Question about Refrigerators
There is ice forming on the entire rear wall of the cooling compartment of my one year old Liebherr comfort refidgerator Model IKS 1524 20D. Items near the back of the fridge are freezing as a result. The temperature setting is only just enough to bring the interior light on, so its virtually at its lowest setting.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 168 Answers
  1. Determine the temperature setting. The refrigerator should be set to temperatures ranging from 34 degrees to 40 degrees, while the freezer should be below 30 degrees. Adjust the temperature setting which will naturally improve the ice build up that's been caused by the wrong temperature setting.
  2. Step 2 Move the refrigerator away from the wall. Oftentimes, this simple action is all that is needed because the unit is not getting enough air circulation behind it. Also, some refrigerators have vents underneath the unit, which are easily clogged with debris. Clean these vents and coils.
  3. Step 3 Remove food and shelving from the refrigerator and freezer portions of the fridge. If ice build up is happening in the freezer, the drain in the freezer may be clogged. With the unit off, remove coverings to expose drain and pour hot water down the drain hole until it comes out into the drain drip pan under the fridge.
  4. Step 4 Check the condenser coils. The evaporator coils could be causing the problem of ice build up. If this is the case, professional repair is likely needed to replace the motor, thermostat or other problems within the fridge. A handy person can make many of these repairs with experience by purchasing the parts they need online.
  5. Step 5 Call a repair technician to come to the home to check the unit for problems. It can be helpful to have a professional determine the source of the problem, but then to do the work yourself by refusing their service. Order the parts and make the required repairs.
Posted on Sep 28, 2009
Dear Sir The refrigerator number is K1 2530, I moved into a flat this summer, the refrigerator did not seam to keep food cold enough and things spoiled quickly, I have set the cooling gauge to its coldest...
Ice formation at back of unit is a sign self of defroster mechanism malfunction. If the ice in rear is primarily at the beginning of the gas line going to the evaporator then there is low gas in system.
Jun 12, 2017 | Liebherr KI 2440 Premium Refrigerator
Liebherr KBES 3650 - too warm in main fridge compartment. Hi the main fridge compartment of this larder fridge warmer the it should be (milk does not taste as cold as it should). The temp...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | Liebherr KBES3650 Stainless Steel...
Water leaking. Mongram zic[s]360 (frig on top, pullout freezer on bottom with ice maker. no water dispenser). Leaks with water supply cut off to icemaker. Ice forms on bottom. Several years old but we...
Have the fridge pulled out and check behind it. I had same model and it was leaking into my walls/floor and caused thousands of dollars in damage to my kitchen. BLACK MOLS Covered my walls/cabinets and made me sick. Please be very careful with this excess water coming from this model. GE should recall it but will not unless forced. Not Cool.
Jan 16, 2010 | GE Monogram ZICS360NR Bottom Freezer...
Refrigerator not cooling, freezer is working.
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fdite
Oct 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Sears Coldspot 17 frostless freezer not defrosting
One reason for the fan running is that it is trying to distribute the air in the compartment. Look at the very rear of the freezer on the bottom and see if the little vents, which allow water to disperse, are not filled with frozen ice. If so, turn off the fridge (unplug it) and use a hair dryer to melt that ice until it is all gone. That will probably fill the condensation pan under the unit and you'll need to empty it.
Feb 01, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Liebherr larder fridge not working in normal mode
thermostat is faulty - supercool just bypasses the stat
Sep 23, 2008 | Liebherr Refrigerators
No cooling in refrig, botton freezer forming too much ice
let me know I can help you get it going again..
Sep 01, 2008 | Amana Refrigerators
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
