Question about Nokia Card Phone Dual Band Version 2.0 (MOB-DAT-0117) Modem
RMP-1 Greetings ! Yes, i ve an RMP-1high speed modem which does'nt work on sp2. Is there a way or any software required to get it working?
0 characters
1 Points
Product ID 3409 Brand D-LINK Vendor Code DFM-562IS Description 56K V.92/V.90 Software-based PCI Modem
The DFM-562IS is a software modem card. It plugs into a PCI expansion bus slot of a desktop PC. It supports voice, fax and data transmission/reception. It's a high-performance CONEXANT-based modem card, and can be used to connect to the Internet, and for fax and voice communication.
Key Features
High speed External Data/Fax/Voice
Plug and Play Installation
ITU-T V.92/V.90/K56flex Auto Detect
Fax Mode up to 14400bps Transmission Rate
Technical Specifications
Data ITU-T V.90/V.92
ITU-T V.34, V.32bis, V.32, V.22bis, V.22
Bell 103 & 212A
V.44, V.42bis & MNP 5 (Data compression)
V.42bis & MNP2-4 (Error correction)
V.80 (H.324 video conferencing interface)
FAX V.17 (14400bps FAX)
V.29 (9600bps FAX)
V.27ter (4800bps FAX)
Voice With voice support via sound card application
System Requirements Requires CPU with MMX support
Operating Systems:
Windows 98,
Windows ME,
Windows 2000,
Windows NT 4.0,
Windows XP
Manufacturer D-LINK Warranty 2 Year Manufacturer's return to base Link D-LINK DFM-562IS Internal PCI 56K Voice/ Data Software Modem
May 03, 2010 | Modems
I can't get on the internet
>> do i have to call my internet service provider to activate my modem?
Each modem has a unique "address", and your I.S.P. uses that address to authorize each DSL-modem that tries to connect to their network.
Or, if the two of you live in the same house/apartment, you should just buy a "router". Then, both computers can connect to the router, and the router connects to the DSL modem, and both of you can "share" the monthly fee for the _one_ Internet connection.
May 27, 2009 | AT&T High Speed DSL Modem
tata's surfing speed is 155 kbps but their max. downloading speed is 15 kbps,if ur getting more den 15 den its welll n gud
Apr 06, 2009 | Modems
Yes i want to find out if a cable modem will work with your dsl phone internet service?
A cable-modem connects with a coax-cable to the cable-company's network, but a DSL-modem connects with telephone-cable to the telephone-company's network.
Jan 27, 2009 | AT&T High Speed DSL Modem
Are you able to work on computer from your end to solve connection problem
Yes, if the "problematic" computer still has an Internet connection, then one can use a tool like "Remote Desktop Protocol" to connect over the Internet to the computer.
Jan 23, 2009 | AT&T High Speed DSL Modem
I have a modem speed 56,6 kbps, how can i changes is speed 360 mbps because my modem can be speed in 360 mbps. thanks. what i should be changes that?
Unfortunately Dial-up modem speed cannot go fast than 56kb.
For more speed you'll have to get either DSL/Cable high speed internet service.
Jan 08, 2009 | Modems
SB5100 Docsis 2.0 Upgrade from Docsis 1.1
Technical Details
  • Model: SB5100
  • Type: External, platform-independent modem with HTML-based user interface for status troubleshooting
  • Standards: Integrated DOCSIS 2.0 A-TDMA and S-CDMA technology
  • PC interface: USB for Windows 98/2000/XP
  • Cable interface: F-Connector, female, 75 ohms
  • CPE network interface: USB, Ethernet 10/100BaseT (auto sensing)
  • LED indicators: Yes (front panel)
  • Users: Supports up to 32 users (1 via USB and up to 31 via Ethernet or 32 users on Ethernet)
  • Power: Internal power supply: 9 Watts (nominal)
  • Input power: 100-240 VAC, 50-60 Hz
  • Excite@Home Level 2 Approved: Yes
  • Bridging: Ethernet and USB connections are bridged allowing LAN traffic between USB device and Ethernet LAN
  • Networking: 10/100BaseT Ethernet (auto sensing)
  • Remote management: Yes (via SNMP)
  • Software upgradeable: Yes (over the network)
  • Top-mounted stand-by button: Yes (enhances network security to end-user)
  • Troubleshooting: HTML-based diagnostic user interface
  • Global safety approval and certificates: CB scheme (EN60950/IEC950), CE-Evaluation test report (EN55022/EN55024), FCC Part 15, UL 1950
  • Downstream demodulation: 64 or 256 QAM
  • Downstream maximum data rate: 38 Mbps
  • Downstream bandwidth: 6 MHz
  • Downstream symbol rate: 64 QAM 5.069 Msym/s
  • Downstream symbol rate: 256 QAM 5.361 Msym/s
  • Downstream operating level range: -15 to +15 dBmV
  • Downstream input impedance: 75 ohms (nominal)
  • Downstream frequency range: 88 to 860 MHz
  • Upstream modulation: 8, 16, 32, 64, 128 QAM or QPSK (with A-TDMA or S-CDMA enabled CMTS)
  • Upstream maximum data rate: Up to 30 Mbps
  • Upstream bandwidth: 200 kHz, 400 kHz, 800 kHz, 1.6 MHz, 3.2 MHz, 6.4 MHz (with A-TDMA or S-CDMA enabled CMTS)
  • Upstream symbol rates: 160, 320, 640, 1280, 2560 and 5120 ksym/s (with A-TDMA or S-CDMA enabled CMTS)
  • Upstream operating level range: A-TDMA: +8 to+54 dBmV (32QAM, 64QAM), +8 to+55 dBmV (8QAM, 16QAM), +8 to+58 dBmV (QPSK), S-CDMA: +8 to+53 dBmV (all modulations)
  • Upstream output impedance: 75 ohms (nominal)
  • Upstream frequency range: 5 to 42 MHz (edge to edge)
  • Data protocol: TCP/IP
  • Operating temperature: 0 degrees to 40 degrees C
  • Storage temperature: -30 degrees to 80 degrees C
  • Operating humidity: 0 to 95 percent R.H. non-condensing
  • System requirements: Windows 95/98/2000/NT/Millennium, Macintosh, UNIX
  • Width: 2.3 inches
  • Height: 6.2 inches
  • Depth: 6 inches
  • Warranty, parts: 1 year
  • Warranty, labor: 1 1year
Nov 25, 2007 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Question about my external modem
I understand that you are using Windows XP. The following are the updates available online windows XP sp2,sp3 they are available for free to download.
Oct 01, 2007 | Compaq Microcom 415 (321108-001) Modem
Nokia Card Phone Dual Band Version 2.0 (MOB-DAT-0117) Modem Logo
54 people viewed this question
Top Nokia Modems Experts
Are you a Nokia Modem Expert? Answer questions, earn points and help others
