I had the computer reset to factory settings and cannot play CD's now. I get a message that says "You don't have a disc drive capable of playing DVD's or CD's. See less
    President:
  • 2,185 Answers
Do you see the CDrom drive from the Device Manager? Right click on My Computer and click Manage. Click Device Manager and on the right panel, expand the DVD/CDROM drives. Check if your cdrom is on the list. If you can see it, try to right click that and Update the driver. You will need to have the installation disk for your cdrom.
If you dont have an installation disk, try to right click it and choose uninstall the drive. Next, you reboot the computer. The system should rediscover the drive.
If this does not work, please let me know.
Posted on Sep 28, 2009
Why won't a CD-RW disc play in my car CD player?
Some of the older cd players, car or otherwise, just aren't capable of recognizing CD-RW's. The player in my 10 year old Ford Mondeo doesn't, but the updated model player in the newer Mondeo does play CD-RW's.
Aug 25, 2012 | Memorex 700MB CD-RW 80 Media (50-pack...
I have a RDS stereo and it won't play my cd's. It says player error
RESET YOUR PLAYER AT DEFAULT SETTINGS. SWITCH IT OFF. SWITCH IT ON AND INSERT CD. GIVE THE PLAYER TIME TO READ. DON'T PRESS ANY BUTTONS TILL IT COMPLETE IT'S READING. IT WILL PLAY THE CD.
ALSO CHECK CD'S ARE BRANDED AND NOT COPY FROM COMPUTER. FEW COMPUTER WRITE CD NOT HAVE AUTO PLAY OPTION.
IF PROBLEM NOT SOLVE PLEASE INTIMATE.
Oct 07, 2011 | 2002 Buick Rendezvous
I purchased chessmaster 10th edition and installed to computer when i hit the play button for startup it asks to insert disc 1 i would like to know why this is required when the program is installed ...
i am sorry to give u bad news, game CM is game that need disc to run the game because a lot of stuff that still need to run the program left behind in the disc. it was factory setting.
But u can use alternative way by make the disc to image then run it with daemon tool.
first u need program that can make image file like .iso, .nrg, etc. ( i use nero)
make an image file from CD 1 and CD 2 and save it in computer.
second install program that can make image drive to run image disc (i use daemon tool).
make one image drive then mount the image disc to the drive.
now u can play without real disc. (after finished play the game unmount the image disc)
hope this helpful
Feb 15, 2011 | Ubi Soft Computers & Internet
JLMS DVD-ROM XJ-HD166 DVD/CD ROM Drive does not acknowledge disc in drive after having the computer set back to factory
Does it not acknowledge dvd disc only or cd or dvd both. If it doesn't read the dvd disc, or able to play dvd disc, but able to exlpore regular cd's, then you have a codec error, and you need to download a dvd codec like powerdvd for it for your system to play dvd disc. Check to see if your dvd-rom drive appears in the "my computer" window, if it is there, but wouldn't be able to play anything, then it could be a driver issue. so make sure in the hardware , the drivers is installed and working properly. If it is working properly and driver is installed, then you got a bad drive, the optical laser lenses isnt reading or the spindle ain't working anymore if you don't hear disc being loaded when inserting the disc.
Jan 30, 2011 | Lite On XJ-HD166S Internal DVD Drive
Can lite-on-ltn4865 48x play dvd movies
If your Drive is a CD-Rome drive, surely it cant, for the drive cant read dvd disc. Replace the drive of yours with DVD-Rom or DVD-RW in order to play dvd disc, DVD-RW simply has the added capablity to burn on DVD discs
Jan 12, 2011 | Lite On (LTN486S) Internal 48x CD-ROM...
Cannot play newer blu ray discs and now cannot play cd's. "This disc can not be played" error message
power off your dvd, disconnect the plug from the power source and then reconnect it again. Power on the unit again and try to resume normal operation. If it cannot still play a dvd much less a cd, then you need to have it repaired. At the most, the flex needs to be replaced or your lens is damaged in which case it needs replacement. Try also locating for a reset button on your unit. Just press the reset button if there is one on your dvd player for about 5 seconds to restore it to its original factory setting
Dec 19, 2010 | Samsung BD-P1600 Blu-ray Disc Player
Rover 25 CD player wont play MP3 format discs
It sounds like your Rover dosn't have MP3 capabilities. You will have to use standard audio CD format (not data/MP3 format). You will only be able to burn about 15-20 songs but they will play in any cd player.
Aug 07, 2009 | Car Audio & Video
Problems with D drive
Sounds like your D: drive isn't a DVD-ROM drive.
Have you been able to run DVDs from that drive before?
- If not, then you probably have a standard CD-ROM or CD-RW drive, which is not capable of reading from a DVD. You would have to purchase a DVD-ROM drive in order to play or copy anything from a DVD.
- If you have, let me know so I can help you further.
Feb 25, 2008 | Computers & Internet
How do i bypass the parking brake switch in order for my video to play
1. FACTORY RESET METHOD (Temporary)
(This isn't the most effective, but it is the easiest to try, so it's worth a shot since it apparently works on some units.)
** Go to the Menu
** Get to the Settings Menu
** Select <yes> to Reset to Factory Settings.
Credit: DKA
2. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press STOP twice on remote
** Enter 26604 on remote
** Press ENTER
** Take out Audio CD and Insert a DVD
Credit: Myself via a DUAL Tech
3. DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Enter 26604
** Press ENTER
Credit: Adam P.
Feb 18, 2008 | Dual XDVD8181 Car Video Player
LG RH277H - won't play bought DVD'S
The cd tray eject after put in the DVD movies, but VCD working fine...it is means that the drive's region code haven't set yet .(please refer to user manual to setting the region code) ..or unplug the recorder drive from the dvd player,using the computer setting to change the region code by connecting to computer's IDE cable .
Oct 19, 2007 | LG RH177 DVD Recorder/HDD Recorder
42 people viewed this question
k24674
jasbo
jasbo
