Question about Dell Inspiron 6400 Notebook
AC adapter not recognised
I have a dell inspiron 1520 notebook which is about a year and a half old. It stopped to recognize the ac adapter. when it is turned on it gives the error that the ac adapter type unknown. please connect a dell adapter. The adapter works fine in other dell machines. I tried everything and dell told me to get the motherboard changed.
  • 788 Answers
Try charging the battery on one of the other dell's.
If the unit runs for any lengh of time, it is not the motherboard.
It could be the A/C adaptor jack on the side of the unit.
Log a complaint will dell's customer care.
Posted on Sep 28, 2009
Dell inspiron 1520 won't turn on. battery indicator light at right sidr of laptop blinking blue
I would like you to try this step
1.Remove the battery and try to turn on again.
Update us with more information of this.
thanks
Feb 22, 2015 | Dell Inspiron 1520...
Have a dell inspiron with original ac adapter and battery. i get error message saying that the AC adapter cannot be determined is not recognized by dell and need a dell 65W AC adapter. I have the...
The adapter could be faulty or has failed slightly and is below the operating limits. This means you probably need to replace the power adapter.
Nov 01, 2010 | Dell Inspiron 1501 Notebook
My Dell Inspiron 1525 is now around 4 years old and recently it has not been able to charge and only works when it is plugged in. Also when i start the laptop, it displays a message saying i need to...
As you say the system is 4 years old update the bios
your download link is here!
IMP. Be sure to plug in the battery and it should be charges above 10 % and the system should be connected to the mains power supply also ensure there will not be a power outage during the update process
this will resolve the issue 100 %
Dont forget to say thanks!
Aug 11, 2010 | Dell Inspiron 1525 Notebook
Charger not recognised
I believe this is a known problem, all you have to do is to Download and install the BIOS update on the support website support.dell.com . After installing the BIOS update and still the charger is not recognized, it only means the motherboard needs to be replaced as well as the ac adapter. If you are still covered by the warranty, call dell tech support and they will replace the motherboard and ac adapter.
Hope this helps.
Jan 16, 2010 | Dell Inspiron 1501 Notebook
I had the battery not recognized on boot up. then
the Dell AC adapter has a sensing pin so the bios can determine the wattage of the adapter. If the system cannot ID the adapter, the battery charger circuit is disabled. You'll need a functional DELL ac adapter to get the battery to charge
Sep 26, 2009 | Dell Inspiron 1501 Notebook
I have dell inspiron 6400, Suddenly system doesn't recognize my genuine Dell 65W power suply which was working for 3 years
Please open Bios by pressing F2. If in Power settings it shows the ac type unknown ur system board needs replacement. If it is showing ac type none then the ac adapter needs to be replaced
Jul 16, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 1526 cannot communicate with battery
The diagnostic Error is a False positive you can ignore the diag error as the LCD is functional. If the battery is not recognized in the BIOS or you get an warning the AC adapter is not recognized, then you may have either a damaged AC adapter sensing pin (Fine wire in middle of ac adapter connection to Laptop) or a problem with the charging unit on the motherboard.
If the sensing pin is damaged or the ac adpater is not sending the right signal to the system, the battery charger will not work. SO if you have another Dell D series AC adapter, you can try it 1st. If the battery is 18 mos to 2 years old, you might see if it is IDs in BIOS and if it indicates battery state. Also the battery should have a test button and 5 LEDs on it. If the 1st 3rd and 5th LED flash the battery is bad. ANy any come on solid, then it is a % of charge, each LED = 20%
If you end up replacing hardware, then it will most likely be in this order:
AC Adapter, Battery, Motherboard
Jun 04, 2009 | Dell Inspiron 6400 Notebook
I have a dell inspiron 1520 that is 15 months old doesn't go on
Generally, if the AC adapter for the system's LED goes out when connected to the system, check the battery and see if it is holding a a charge (Press the button next to the LEDs on the battery see if all 5 light up)  If the battery still has power, then most likely there is a failure of the motherboard.
If you can, try another Dell D-series AC adapter and see if the same thing occurs.  If the system powers on, replace the AC adapter, if not it is a motherboard.
May 19, 2009 | Dell Computers & Internet
Dell Inspiron 6400 Notebook Logo
336 people viewed this question
Alun Cox
