Question about HP DeskJet 9650 InkJet Printer
I have 2 nearly identical Dell workstations, my HP Deskjet 9650 print fine from one but the prints come out shifted off the page on the other?
headstrong
  • 233 Answers
SOURCE: hp deskjet prints symbols/wingdings instead of text
sounds like a driver problem.
1. reboot your "Computer"
2. re-install driver
3. test print.
hope this helps
thanks for rating
Posted on Jan 14, 2008
SOURCE: HP Deskjet 6940 printer - printing but no ink transferred to page itself
I have the same issue, but with a HP DJ 3550, I´ve heard about the data execution protection (DEP) migth help when changing the options, but still have to try it
Posted on Jul 17, 2008
SOURCE: hp deskjet 990 cse won't stop printing, help!
you'll need to re install the printer drivers, clear out the print queue, and begin anew
www.hp.com has those drivers by model number and operating system
http://tinyurl.com/6qcpgy
Posted on Aug 19, 2008
  • 158 Answers
SOURCE: hp F4200 deskjet problem
Please follow the best option that are given :
1) Check all the cable.
2) Check you cartridge position and install it correctly.
3) Remove the old copy of your driver and try to download latest driver from http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-002&h_lang=en&h_cc=us&h_product=14438&h_client=S-A-R163-1&h_page=hpcom&lang=en&cc=us and install it.
4) If cartridge condition or its refill time is over then try to use new cartridge.
Posted on Feb 22, 2009
ikechinedu
  • 184 Answers
SOURCE: Hp deskjet 9650 not compatible with Vista 64-bit
Hp Deskjet 9650 printer owner, sorry to inform that there is no Microsoft Windows Vista operating system printer driver solution available for your printer. But there is an alternative way to workaround it so that you can do basic printing with your printer.
As a workaround, an alternate printer driver solution included in Microsoft Windows Vista operating system can be used to perform basic printing to the printer. However you might find that some of the product features are no longer available when using this alternate printer driver, but that is your best option right now.
The alternative HP printer driver that will work with your printer is HP Deskjet 9800.
The Next thing you do is: Install the driver for HP deskjet 9800
1. Verify that the Universal Serial Bus (USB) cable is NOT connected to the printer.
2. Click Start , click Settings , and then click Printers .
3. Click Add a printer .
4. Click Add a local printer .
5. Select the Use an existing port check box.
6. In the Use an existing port drop-down list, select LPT1: (Printer Port) and then click Next .
7. Under Manufacturer on the Install the printer driver dialog box, select HP .
8. Under Printers , select the appropriate alternate driver for the printer (deskjet 9800) and then click Next .
9. In the Printer name text box, type the printer name and then click Next . The printer driver starts to install.
NOTE: The name of the alternate driver displays as the default name. Change this name to the name of the printer, if desired.
10. After the screen stating that the printer was successfully added displays, connect the USB cable / Parallel cable to the printer and to the computer.
11. On the Found New Hardware screen, click Cancel .
12. For USB connected printer, please proceed to step three . For Parallel port connected printer, please proceed to step four .
NOTE: If multiple pop-up windows display, click Cancel on each window.
Next is: Configure the printer
1. In the printer folder, right-click on the name of the printer and then click Properties .
2. Click the Ports tab.
3. Change the port from LPT1 to the newly created USB port, click Apply .
Last step: Print a test page
1. Click the General tab.
2. Click Print Test Page .
Good luck Cheers!!!
Posted on Apr 26, 2009
My HP deskjet F4440 is printing online doc. with a down left shift double letter any ideas? Prints fine except for online stuff.
If you are referring to websites this is common, because they are not printer friendly or made for printing. That is why some sites have a print option, that takes you to another page.
Oct 14, 2012 | HP Compaq dc5000 PC Desktop
Won't print on Vista operating system
I've seen this before with these printers. They will print a test page ok but nothing from the computer. Reload the driver. In fact go to the HP website and download the newest driver and install it. This should solve your problem. You should find your drivers here http://h10025.www1.hp.com/ewfrf/wc/siteHome?lc=en&dlc=en&cc=us Let me know if you need anything else.
hardrocko
Thanks for using FixYa
Feb 20, 2010 | HP DeskJet 845c Printer
Good luck Cheers!!!
Apr 26, 2009 | HP DESKJET PRINTER, HP OR COMPATIBLE
HP9650 full document print
THIS PROBLEM IS USUALLY CAUSE BY THE DRIVER,IF ITS CORRUPTED.TRY REINSTALLING THE DRIVER AND LET US KNOW  WHAT HAPPEN NEXT.
Feb 05, 2009 | HP DeskJet 9650 InkJet Printer
My hp deskjet 9650 sometimes makes this terrible noise when printing a screaching noise like it is off track and my print looks like it took a shift one way or the other. When it is printing letters they...
Printers usually have some sort of cable or belt that moves the carriage. Check the belt on your machine. They will wear and deteriorate over time and sometimes will shred. If you REALLY like your printer, the belt can be replaced.
Jul 27, 2017 | Office Equipment & Supplies
Hp desk jet 920c ink cartridge
hi,
i think your color ink cartridge is near to empty that's why you are experiencing a pause printing..
try to replace it and try to print again..
rey...
Oct 08, 2008 | HP DeskJet 920c InkJet Printer
HP Deskjet 6540 Alignment
Yeah, the only thing that can cause this is paper feed problems.
There must be either something loose in the paper feed mech (look for wobbling "tires") or there is still some paper or other foreign debris in the paper feed path.
Jul 03, 2008 | HP DeskJet 6540 InkJet Printer
Hp deskjet prints symbols/wingdings instead of text
3. test print.
hope this helps
thanks for rating
Jan 14, 2008 | Office Equipment & Supplies
Hp-dj 9650 won't print
please reinstall printer software
Sep 22, 2007 | HP DeskJet 9650 InkJet Printer
Open Questions:
See all HP DeskJet 9650 InkJet Printer Questions
HP DeskJet 9650 InkJet Printer Logo
22 people viewed this question
Seeker5211
Seeker5211
