Question about Cameras
Canon digital IXUS 500 video mode doesn't work on it??Just stop working, won't even show on screen the video mode icon.
SOURCE: CANON FAULTY SCREEN IMPORTANT READ ME
I have read that there seem to be many issues with no display on the LCD in playback or photo mode. What can I do to get this resolved? Thanks you. Greg
Posted on Sep 15, 2008
SOURCE: canon digital ixus 700
I understand that it takes a maximum of 2GB. Still loads of photo/video capability. Don't make the mistake I did of buying a 4GB SDHC card for it. It won't take it.
Posted on Sep 28, 2008
Only for the brave, on a warrenty expired camera.
Buy a set of jeweller's screwdrivers.
Make sure it is off, with the lens retracted, and remove the battery and SD card.
Remove the 11 screws holding it together
The metal shell is in two halves that can be pulled apart. The rubber socket cover flap has to be removed once one half is off. A rubber gasket round the eypiece lens may drop off - it is easily replaced.
Hold the inner chassis by the edges.
The lcd screen is held by one screw, half hidden under the wiring to the flash - remove it.
Push the wiring to one side just sufficiently to enable you to hinge the lcd screen up on its flexible printed circuit wiring loom.
Underneath you will see the back of the ccd pod, with a flexibe printed circuit wiring loom pinioned under a metal plate with two Y shaped holes filled with brown gunk, and held down by a torex screw locked with some holt melt adhesive, and two further screws inaccessible under the metal chassis to the right.
I hypothesised these were the contacts that become detatched in hot conditions, and (1) tried to shift the flexible printed circuit minutely from side to side using the hole in it (it didn't move appreciably)and (2) pressed down quite hard in the centre of the metal plate, having supported the chassis from below so as not to damage the lens.
I reassembled the whole thing and it worked immediately, with just a faint light smear down the left hand side of the image (the whole image had been completely smeared, then dark, before) which was only noticeable when photographing in dark conditions.
So I took a gamble and it seems to have worked. If it hadn't I was going to break the glue seal on the Torex screw and unscrew and then screw it up again.
Obviously doing this is on your own responsibility.
Posted on Oct 25, 2008
t00nz
  • 4738 Answers
SOURCE: Canon digital IXUS 970IS, pink/purple screen images
Sounds like a CCD image sensor problem, not a do-it-yourself repair, but this would also definitely fall under warranty repair. The IXUS 970IS is a relatively new camera, and thus your camera should likely still be under warranty. Recommend that you contact Canon directly to arrange warranty repair. If in US or Canada, call 1-800-OK-CANON. All others, www.canon.com, select "Support" and then your Region for further info in your local area.
Posted on Feb 19, 2009
t00nz
  • 4738 Answers
SOURCE: a 4 year old canon ixus 500 fault on screen only
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Jun 28, 2009
The lcd screen distorts & my pictures show up pink on the display screen on my ixus 500
If the menus and icons look normal, but images are distorted or discolored, you may have an image sensor (CCD) problem. See Canon's service notice regarding this issue here. Canon will repair your camera at no cost regardless of warranty. Contact them at your regional Canon service agency.
Mar 26, 2010 | Canon PowerShot S500 IXUS 500 Digital...
A 4 year old canon ixus 500 fault on screen only getting pink/mauve flashes across screen flash works but no result as unable to see any subject
Jun 28, 2009 | Canon PowerShot S500 IXUS 500 Digital...
Lines across still pictures - but video ok
Mar 21, 2009 | Canon PowerShot SD100 / IXUS II Digital...
Black screen
First press the DISP button on the back of your camera. If this does not correct the problem, then this sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Nov 15, 2008 | Canon PowerShot S200 / IXUS 178 Digital...
IXUS 500 Screen Not Displaying Picture
Did you see the posting regarding the image sensor? I am exibiting the problems which sounds like it could be what you are seeing. I went ahead and send an email to canon. we will see what happens. I suggest you do the same.
-MitchDZJ
Oct 25, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Preview mode not working and lines on the screen
canon ixus 500.
when i switch mode to playback/preview it doesnt work so i cant view pics that are taken or can i upload them to my pc.
Jun 28, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Blank LCD Screen when in shoot mode
Mar 23, 2008 | Canon PowerShot SD100 / IXUS II Digital...
Cannot see realtime display in camera or video mode
Feb 24, 2008 | Canon PowerShot SD100 / IXUS II Digital...
Display not working
This sounds like it might be a defective CCD imager. Especially when you mentioned voice but no picture for video. If so, Canon will fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Feb 14, 2008 | Canon PowerShot A70 Digital Camera
Cameras Logo
62 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
