Question about Gigabyte GA-8IG Motherboard
GA-8IG mainboard. power comes on as soon as plugged in all fans work but no lights. No sound no signal to monitor. tried new power supply it wouldn't power on at all.
  • 153 Answers
Check for any physical shot in the board....
it ma happen only if the board turns faulty
remove all the attachments on the board sucha as ... processor ...ram... and any add on cards and then check .... if ok...
install the processor and then check........
you should get a long beep sounds
Posted on Sep 28, 2009
No power to HDD, CD Drive, Cpu Fan but Mouse and Keyboard receiving Power
Hello i think your power supply is dead.
Try to replace it with one you know is working.
Here is the gigabyte homepage:
http://www.gigabyte.com/support-downloads/download-center.aspx?kw=ga-8i915me
Try to download a manual after you find the right mainboard.
Good luck
Dec 19, 2012 | Computers & Internet
My emachine desktop tower will not power on
the sound you are hearing or heard could have been power surging through a powersupply unit that just blew.. hopfully it did not effect any of the other hardware..to trouble shoot this you can do one of two things..1 disconnect the 20/24 pin powerconnector from the motherboard 2 disconnect the cpu power connector 3 disconnect the 6pin power connector from the graphics card if there is one some machines have onboard video chipsets if thats the case then no worries 4 disconnect the Harddrive power 5 jump the power supply to see if you get any power from it any questions on that go to youtube and type in how to jump a power supply... or option 2 is buy a new power supply make sure its 80plus certified and replace it...i know its a lot of work but i hope this has helped you
Aug 26, 2012 | E-Machines eMachines Desktop PC
Monitor comes up with no signal, and fan is not going round on the tower I have a Packard Bellk Imedia 5061
Could be just about anything so let's go step by step.
Check power outlet for voltage. If you're using an extension, check that too. You can easily check by plugging in something else and see if it works.
Check power cable from pc to the wall. You can use a cheap multimeter for this. If it's a sealed plug then chances are that it's good unless the cable is perished or chewed up.
Check power supply. Easiest way is by shorting the power_on pin to ground. Go to http://pinouts.ru/pin_Power.shtml for more details. If it turns on it might be good. Check the pinout according to the voltages they should be giving you. If they're ok then it most probably is a fried motherboard. Last thing to check - trace the power button cable from the case to the mainboard, remove the connector and short out the 2 pins that are exposed. If the mainboard is good then it should start up. If it doesn't start up......well....most probably you'll have to change the mainboard.
Aug 13, 2012 | Work Station 250W ATX POWER SUPPLY (=...
Screen does not turn on but green light is on.
Green light indicates the monitor is getting power. Nothing coming up on the screen indicates, No Signal.
No signal from the computer. This means the computer itself isn't working.
A bad power supply in the computer can cause this. A bad power supply is the leading cause of desktop computer failure. It is replaceable, and can be done by the owner relatively easy.
You may have a computer tower that the Power light comes on, you hear fan/s spinning, (Including the Power Supply fan), and it sounds like the harddrive is running.
ALL the lights in your computer use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
A harddrive sitting there spinning in an endless loop, consumes about 2 to 3 Watts.
A Processor uses 51 to 125 Watts. Depends on what Processor it is.
A weak Power Supply will have enough power for lights, fans, and that harddrive sitting there spinning.
It won't have enough power to turn on the Processor.
[No processor operating, then the harddrive sits there spinning in an endless loop, because there is no processor to find the boot sector]
For a test, connect your monitor to a know good computer. See if it works.
Now connect that other monitor to your computer.
Sep 05, 2009 | Sampo P7011M (Silver) 17 in. Flat Panel...
Asus p5s800-vm MB has complete power lets monitor know
Disconnect the hard drives, cd/dvd drives and any expansion boards you have plugged into the mainboard. We want to remove as much as possible to see if we can eliminate the problem.Using the onboard video, start it up again, and see if it comes up. If it does, then its one of the items you disconnected. Power down and reattach one of the disconnected items and power up again. Did it come up? Keep in mind that we want to see the bios start up screen. Once you have attached all the items you will have found the bad component. Replace it. But lets say you didn't get a good system when you disconnected everything. Well, that narrows down the suspected bad items to: the mainboard, the power supply, the memory, or the cpu. The power supply has many voltages coming out of it, keep in mind that the drives, cd/dvd rom drives and fans use 12 volts for spin up. There are 3 other voltages used by the mainboard. I would replace the power supply next with a known good one. Then it gets a little costlier, the memory, then the cpu and then the mainboard. Stick with it. You'll find out which it is. Good Luck.
May 21, 2009 | ASUS P5S800-VM Motherboard
Ga gigabyte mainboard trouble
Just because it doesnt beep doesnt mean the vid is not gone
place board on a non metal surface hooked to
monitor
keyboard
mouse
powersupply UNPLUGGED RIGHT NOW
cpu with heatsink and fan attached
ram
plug power supply in (will not shock you just dont lick it ok)
if board does not come on take a small flat head screw driver look at where the power wire would slide on cross those two pins should come on. again will not shock you.
still no video try pci (most basic video mobos support) card
still no video could be cpu I have had several of these be bad caouse no video also
try anouther cpu same setup
still no vid mobo shot sorry
Oct 24, 2008 | Gigabyte GA-7N400 Pro2 Motherboard
GA-MA790FX-DQ6 Mobo not POSTing Should i reset the bios??
no beeps, indicates you have faulty CPU or mainboard.
  • remove all components even RAM and CPU.
  • insert only CPU and Speaker (without RAM or any other componet).
  • Boot and try to hear, there must be long beep for missing RAM, if not then try to re-insert the CPU or change the CPU/Mainboard.
Thanks and Good Luck
Iqbal
May 14, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
New power supply, but turning on no signal to monitor
well this is one of the nightmare problems I keep got into ..there can be alot of posibilities..but the most common are the video card is damdaged or the mainboard.try to change the video card and check than.if the problem persists,than is a motheboard fault..look to all the condensors,chech the intefrity of your connections..
good luck.
it is  a very booring work.
Feb 03, 2008 | E-Machines (308714) Motherboard
What to do
try remove and clean the memory and fix it back.
we know if the mainboard and processore are working because it beeps when you start the system without the memory.
In the case that if ever the u can't beef at all then try to examine the mainboard and the processor.
Jan 16, 2008 | Computers & Internet
COMPUTER WON'T WORK
Is the CPU fan running?
Oct 21, 2007 | Computers & Internet
Gigabyte GA-8IG Motherboard Logo
50 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
