Question about Brother Multi-Function Center® MFC-215C All-In-One InkJet Printer
Has plenty of ink in all colors but printer says no ink in any colors will do a copy ok but not print from computer
Printer has ink but wont print in color test page wont print in color, also aligned printer and it worked in color. cleaned printer head as well which printed all the colors. what else can i do? It seems...
Take color copy, test all colors are OK..Go to printer properties, printing preferences, finishing check is there any check mark on print in black cartridge only? mark on print color..apply..OK.. give print command..
Go to paint draw a color drawing, print it.> check colors if its not printing in color it might be drivers issue.. un install the drivers re install once again check..> if printed in color check the file which you are printed..take another file.. then test..
Oct 29, 2011 | HP Photosmart C6180 All-In-One InkJet...
The MX860 is making all color copies and printed pages pink. Any thoughts? It has plenty of ink in other colors.
Hello ! Here is your solution.
Your ink i.e. Cyan & yellow were malfunctioned so remove your cartridge and rub its head with soft paper until your two colors stain on your paper.... thanks
Sep 07, 2011 | Canon Pixma MP800 All-In-One InkJet...
We have a Xerox Phaser 8500N printer. The yellow is printing out a dingy gold. I hav checked the yellow print blocks and there is plenty.
What it essentially boils down to is that you're not printing enough color. The blocks are melted into a holding bin and will discolor over time. To correct this, you will need to purge the color that is "stale". Go to this link http://www.solid-inks.co.uk/technical_support-phaser_850_860_8200.html?category_id=1 and download the pdf for your color (I would recommend downloading all four to keep on hand). You'll want to open the PDF and print 10 to 20 copies until the bad ink is replaced with fresh ink. You'll notice the color change as the ink is purged.
Jan 05, 2010 | Xerox Phaser 8500N Printer
All my photos have a heavy red tint
Be sure you have plenty of all the different inks and that the print head is clean and functioning well. If you are low on one of the inks the colors can be off.
If you have plenty of ink then on of the color print heads may be clogged and preventing that ink from flowing. A few cleaning cycles will hopefully fix this.
Also realize that different inks will render different color reproduction and will especially look different from what you see on your computer, unless you have special software to correct for this.
Dec 19, 2009 | HP Photosmart D7460 Printer
The printer will print ok in color, but will not print black ink. No copy or printing.
My best guess without knowing more is that your printer has both a color print cartridge and a black ink print cartirdge. Replace the black ink cartridge and you should be fine. You might also find that replacing the entire printer is less expensive....All the best!
Nov 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My printer will not print black ink.
I had the same problem & I think it was I had the wrong color on the Copy screen.
Dec 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
No color--plenty of ink
the colour ink must be dried up.so its not printing.replace the cartridge to make it proper.
Oct 23, 2008 | HP PSC 1610 All-In-One InkJet Printer
Poor color printing quality
do you have the canon print management software installed? it's located in the maintenance tab on that software.
www.canon.com has that by model number
Jun 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Epson DX4000 printer
Hi..
Try this. Removed the color cartridge. Open the printer settings under Quality and check the box that says print in "greyscale" or "black and white.
This will rule out and color cart problem and also change the printer settings. You will have to change this back to print in Color,
Hope this helped........
Squipps
Feb 06, 2008 | Office Equipment & Supplies
Brother Multi-Function Center® MFC-215C All-In-One InkJet Printer Logo
172 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
