Question about Epson Stylus CX7800 All-In-One InkJet Printer
Printer is giving "Cannot find a document" error for slides
I'm trying to scan in slides. I have been able to scan in 2 sets (8 sildes total), but when I attempt the 3 set of slides it gives me the following error.
"Cannot find a document."
Why would this be happening?
Same thing happening to me. Called Epson they said it is a hardware problem and that I could send it to one of their service centers to repair it. It would probably cost more to do this then buy a new one.
Posted on May 28, 2011
What is the error 017-988 for phaser 6128mfp
It's a scan from PC error. Most common problem is that the destination folder for scan does not exist. Does it give that error on just a plain text document as well? It could be the document type and settings. Hardware wise could also be a main board issue.
Oct 20, 2014 | Xerox Phaser 6128MFP AllInOne Laser...
How do i scan a legal size document?
Your Lexmark scanner may not be able to scan legal size documents (8-1/2 x 14)
Sep 18, 2012 | Lexmark X6650 4-In-One Wireless InkJet...
Can I scan multiple pages to a PDF?
1. Open the HP Solution Center 2. Click Scan Document 3. Document to PDF File 4. Change Settings 5. Save to File Save Options 6. Make sure One file per scanned page is not checked. 7. Click, OK > Scan 8. Ofter first page is scanned, position next page on scanner, then click Add Page. 9. Keep doing step 8 until all pages scanned. 10. Click Finish.
Apr 01, 2010 | HP Photosmart Premium C309A All-In-One...
The drop down menu does not give the option to have the picture scanned/saved jpg format which is necessary for certain sites such as shutterfly
Please follow the steps below to scan and save a Multi-Page PDF with Epson Scan.
1. Launch Epson Scan from your START, (ALL) PROGRAMS, EPSON SCAN.
2. If prompted, select your scanner model. Epson Scan will now launch.
3. Click the drop down arrow next to SCAN, select FILE SAVE SETTINGS.
4. Select PDF for IMAGE format. Click OK.
5. Click SCAN. Click OK to proceed (if prompted).
6. Once the image has scanned you will be prompted to click ADD PAGE or DONE.
7. Click ADD PAGE to scan more documents.
8. Once you have scanned all your documents, click DONE.
9. Your documents will now appear in the EDITING PAGE window. Click OK.
10. The multi-page PDF is now created.
Jan 16, 2010 | Epson Perfection 4490 Photo Scanner...
Printer will not kick out document automatically, attention lite keeps flashing. tray 2 selected but always defaults back to tray 1
Sounds like you have a mismatch in the paper you are trying to print on and the paper that is loaded in the printer. HP printers look to feed paper from tray 1 anytime the computer settings don't match the paper loaded in tray 2. Tray 1 is the multi purpose tray and prety much any size paper can be loaded in tray 1. Double check your document settings and double check the paper size loaded in the paper tray 2 and make sure they match. Also try printing a different document to see if the error persists. If it does this on everything you try to print you should also double check teh rear guide in the paper tray. There is a rear guide in paper tray 2. If it slides back too far it will make the printer think that paper longer than 8 1/2 x 11 is loaded. Push the paper all the way forward in the tray and push the rear guide until it is snug with the tail end of the paper stack.
Nov 01, 2009 | HP LaserJet 4700 Printer
I have hp officejet 6110 all- in- one and cannot scan page of text into my computer. Printer gives message "Scanning error. Cannot connect to computer."
If you have updated to Internet Explorer 7 or 8, the HP Director program won't work correctly without the update patch from HP Support. Go to HP Support, put in the model number of the device and search for drivers. Look for a special driver or patch for Internet Explorer and download and install. This will allow the HP director to run from the desktop. Once it is started you should restart your printer and make sure it is connected with a USB, or if it is connected directly to the router for your home network, you should uninstall the printer, then reinstall the printer and see if the computer sees it this time with the new driver on the hard drive. Once it installs, see if the HP Director can be started from the desktop and choose scan document, It will ask what you want to scan and where do you want to scan it to. Click document or picture...I have mine set up to scan text documents as PDF's and Pictures as JPGs. I then set it to "Save to file" when the scanning is done, whether it is one file or many, the director will then ask what folder you want to save the files to. That's all there is to it. Good Luck, ParrotHead PC Repair
Sep 08, 2009 | Computers & Internet
Scanning a legal size document
Move the document feeder front guide towards the rear of input tray, line up with 8 1/2" marking. This should inform the machine to register for 8 1/2 x 11 or 8 1/2 x 14 originals>fed lengthwise.
Jun 01, 2009 | Canon iR 2022i Printer
Connection issue between XP Pro and HP C6180 all-in-one
Hi Lynn,
Unfortunately, HP.com doesn't have a very satisfying online solution to your problem. Still, there are a few things you can try.
The first is a general diagnostic check of your scanner. HP provides a doc that takes you through some steps, many of which you probably already tried, to see if it's a simple fix:
An error occurred while communicating with scanning device
The next document is a set of diagnostic steps to address errors trying to scan to a PDF:
An error occurred while trying to scan to a PDF
I don't know if the current situation was created by a fault in the device or some recent change in your configuration settings. I do know you can use the HP Director software installed on your computer to set the scan destination settings:
Settting "Scan To" Destination using HP Director
Those were the most relevant solutions I could find for you. I hope some of this information is helpful. Good luck.
-Trip
Oct 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
Scanning Legal Sized Documents
1. From the MP Navigator screen, select "Scan with Scanner Driver" in lower left corner.
2. When in ScanGear MP, select the Advanced Mode tab
3. At Input Settings, select Document (ADF) for document type
4. Set paper size in next window
5. Click Scan button at bottom
May 01, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Epson Stylus CX7800 All-In-One InkJet Printer Logo
51 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
