Question about Dell Inspiron 1501 PC Notebook
I get a blue screen with flickering white lines
After logging on everything seems to be loading fine. But then five minutes into it the screen goes blue with flickering white lines and dots. I've tried uninstalling and reinstalling the drivers for my graphics card but ran into a problem there too. I'm using windows vista home basic 32 bit system. The graphics card is a ATI Radeon xpress 1150. Any ideas on how to fix this problem?
  • mikecilla Sep 28, 2009
    Here's the thing, I can boot into safemode. The only bad thing is I cant run some services because of safemode. Is there anything I can do myself to solve that invertor problem?
  • 374 Answers
Try connecting an external monitor...this will clear one thing...it's either your screen or your hardware/software. In some cases if works fine if ac adapter is connected and when the notebook is run by a battery it starts flickering so you can even try detaching your battery and using only the adapter. As you have already tried installing the video drivers,I believe it's a hardware problem. Take it to an authorized service center.
Posted on Sep 28, 2009
  • 788 Answers
It couuld be the invertor is burning out.
If you boot into safe mode and the same thing happens, it is not a software problem or drivers.
TH-42PX75U horizontal lines (flickering black and white)
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
Feb 21, 2014 | Panasonic VIERA Televison & Video
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
My emachine E525 goes white after logon
First try to start pc in safe mode,by normally Pressing F8 key when windows starts up
If you have done then update your graphic drivers just go the site of your Laptop manufacture. Once there enter the model number OR service tag of the laptop then request driver (usually found in the web site's "Support Section"). There you should be able to find all the drivers for your model laptop
-Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
If -If this didn't help you then simply get the Intel software partner Reginout to fix all the errors and registry issues which causing blue screen
Jun 18, 2013 | Acer Computers & Internet
Screen crashed to flickering gray screen
Try a roll back of the Graphics driver. Have you done any Graphic Updates? Install the driver from the DELL or Windows Update website. Does it work with a external monitor? When you boot in safe mode your machine uses the Basis graphics driver. Is the monitor OK when you boot in safe mode?
Jan 07, 2013 | Dell Inspiron 1764 Laptop
I have an HP compaq presario cq71-230sa. Laptop worked fine a few hours before, and then when I lifted the lid, the screen was black with 2 lines of white dots running down the left hand side, and the...
Can you check the function buttons and make sure the primary display is set to show the output on the laptop. Try repairing your OS. If not then re-install the os. As you are saying till the time windows gets loaded, all works fine so it seems the issue isn't really the hardware.
Jul 18, 2011 | Compaq Presario 700 470024-192 Notebook
Vizio P42hdtv10a has distorted blue and white
Very likely the power supply is failing.
Dec 01, 2009 | Vizio P42HD Television
My lap top screen continues to flash white
Your driver or monitor is totally screwed up.Try to get some live cd i recommand u this one.
If it doeasn't work then is a hardware problem that i can't solve remotly.
Apr 01, 2009 | Gateway Solo 5300 Notebook
Flickering multi-colored line in the middle of the screen.
You have a failure in the vertical deflection circuit. This could be either a bad vertical chip, the power supply that runs the chip or a bad capacitor in that circuit. This is usually a repair best left to a professional. There is a small possibility that it could be bad solder connections. If genlty tapping the unit temporarily solves the issue you can try and resolder the pins on the vertical chip LA7841 is the part number. There is also a resistor 1 ohm 1 watt. If that resistor is open you can assume the IC is bad
Oct 26, 2008 | Sanyo DS27800 27" TV
Screen becoming blue and flickering white
I fixed this same problem using a registry scanner. Here's a link to a good free one:
www.your-free-info.com/RegCure
I've used this one and it sped up my computer by quite a bit. Hope this helps.
Jul 17, 2008 | HP Pavilion TX1000Z Notebook PC
Dell Inspiron 1501  PC Notebook Logo
1,011 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
