Question about Linksys Wireless-G WRT54G Router
I don't remember router user name or password, but I need to access the router. How can I do this?
  • Linksys Master
  • 32,281 Answers
You can reset the LinkSys back to the factory default by :-
Powering the router and pressing the RESET button with a sharp object for 30 secs.
Open your browser and enter the URL IP configuration address
The default Login is admin and the PW is admin.
Posted on Sep 28, 2009
5 Suggested Answers
drlalitv
  • 488 Answers
SOURCE: forgot user name and password
please try admin as username and press enter keeping password blank..or try admin and admin..i hope it helps..
otheriwse u may have to reset the router by pressing for 10 seconds on the reset button on the back or bottom of the device..
hope it helps!
Posted on Nov 02, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: I can't remember my user name and password to my router
You will need to reset the router. On the back of the router hold down the reset button for 30 seconds release the button and then wait for the power light to stop blinking. If it doesnt stop blinking within 1 minute unplug and wait 30 seconds plug back in and the router will be reset
Posted on Feb 15, 2009
  • 523 Answers
SOURCE: Router locked. Cant remember the password.. User "root"
The only solution for u to login in to the router is to reset the router.
1.If you forgot your password, you must reset your router. Unfortunately this process will change all your settings back to the factory defaults.
2.To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process.
3.Wait about 30 seconds to access the router.
4The default IP address is 192.168.1.1. When logging in, type in the default User Name “admin,” and the
default Password “admin” then click on the OK button to access the web-based manager.
Regards,
Ayyasam
Posted on May 29, 2009
niquose
  • 198 Answers
SOURCE: forgot the password on the surfboard router
Here are the default settings:
In the User ID field, type admin (case sensitive) and press TAB.
In the Password field, type motorola (case sensitive) and click Log In
Posted on Jul 24, 2009
I WANT TO LOGIN TO MY ROUTER,AND IT ASK FOR MY USER NAME AND PASSWORD.BUT I DON'T SEEM TO NO IT.WHAT CAN I DO? THANKS DEAN.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Sep 10, 2011 | D-Link D Link Dir615 Wireless Router...
I have lost the security code and have a new laptop, how do i set it up to work
Hi!
If you don't remeber the wireless security code, maybe you still remeber the user and password to access the web management interface of the router.
Then you have to connect the laptop to the router by using a network cable. Open a browser window, type in the IP adress of your router and check the wireless setup section. There you can find / modify the wifi security code.
If you don't know the router's IP adress, then open on your computer a ms-dos prompt and type the command
ipconfig /all
it will display your current IP adress, subnet mask and GATEWAY. The gateway adress is the router's IP adress that must be typed into the browser.
If you don't remember the user and password for accessing the router's web interface, please refer to the router's user manual in order to reset it to factory default configuration, and then proceed as for the first installation of the router.
Hope it helped,
Bogdan
Aug 30, 2011 | Belkin (F5D8231-4) Wireless Router...
I had someone set up my new NetGear Router, but the said the User name was blank and gave me the password, but I can't access the intranet settings without a use name. Can I reset this myself? I...
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Jul 16, 2011 | NetGear WGR614 Wireless Router
Enter password, i don't know the password.
Jun 18, 2011 | Computers & Internet
I don't remember my network key,so I cannot use it
Try to connect you computer with an Ethernet cord. If the Internet is working check the default gateway of the computer by typing "ipconfig" on the command prompt. Type the default gateway on the address bar. There you will see the login page for your wireless router. Check the default username and password from the router's manual and enter it. If it accept the user name and password, look for the wireless settings, password should be seen there. If not create a new one. If default user name and password doesn't work reset the router. There should be a reset button or pinhole on the back of the router. Press and hold it for 10seconds. Try again typing the default gateway on the address bar then re enter the default user name and password. If it work your router now do not have a network key (unsecured). You can create a new network key on the router's configuration page.
May 21, 2011 | Computers & Internet
Can't remember my user name or password
You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. .Click on wireless and enabled it. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Feb 16, 2011 | Computers & Internet
How do I find my security key for a D-Link DIR-625 router?
You will need to log into the router's web page to view the security settings and access your security key. The default IP address of D-Link routers is normally 192.168.1.1; simply input this IP address into the address bar of your web browser.
You will be brought to a D-Link page and be prompted for your user name and password. If you have not made any changes then the default password should be admin. If you changed the user name and password simply enter them here.
You will need to click on the "setup" tab found at the top of the page. Now you will need to click on "setup wireless" or "Wireless settings" to access the manual configuration. Now you will be able to locate the security key.
If you are unable to locate any of these or you have changed the user name and/or password and no longer remember what they are, you will need to reset the router and set up your wireless network from scratch.
Thanks,
Pat
Nov 07, 2010 | D-Link DIR-625 (790069292637) Wireless...
D-link dir-628. I can't remember my user password. I need to
the only way I know to go about changing a password after its been established on the admin account is to restore the modem or router to its factory defaults using the reset button usually about the size of a pin on the rear of its case
Hope this helps
Be sure to leave feedback
thanx
Robb
Apr 02, 2010 | D-Link DIR-625 (790069292637) Wireless...
Regards,
Ayyasam
May 29, 2009 | Buffalo Technology WHR-G54S Wireless...
Wireless Router
no u need to reset the box again like turn on the device and press and hold reset for atleast 40 seconds and check while u doing this the lights should blinks>and reboot and check
Oct 09, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
Linksys Wireless-G WRT54G Router Logo
521 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
