Question about HP Pavilion dv6000z Notebook
How do you stop screen flickering on laptop - HP Pavilion dv6000z Notebook
  • HP Master
  • 32,281 Answers
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Posted on Sep 28, 2009
Laptop screen flickering
You need to replace the screen. Look for a replacement on ebay.
Aug 06, 2014 | Computers & Internet
My laptop screen flickers in and out, screen goes black
Hello there,
The reason the screen flickers is simply because the module of the laptop is faulty. The module is what connects the screen to the main board, it is like a flex for the screen. Once you can have it replaced, the screen will stop flickering.
All the best Elect_Comp
Sep 13, 2011 | Acer Computers & Internet
The screen flickers periodically without any reason. If i giggle the screen or pull the screen down the up it staops.
Hi
The flickering happens because the flex of your laptop is getting weak.
The flex connects the screen of a laptop to the motherboard it is through it that data is passed to the screen.
It is found in all laptops and the more you open and close the laptop,it gets weaker and weaker.
The best thing to do to stop the flickering is to change the flex.You can also loose the laptop,remove the flex and fix it back properly but that may not stop the flickering permanently.
Note;if you cant loose the laptop yourself please get an expert to do it for you
Thank you for visiting fixya
Mar 12, 2010 | Microsoft HP Pavilion DV6276US Notebook PC
Laptop LCD screen shaking/flickering
it can be a static problem, where covers are not correctly ground.
Jan 15, 2010 | Toshiba Satellite Pro U400-S1001V Notebook
Flickering of the screen
just open the system and reseat the display cable...
Sep 20, 2009 | Acer Extensa 5420-5687 Notebook
Flickering screen of my lifebook s series
This sounds like a loose connection. If you can press on the back of the lid and it flickers or stops flickering, then it's definitely a connection problem. You will need to take the bezel around the screen off, the screws are hidden under small sticky tabs or the small rubber bumpers. Then take the screen loose and check the connection on the back. Replace the tape on the cable, if there is any.
Aug 02, 2008 | Intel S6240 Notebook
Lcd Flickering
Sounds like the driver board for the backlight is going bad...is there a spot on the screen part of the case ( usually at the bottom) that feels much warmer than the rest?
Mar 16, 2008 | Gateway 450ROG Notebook
HP Pavilion dv6000z Notebook Logo
174 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
