Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
Whirlpool duet will start washing but then stops and displays 02 then f.
  • 48 Answers
It means your washer isnt pumping out the water...check the drain filter for a clog or an object in it if this doesnt do it call for service there is nothing you can do to fix it
Posted on Sep 28, 2009
Washing machine stop and start flashing o2f
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later
the F/02 error code will be displayed.
Potential Causes • Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is
running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
Feb 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Tip
WHIRLPOOL Duet & Duet HT washing machine shows F/02 error code on display?
This error is shown on the display due to:--
Drain time exceeding more then 8 minutes, the water valves will stop functioning and the the water valves turns off and "F/02" will be displayed on the screen.
NOTE: in some cases it has been noticed that 4 minutes the "Suds" error displays, and then 4 minutes later the F02 error displays.
This Will Help.Good Luck.
on Mar 11, 2010 | Washing Machines
02 F message that comes on after I start a load?
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Thank you !!
Jul 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F02 Error message
57f1973.jpgUse a nutdriver (1/4th in) to get that bottom panel off.001354b.jpgaab6887.jpg
Jul 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer starts wash cycle and runs for about 5 mins then stops and displays F 02 on the clock
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Whirlpool GHW9300 Duet Washer
F-02 error code on whirlpool front loader duet
F/02 Long Drain
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F02 keeps showing on display
If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
Cause: wrong detergent, too much of the right detergent, detergent placed in wrong compartment.
Feb 18, 2010 | Whirlpool GHW9400 Duet Washer
F 02 STARTS FLASHING WHAT CAN I DO TO STOP
i believe that is the code for slow drain condition.pump may need to be cleaned
Jan 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hello- I have a front loading whirlpool duet washer. I am not sure of the model number BUT.... it fills and begins its cycle and after awhile it starts to make a low grinding/crunching type noise. It...
F/02 Long Drain
Jan 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is F 2???
This is what the code F2 means for whirlpool duet washer.
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is
flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later
Potential Causes
running.
Mar 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
46 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
