Question about Dryers
Relay buzzing sound,drum won't start unless you press start repeatedly.
  • 909 Answers
Check either the relay on the board to start with or check the starting capacitor.
Posted on Sep 28, 2009
Testimonial: "Thanks I will test the relay in the morning!"
Kenmore model # 86470810 buzzes when I press start but won't run
The motors centrifugal switch may be stuck. Try having someone start it while pressing in the door switch while you rotate the drum with your hand by grabbing one of the drum vanes. I don't know which direction your drum rotates. Try both. This may start the drum turning on its own and resetting the switch
Sep 21, 2011 | Kenmore Dryers
My dryer makes a buzzing noise when i try to turn it on, but it won't turn on at all. What could the issue be?
The motors centrifugal switch may be stuck. Try having someone start it while pressing in the door switch while you rotate the drum with your hand by grabbing one of the drum vanes. I don't know which direction your drum rotates. Try both. This may start the drum turning on its own and resetting the switch.
Sep 20, 2011 | Kenmore 62722 Electric Dryer
WON'T START,BUZZ SOUND WHEN I PUSH THE START BUTTON
Sounds like a bad battery or a bad starter relay. Take the battery out and take it to an automotive parts house. Ask them to load test the battery for you.
If the battery test good, reinstall it in the bike making sure your connections are good. Press the start switch and listen for the buzz. Look for the starter relay. It's a one inch plastic cube. When you find it, press the start button while holding the relay. Is this what is making the noise?
If all you feel out of the starter relay is a simply click, and the buzzing is coming from the starter, you're solenoid may need new contacts installed in it or your solenoid might be bad.
Good Luck
Steve
Aug 22, 2010 | 2004 Harley Davidson FXD - FXDI Dyna Super...
AC unit with ''test'' plug; test shows ''green'', but AC doesn't work
Hi, and no this buzzing is not normal. If the test button does not trip, its not to major. It sounds as though you have a relay, fan, compressor, or some other relay that has worn contacts that buzz when power is put to it. If the unit operates and its not to the point it is driving you insane, you can take it apart to locate which relay is the noise one and replace it if you have the skills to tackle it. If it fails completely, not knowing the sequence of operation unless you can read a ladder schematic, you will have problems locating the one that was buzzing. I would remove the front cover if its a wall or window unit to find the control section and locate this buzzing relay to replace it.
Best of Luck to you,
Shastalaker7
Jun 05, 2010 | Heating & Cooling
Buzzing sound
sounds lkke a badcompressor, the overlaod relay is "buzzing trying to start the compressor. if unider 5 years it should be coverd under manufactures warr.
Jan 11, 2009 | Frigidaire FRS3R5EMB Side by Side...
I hear a buzz sound for 5 seconds when compressor starts.
The grommet simply holds the start relay in place.  Unless it is torn, you won't need it.  Likely the start relay.  The buzzing is possibly the relay contacts on the start relay burning if the problem occurs when the compressor starts...although it could be the compressor making noise as well.  You might try to "hear it out".  The start relay gives a boost to the compressor by adding in another winding inside to 'kick' the compressor.
If all you hear is the buzz, you might just wait a bit to see what fails!
Nov 14, 2008 | Refrigerators
Amana Dryer won't start
Depending on your interpretation of the 'buzzing' sound compared to mine, I'd say it may be a relay chattering or the motor trying to start up but the windings are beginning to fail. You may want to clean the motor housing from dust etc and make sure that you do that with the power disconnected. Also: with no clothes in teh dryer..try rotating it around and feel for any spots in that rotation that may be binding.. if the drum has excessive restriction while rotating.. the motor may not have enough torque to overcome that and just buzz,,, Hope that helps...
Aug 14, 2008 | Dryers
Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Sep 17, 2007 | Estate EED4300SQ Dryer
Dryers Logo
115 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
