How do I get the motel lock off an NEC multisystem N-4880?
  • kirstygregso Sep 28, 2009
    I am far from impressed with this response. I own the hotel it is called Tuscany Wine Estate Resort in Pokolbin Australia. As I am the Hotel Manager Kirsty Gregson if I knew I wouldn't waste company $$$ I understand it is a simple use of a sequence of keys on the remote we are after. I hope there is an "expert" who works for fixya??? send the response to my work account if you like kirsty@tuscanywineestate.com.au regards Kirsty
    Hi will try on Wednesday when my maintenance man is back in 2 days time. I will get back to you then. Thank you Kirsty
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please try this procedure to unlock the tv--
  1. Turn on your TV.
  2. On the remote, press the Menu button. The Set-Up Menu appears.
  3. Scroll to the Key Lock function and set function to Off.
  4. Press the Exit button to exit.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 28, 2009
  • 395 Answers
To get the lock off look for the preset button, press and hold for 10 seconds. This should do the magic.
Good Luck
    Brigadier General:
  • 4,090 Answers
Hahahaha are you kidding me? You took a TV from a Motel?
If its coded you have buckleys and none unless you know the original code programmed by the Motel Owner..try giving them a call
Thanks for using FIXYA
  • dennis bullard Oct 07, 2009
    I wonder how impressed you would have been if we hadn't tested to see that this was a stolen set from a motel? We are asked for all types of codes to open anything from stolen GPS to safes. We have to be sure that those asking have a right to receive the information asked for.
    I trust the solution supplied worked for you.
I'm at a motel. The safe says E-bar even after I put my code in
E-bar means the door lock is jammed, use your clenched fist and after inputting the code to unlock hit the door of the safe all around the key pad as hard as you can, you will hear the rods moving and unlocking the door. Hope this helps. I know it works as I have done this in motels I've stayed in!
Feb 08, 2015 | motel6.com Computers & Internet
MNT TK NEAR FULL what should I do replace mnt tk or cleaning the tank?
maintenance tank problem Epson 4880
I have my Epson pro 4880 down for four weeks. The Maintenance tank is rejected by printer. I bought brand new waste tank sensor and chips still says: "NO MNT TNK" it also would let do media setting through Epson LFP remote panel at all. I need help of what may be wrong. please???
Nov 16, 2012 | Epson 4880 Stylus Pro InkJet Printer
I have an epson 4880 with an error reading "service req. 0001001d" How can I fix this
Service Request errors in the range 00010004 - 000101D are related to a carriage movement problem. In some instances like paper jams, the carriage locking tab may be partially pushed in, causing the carriage locking mechanism to put a drag on the carriage or lock the carriage completely. This will cause a carriage error. Make sure the carriage locking tab is pulled to the left. Then turn the printer's power off and release the carriage by pushing down on the cutter blade. Slide the carriage to the left and look for any paper that also may be restricting the carriage from moving freely.
00010004 CR Motor encoder check error 00010005 CR Motor out of step 00010006 CR Motor over current 00010007 CR Motor in-position time-out 0001000A CR axis detection error 0001000F CR Motor PWM output faulty 0001001D CR servo parameter error
The T-Fence may also be dirty or out of the carriage encoder. Check to make sure it is clean and in the center of the encoder. Contact Epson for additional assistance.
May 09, 2011 | Epson 4880 Stylus Pro InkJet Printer
How do i enter codes
You can download the manual for the URC-4880 at http://www.retrevo.com/support/One-for-All-URC-4880-Universal-Remotes-manual/id/18524ag425/t/2/
Let me know if you have any more questions. Thanks.
Apr 05, 2011 | One For All URC-4880 Remote Control
Is Delta Luv Crib 4980 built 12/3/03 on recall list
Hello Shohola107,
I found this recall list. I did see your model listed. Here is the list.
Delta cribs manufactured in Taiwan or Indonesia, with the “Crib Trigger Lock with Safety Peg” drop side hardware design, numbers:
4320, 4340, 4500, 4520, 4530, 4532, 4540, 4542, 4550, 4551, 4580, 4600, 4620, 4624 (production dates 01/06 thru 11/07), 4640, 4660, 4720, 4735, 4742, 4750 (production dates 01/95 thru 12/00), 4760 4770, 4780, 4790, 4820, 4840, 4850, 4860, 4880, 4890, 4892, 4900, 4910, 4920, 4925-2, 4925-6, 4930, 4940, 4943, 4944, 4947, 4948, 4949, 4950, 4958, 4963, 4968, 4969, 4980.
Delta drop side cribs manufactured in China through 2005, with the “Crib Trigger Lock with Spring Peg” drop side hardware design, numbers:
4340, 4343, 4520, 4600, 4620, 4624, 4625, 4629, 4660, 4665, 4720, 4750, 4751, 4850, 4855, 4857, 4880, 4920, 4925-2, 4925-2B, 4925-6, 4980, and 8605.
You can also check out this website. http://www.deltacribrecall.com/recalled_products.asp
Thank you
May 01, 2010 | Delta Luv Jasmine 4852 Crib
Need TV code for URC 4881
Here you can find the manual/codes for URC 4880. I would expect the same codes for 4880 and 4881 models.
http://www.oneforall-na.com/archived.php
Jul 07, 2009 | One For All URC-4880 Remote Control
Firstly i do not have a projection tv problem
I've searched everywhere for any info in regards to your TVs but nothing comes up. It appears that those monitors or TVs were somehow just modified to work with the motel setup. You can try to use them with an external tuner such as a VCR to tune the channels to send the video signal to the TV.
What other type of connectors dod you have at the back?
Is there a way you can post a picture of the back of your TV?
Jul 28, 2008 | Televison & Video
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
