Question about RTO 110cc Basic Manual ATV # ATD-125C
How can you bypass the starter solonoid on a 110cc pocket bike
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 78 Answers
Just use a screwdriver and wedge it between the two big terminals on the relay to make contact to each other and the motor will turn over. You can also run a jumper wire from the positive terminal of your battery to the terminal on the starter motor and it will crank.
Posted on Jan 05, 2015
  • 4 Answers
Set a battery charger to around 13 or 14 volts. Ground it to frame. Make positive charge contact with starter where harness directly attaches to starter. That will crank up the starter.
Posted on Dec 08, 2009
Hyosung 650 aquila starter solonoid
For Every starter motor there is a Relay check the relay near the battery for he starter motor/ Change
Apr 27, 2014 | Hyosung GV 650 Aquila Motorcycles
Pocket bike
Of course you can, but it will cause fuses to blow or even burn out the wiring, A solenoid is there to switch the power to the starter motor which is the only high current item on your bike. Just replace the Solenoid.
May 19, 2013 | Motorcycles
660 raptor wont start
If when you hit the button you here a solid knock followed by nothing it is quiet likely that it is the starter solonoid try tapping the solonoid lightly whilst pushing the starter button if this frees the starter I suggestyou remove both the starter &solonoid strip & thorougly clean them both N.B use only electrical contact cleaner or white spirit for this most other products will leave an oily film not condusive to good conductivity.If the problem continues to reoccure & free up with tapping the solonoid its a safe bet the solonoid is about to turn its toes up for good these thing can only be resurected so many times hopefully its just dirty & all it will cost you is time
Feb 26, 2010 | 2004 Yamaha XT 660 R
Need to install a starte solonoid in a 1982 yahamaha XS400R
hi if you follow the wire from the starter motor it will lead you to wear the solonoid goes
ther should be two large wires one from the battery then one fron the starter then ther will be two smaller wires that operate the solonoid
Jun 20, 2009 | 1982 Yamaha XS 400
110cc pocket bike carberator
That tube would be the overflow tube. Your carb float is sticking open and allowing fuel to flow in constantly. You need to take carb apart, clean needle valve, and inspect or replace carb float.
Apr 21, 2009 | Pit SSR 110CC Pro Beginner Bike
Starting issues
when he tries to start it the starter solonoid clicks but the starter never spins. After this happens the starter solonoid will not even click again until after the starter lead wire is disconnected from the starter. Even after trying to bypass the starter solonoid and connecting the starter straight to power it won't spin. This happened a few months back while on vacation and we replaced the starter after trucking the bike back home and all worked well for several months. He rode the bike to work on Wednesday with no problems. Went to start it Thursdy morning and nothing. Looked at all he can think of last night (starter switch, neutral switch, solonoid, etc) and can't figure out what is going on. Does anyone have an idea what could be going on here?,Electricity is one of those areas that seems to baffle most folks. But it is LAZY and only does what is commanded of it. Whether it gets commands through engineered protocol or from a short or ground failure. Try to follow the sequence of events as designed by Ducati. And solve through process of elimination. As I read your TS you have applied 12vdc directly to the starter + stud with no results. To me that would suggest open segments on the starter armerature. Try removing the starter and Bench testing it directly with 12 vdc. If it does not respond then try rotating the drive gear a little and reapply power. If it spools up after rotating then you have an open and need a replacement starter. PS I don't want to sound condescending but be sure to supply a ground from the starter housing to the 12v source - terminal. If the starter checks out GOOD then start back tracking to the Solenoid and ensure it is operating properly and so on all the way back to the handlebar switch. You can also check for an OPEN on the armerature with an OHMETER connected to the + stud and the housing. Then slowly rotate the drive gear from segment to segment and look for Infinity readings. There are also carbon brushes that transfer the power to the armerature segments and sometimes they wear out/fail. They usually have a braided copper pigtails to pass the current to the core. This is all stuff you can do to minimize the 90$/HR troubleshooting expenses at the dealer. Let us know what you find,,,
Nov 10, 2008 | 2001 Ducati Monster S4
RTO 110cc Basic Manual ATV  # ATD-125C Logo
625 people viewed this question
Top RTO Cycling Experts
Michial Gueffroy
Lloyd Carter
Gregg Mahin
Gregg Mahin
Are you a RTO Cycling Expert? Answer questions, earn points and help others
