 110Xi III Plus Thermal Printer
HP DeskJet F4280 All In One Printer InkJet Logo
52 people viewed this question
Seeker5211
Seeker5211
