Question about Microsoft Excel for PC
Additional worksheets How would I add additional worksheets on a particular file
  • 39 Answers
Open the file
right click in the workseets (right bottom at the screen)
Choose new worksheet
Let me know if i could help you
Posted on Dec 18, 2007
How do I pull a figure from a spread sheet and add it to another in the same file.....
Are you talking about different worksheets in the same file.
go to the other worksheet then go to the particular cell and press = on keyboard
then use mouse to select the other worksheet from the bottom of the spreadsheet .
Then click on the cell you wish to link and press enter key on keyboard.
You can also do this to spreadsheets with different file names by opening both spread sheets in different windows and switching between the windows.
you can also copy just the data by copy whole sheet (click on the square in top left hand and copy and then right click paste special on new worksheet - with values only rather than the original formulas from the spreadsheet
Jan 06, 2017 | The Computers & Internet
Answers to prblems 11.5 worksheet
Many worksheets have been written throughout history, all around the world. There is no way we can tell you anything about a particular worksheet without knowing which worksheet you're asking about.
May 12, 2014 | Office Equipment & Supplies
Describe the each part of microsoft excel 2207
Parts of the Excel 2007 Screen
Active Cell In an Excel 2007 worksheet, the cell with the black outline. Data is always entered into the active cell.
Column Letter Columns run vertically on a worksheet and each one is identified by a letter in the column header.
Formula Bar Located above the worksheet, this area displays the contents of the active cell. It can also be used for entering or editing data and formulas.
Name Box Located next to the formula bar, the Name Box displays the cell reference or the name of the active cell.
Row Number Rows run horizontally in an Excel 2007 worksheet and are identified by a number in therow header.
Sheet Tab Switching between worksheets in an Excel 2007 file is done by clicking on the sheet tab at the bottom of the screen.
Quick Access Toolbar This customizable toolbar allows you to add frequently used commands. Click on the down arrow at the end of the toolbar to display the toolbar's options.
Office Button Clicking on the Office Button displays a drop down menu containing a number of options, such as open, save, and print. The options in the Office Button menu are very similar to those found under the File menu in previous versions of Excel.
Ribbon The Ribbon is the strip of buttons and icons located above the work area in Excel 2007. The Ribbon replaces the menus and toolbars found in earlier versions of Excel.
Here are the main parts of Microsoft Excel 2007. Thank you for using Fixya !!!
Nov 15, 2010 | Microsoft Windows XP Professional
How many charts can put in a sheet?
In Microsoft Excel 2003 for PC, you may add at least 32 charts as as objects into a worksheet (as illustrated above), however it appears that you may add as many charts as you wish into a worksheet using this method .
Dec 10, 2009 | Microsoft Excel 2003 (06503995)
When i open remote management showing a error message''error:1004'' please help me to solve this problem.
his problem can occur when you give the workbook a defined name and then copy the worksheet several times without first saving and closing the workbook, as in the following sample code: Sub CopySheetTest() Dim iTemp As Integer Dim oBook As Workbook Dim iCounter As Integer ' Create a new blank workbook: iTemp = Application.SheetsInNewWorkbook Application.SheetsInNewWorkbook = 1 Set oBook = Application.Workbooks.Add Application.SheetsInNewWorkbook = iTemp ' Add a defined name to the workbook ' that RefersTo a range: oBook.Names.Add Name:="tempRange", _ RefersTo:="=Sheet1!$A$1" ' Save the workbook: oBook.SaveAs "c:\test2.xls" ' Copy the sheet in a loop. Eventually, ' you get error 1004: Copy Method of ' Worksheet class failed. For iCounter = 1 To 275 oBook.Worksheets(1).Copy After:=oBook.Worksheets(1) Next End Sub
Nov 18, 2009 | Computers & Internet
How can enable mail recipient as attachment excel
Apr 11, 2009 | Microsoft Office Excel 2003 for PC
Try this:
1. Find the copy of the workbook on which you will merge the changes. In Excel, go to "File > Open" and find the file.
3. Click "Tools > Compare" and "Merge Workbooks." 4. Look for the files you want to merge and add them into the current file. 5. Click “OK” to merge the files. This is your master copy of this workbook. 6. Save the file.
Dec 21, 2008 | Microsoft OFFICE 2003 BASIC OEM ENGLISH MS...
LINE 100
If Sale Line 100 is an Excel Template then it is simple.
The Templates are just preformatted spreadsheets which are edited just like any other spreadsheet.
If you mean that you are using the Template to create another document but wanting all the fields to be the same as the Invoice then I suggest the following method:
Copy the Template fron Worksheet 1 onto Worksheet 2.
Add and remove any fields that you wnt to add or remove (Prices would be deleted on this copy and the title would be changed from Invoice to Delivery Docket, etc)
Then (on Worksheet 2) in the fields that you want to be the same - click on the cell you want the same Data in and hit the = sign. Then go to Worksheet 1 and Click on the cell that you want the data to be the same. Hit Enter. This will send you back to Worksheet 2 and you will see that any data entered into the cell in Worksheet 1 will now also appear in Worksheet 2.
Repeat this process for all the cells you want copied from worksheet 1.
When you complete the data in Worksheet 1 (the Invoice) all the data selected will automatically appear in the cells selected on Worksheet 2.
Try this on worksheet 2 select cell A1, type =, then open worksheet 1 and select B1. You will be returned to worksheet 2 and the formula in cell A1 will now read =Sheet1!A1. Enter anything into Shhet 1 A1 and you will see that it appears in the appropriate cell on Sheet 2.
When you want to print off the Invoice and the Delivery Docket - you only have to open each Worksheet and hit Print and a copy of each worksheet will be printed giving you an Invoice and a Delivery Docket with the appropriate info on each printout (eg if you exclude prices from the Del. Docket then after completing all the details in the Invoice will create a Del Docket with all the relevant information other than the prices.
Does this answer your question?
Apr 25, 2008 | Computers & Internet
Microsoft Works Please help
Get new stuff you don't have to look through particularly grotty Half-Price Books (though you could use AbeBooks) to obtain relevant manuals! Linux and OpenOffice can do your job; OpenSolaris and one of Sun's office suites can too. Your machine won't be zombified every time you hit the internet with it this way, too.
Works and Excel differed in several editions. You might not be able to just rightclick on the tab and ask select New Worksheet or Edit/Insert/Worksheet.
Mar 20, 2008 | Microsoft Windows 95 NT 4.0 Workstation
Unsure of correct formula
You can add a reference from the worksheet 1 to all other worksheets
Is it OK?
Mar 08, 2008 | Microsoft Excel for PC
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
148 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
