Question about OEM Systems Car Audio & Video
How can I install 2 amplifiers to the original radio in a Chevy Silverado 2004? I need to know from which wires I have to take the power and the ground for those amps. I want to make the installation by myself. Thanks for your help.
  • 655 Answers
Hello alfonso_ordo,
Here's a link to the wiring color code for the 2004 Silverado. It appears that there is not a 12V+ switched lead in the factory wiring.
Anyway, you really should not take the power and ground directly from the OEM wiring. The wiring itself is not big enough to provide the current that will be drawn by an external amp. And the fuse will not support the additional current either. You'll end up with blown fuses and burnt wiring at a minimum, and perhaps other damage to the vehicle electrical system.
It's best to power external amps directly from the battery and ground them as close to the amps as possible. Here's a link to an excellent amp installation video: http://www.crutchfield.com/Learn/learningcenter/car/amplifiers_movie.html
Crutchfield also provides complete installation assistance, and lifetime technical support when you purchase from them. If you shop their "specials", their prices will be competitive.
If you are a first-time purchaser at Crutchfield you can get a $20 discount off a $200 order if you use a "friend referral code" such as mine, which is: p7sdj-hrx8q-9800g, plus free shipping. Oh!, I get a $20 merchandise credit too.
Hope this helps.
Posted on Sep 28, 2009
Get sound on radio install.
Your 2004 Vibe may have been equipped with a radio or a radio and separate amplifier. The BLU/WHT wire supplies +12 V to the radio. The radio ground wire is BRN. A GRY wire powers dial illumination. The BLK/WHT wire you mention is either the antenna input or a sensitivity control input to the amplifier. There also may have been a WHT mute control wire connected to the amplifier. The Vibe has an antenna amplifier which needs +12 v. The aftermarket radio should have separate LF, RF, LR, and RR outputs to connect to the corresponding speakers or amplifier inputs.
Sep 13, 2016 | Cars & Trucks
2004 chevy radio display quit working. The radio seems to work but flying blind. Any way to get the display lite up again?
There is a hot wire to the radio for the display, you need to check and see if it has power. If it does, then the display is bad and you should replace the whole radio.. Look on Ebay
Sep 09, 2016 | 2004 Chevrolet Silverado 1500
I need to know the wire diagram for my 04 Silverado crew cab. Previous owner removed the original stereo and put a horrible after market stereo. Now I want to replace that with a after market stereo can...
use a test light and a battery. the black is ground, orange is constant and yellow is your turn on and off (ignition). then take a 9volt battery to check your speaker wires. front should be green and light green and gray and light gray. double check it has ben a while, rear is blue and light blue, a yellow and brown. you do not need any other wires in the harness unless you are using a power antenna or amp which you can use the yellow wire for ignition. double check with test light and 9volt battery. the 9volt battery will make the speaker pop noise, you then know you have a speaker when it makes that noise.
Mar 28, 2015 | 2004 Chevrolet Silverado
I'm attempting to install a pioneer stereo into my son's 74 Chevy pickup.
it plugs in to the the plugs you unpluged from the original radio if there are no plugs then your going to have to wire it all up from scratch new power wires new speaker wires and just alot of work so I hope you didn't cut the plug off the old radio
Mar 21, 2013 | Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth...
I purchased a used Jensen UV10 from a friend and installed it in a 97 eclipse spyder. I recently bought a 2003 chevy silverado 1500hd LX, and took out the aftermarket JVC cd player to install my Jensen....
Depending on the model, the Silverado may have an amplifier between the OEM radio and the speakers. If that is the case, you will have to remove it and wire directly to the speakers. Check the wiring schematics for the original truck radio option (one source is Alldatadiy.com).
Jul 16, 2017 | Cars & Trucks
I have a 2007 chevy silverado classic an i dont
Buy the aftermarket harness for it. Within the harness there should be a wire that says power ant or remote. Splice a wire to that and run it back to your remote turn on.
Nov 17, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Need Radio wiring diagram 2004 chevy silverado 2500hd (oem plug)
Left Front Speaker(+) TAN ; Size: tab_tech.gif Left Front Speaker(-) GRAY ; Size: Right Front Speaker(+) L GREEN ; Size: Right Front Speaker(-) D GREEN ; Size: Left Rear Speaker(+) BROWN ; Size: Left Rear Speaker(-) YELLOW ; Size: Right Rear Speaker(+) BLUE ; Size: Right Rear Speaker(-) LT BLUE
Yellow -ignition
Orange-Constant +12 volts
Black - ground
If you need more info, please ask.
A rating is appreciated.
Jun 13, 2009 | Car Audio & Video
Installing CD player
here is the wiring schematic.
Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Right Window Trim Front Speakers 6 1/2" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 4" x 6" Side Pillar Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
And you will need a Wire harness... Metra #GMRC-LAN-01
And a mounting Kit Metra #99-3305
And antenna adapter Metra #40-cr10
This is for the basic radio... if you have upgrade NAV/Onstar/Premium sound.... there are different wiring harnesses available.
Let me know if you need more help.
Jan 08, 2009 | 2004 Chevrolet Silverado 2500HD
Car Audio & Video Logo
79 people viewed this question
Top OEM Systems Car Audio & Video Experts
xxxxxx xxx
miles
miles
SuperN0va
SuperN0va
Are you an OEM Systems Car Audio and Video Expert? Answer questions, earn points and help others
