Question about SVAT CV67 Hi-Res Outdoor Weatherproof Color Nightvision CCD Security Surveillance Camera
Need wireing map for cv67 i have four wires red black yellow white whats what?
Only red(+) Black(-) and Yellow (Video) is used if you just cut off that mini din plug end and were looking at the wires coming from camera. I bought some standard power and bnc pigtails from DX.com and replaced that mini din cable they use to make their connections to a standard cctv type.
Un-screw the main lens cover and you will see a screw ring and by taking a verner caliper to catch on both sides you can unscrew camera unit ring and when you look inside the only wires you need to solder to new pigtail is red/black/yellow each to their own color.
Pushing the pigtail thru may be a little pain but with a little spit on wire makes it a lot easy.
Re-assemble in reverse and you should be up and running.
Camera runs on 12 volt with center of plug positive and video bnc center is video.
Hope this helps.
Posted on Feb 16, 2016
I need to change my 3 prong to a 4 prong
Unplug the dryer then remove the terminal block cover and disconnect the 3-prong cord from the dryer. Note that the cord has red , black, and white wires but sometimes the red and black wires are both replaced by same color wire, usually gray and can switch places. There's also a ground strap wire also connected to the center terminal together with the white (neutral) wire.
Get yourself a 4-prong cord and note that it has red, black, white, and green/yellow wires but sometimes, like the 3-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect the 3 wires in the same manner they are connected as 3-prong cord to the terminal block. The ground strap wire now just need to be connected to the remaining 4th wire, the green/yellow wire instead of the center terminal together with the white (neutral) wire. Reinstall the terminal block cover and it's done.
It can be observed that converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4 whereas, on the other hand, converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3.. The links below might enlighten you further on this matter.
Four-prong to Three-prong Electric Dryer Conversion
Three-prong to Four-prong Electric Dryer Conversion
Aug 21, 2011 | Kenmore Dryers
I need to know which wire on the 4 wire oxygen sensor (2 white, one grey one black) is the heat wire on a ford f-150 o2 sensor?
Hello! There are four O2's...Each O2 heater, left and right bank, front and rear, has it's own wire colors...These colors are "at the connector"...First series are the control ground sent by the PCM..
RR=White/Black...RF=Red/White...LR=Tan/Yellow...And LF=Yellow/Light Blue...........This series are the battery leads, hot when fuel pump relay pulls...RR=Violet/White...
RF=Red/Yellow...LR=Violet/White...LF=Red/Yellow...
If you have any questions feel free to ask...Guru...Saailer
Oct 20, 2010 | 2001 Ford F150 Styleside SuperCrew
Just moved and outlet for dryer is different.
Connect the red, black, and white wires of the new cord to where the red, black, and white wires of the original dryer wires are connected to but disconnect the ground wire (green/yellow wire attached to the cabinet) from where the white wire is connected to and connect it instead to the fourth green/yellow wire of the new cord.
Apr 12, 2010 | Whirlpool LER5636P Electric Dryer
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
02 sensors wiring
The yellow and white wires take any white wire.I dont now why they dont tell you that.And just fit black to black and grey to grey that simple good luck pippall.
Aug 08, 2009 | 1996 Jaguar Xj Series
I need a wiring diagram for a 2001 ford f150 trailer hitch plug in. i got a new heavy duty trailer connector and i need to know the color code of the wires
Hey Bryan
I've got them for Six and Four wire plugs
Six wire plugs:
Horse, stock or utility trailers:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Yellow = Not used -
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
Mike
May 02, 2009 | 2001 Ford F150 Styleside SuperCrew
Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Oct 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
SVAT CV67 Hi-Res Outdoor Weatherproof Color Nightvision CCD Security Surveillance Camera Logo
146 people viewed this question
Top SVAT Home Security Experts
Lawrence Oravetz
Are you a SVAT Home Security Expert? Answer questions, earn points and help others
