Question about Cameras
Dcr32e touch screen not working
Dcr32e touch screen buttons not working
My lg encore touch screen will not respond to any touch. the power button, volume button, the camera button, and the charger all still work, but no matter how many times, or where you touch the screen, it...
Displex Touch Screen Polish is perfect to protect screen of your Smartphone. Tired of a smeared, dirty, scratched up touch screen? The Displex Touch Screen Polish is the simple solution for this problem most smart phone users have. This new special polishing paste gives you the ability to mask off apertures in the display. It will make a layer of transparent protective film on your screen. Safe and made specifically for touch screen phones, the displex paste will not damage your touch-screen.
Features:
  • Displex Touch Screen Polish is perfect to protect screen of your Smartphone.
  • The Displex Touch Screen Polish is the simple solution for this problem most smart phone users have.
  • This new special polishing paste gives you the ability to mask off apertures in the display.
  • It will make a layer of transparent protective film on your screen.
  • Safe and made specifically for touch screen phones, the displex paste will not damage your touch-screen.
  • It protects your screen from dirt and dust.
  • Antistatic and reduces fingerprints.
  • Perfect for touch screen phones, touch screen devices and tablets.
Specifications:
  • Type: Screen Polish.
  • Scratch-proof.
  • Invisible protection.
  • Manufacturer: Displex .
May 05, 2011 | Cell Phones
My arcos no working teh touch screen so bad because for example u press a dive k d q etc
I believe you are trying to say that your touch screen isn't working. Your touch screen is probably locked. Its similar to a button hold lock, when this is activated, you can't press any buttons do anything unless you unlock it. To unlock the touch screen, press the ON/OFF button (don't hold the button for a long period of time. A message will appear on your screen asking for your conformation (approval) to perform the task. If that doesn't work, tap the TOOLS option, then select SETTINGS, and choose SCREEN. Once you've done that, choose the "Touch Screen Calibration" button and follow on-screen instructions given. If the second solution doesn't work, the "Touch Screen Calibration" option can be forced by using a feature called 'System Recovery'. To do a system recovery, Press and hold the Power button, then the Volume + button as soon as possible until you see a white screen, as system recovery is beginning. While this is happening, you will not be able to use the touchscreen to navigate between items. In order to navigate between items, you will have to use the Volume + & Volume - buttons and use the Power button to validate your selected task. The system recovery feature gives you a lot of options. Select the "Touch Screen Calibration" option and follow on-screen instructions given. I hope this activates your touch screen again.
Mar 22, 2011 | Archos 7 Digital Media Player
LG touch phone. Touch screen keeps blanking out, it that the touch screen will not work. Screen shows everything but the touch of the screen does not work. I have took out the battery and replaced it. It...
when phone is idle, the auto lock feature locks out the screen. you can set the time when lock engages or disable completely. To unlock, press top right corner button or use touchscreen options by sliding finger up from bottom to top or press unlock button on bottom of touchscreen
Feb 19, 2011 | AT&T Cell Phones
Ipod touch screen stopped working
Try Holding In the Top Button And Touch Button For A Long Time Around 7-10 Seconds.. It Will Reset The iPod And Your Screen Might Work
May 06, 2010 | Apple iPod touch
Set time and date of Handycam
hi,
its a ruttin problem you just change the LCD FLAP its easily available ,just change it and find the magic,
Aug 30, 2009 | Sony DCR-HC32E DV Digital Camcorder
Touch screen not working
touch of e900 detected when you cover the light.its mean when not work then something wrong with detector behind buttons.remove dust from button using anti germ chemical.may be button come back to work.if then your button detectors get damaged.get repair from phone repairing shop.
Aug 01, 2009 | Samsung SGH-E900 Cellular Phone
Bottom screen wont work
Have you attempted to recalibrate the touch screen?
Since you can still use the navigational buttons,
From the main menu:
1. Click the "Settings" button. It is the button at the center bottom with the DS on it.
2. Then click the "Touch Screen" button. That is the one with the Yellow Crosshair on it.
After that, proceed to calibrate your touch screen.
Let me know if that does not work.
Dec 09, 2008 | Nintendo DS Console
My touch screen is not responding
My touch screen has not been responding but my navigation buttons are working. I'm not able to check my contacts too.. .
Oct 27, 2008 | Motorola Mobility MOTOROKR E6
My touch screen buttons stopped working, and now I cant play back or even put footage on the computer. I try to click the touc screen buttons but it doesn't work. The recording and everything works fine,...
the flexwire is the problem of your camera and if all wiring be cut the next problem is the lcd monitor would not turn on...go to a service center for replacing or repairing the flexwire...
Sep 01, 2007 | Sony DCR-HC26 Mini DV Digital Camcorder
Cameras Logo
55 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
