Question about Apple iPhone Smartphone
Iphone won't hold any charge for two days now
It won't charge!i keep trying to charge it but when i
unplug it the battery goes down?!
  • 438 Answers
Ur battery is the problem..change it......
Posted on Sep 28, 2009
IPhone won;t stop vibrating ,blank screen won';t charge help ??
If phone was dropped or got wet, it needs to be taken to a tech ASAP. Try restoring it, putting the device on DFU mode.
Nov 01, 2014 | Apple For iPhone 4/8GB LCD Screen...
MY IPHONE DIED AND NOW WONT TURN BACK ON
First check to make sure your charger is working, plug it up to the computer and see if the battery charging display comes up.
Second I would check to make sure the battery is actually charging.
Third try a cold boot, hold the power and home keys down while it boots it could just simply be locked up.
Jan 09, 2013 | Apple iPhone4 4G iPhone 4
The car was running fine one day then the next day it would not start. We tried jumping it thinking the battery might be dead and it still would niot start. The car has power until we take the jumper...
Sounds like you have a toasted battery or alternator. Have you performed a load test on the battery? Have you tried to charge the battery? First remove the battery and charge it externally from the vehicle. If the battery won't hold a charge, or won't hold a charge of 12 volts, replace it. Once you have the vehicle started, test the operation of the alternator. It should be putting out at least 13 volts back to the battery to keep it charged - if it is putting less than 13 volts or more than 16 volts, replace the alternator.
Nov 01, 2011 | 2005 Chevrolet Malibu
Hello, My Iphone is completely dead. The battery went down and I was about 2 months without using it. Now I'm trying to unlock it but the Itunes doesn't recognize it. The screen is black with no battery....
First, plug the iphone into the wall with your usb cable and power adaptor. Then hold down the sleep/wake button (button on top left) and the home button (bottom middle button). Keep holding those two buttons until you see the Apple logo. This should turn it back on and then charge it. If not, Genius Bar.
Mar 10, 2011 | Apple iPhone Smartphone
I've had an iphone 3G for about a year now, and jus in the past 2 weeks i've had a hard time charging my phone, with either a wall outlet or my computer. i'll find myself spending an hour jus trying to...
Most likely your iPhone battery is dead. If you have the AppleCare and hasn't expired Apple will replace your iPhone battery free of charge.
If it has expired you can pay about $50 (I think) and Apple will replace the battery. If you think that's too much go to Amazon/Ebay and look for an "iPhone Battery Replacement Kit." Remember if you do decide to do the battery replacement yourself. You're voiding your Apple warranty & they won't replace it.
Jan 11, 2011 | Apple iPhone 3G
My iphone didnt charge and its not turning on. my laptop charger is open like the inside part to charge it,i use half of my iphone charger to try charge it the battery was almost dead after a couple trys...
Try doing a master reset by holding down the Home button (the button at the bottom with the square), and the power button at the top of the phone down at the same time until the power off command comes on, but keep holding until you see the apple logo come on then let go. This is a master reset. Then try charging it. let me know how that goes.
Feb 17, 2010 | Apple iPhone 3G
Battery issue still cannot be solved, hard reboot tried.
Have you tried all the resets:(if you have, bring back to the Apple store)
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 29, 2009 | Apple iPhone Smartphone
My iphone won't sync with itunes. it did at first but now keeps coming up with an error I have an original iphone, never been jailbroken or any such thing, and can not currently get it to sync with itunes...
Recharge
Make sure iPhone is charged. Connect to a USB port and look for the lightning bolt battery icon in the upper right. If you don't see this icon, then iPhone is not charging. The battery will charge to 80% in an hour.
Note: If you put your computer into sleep mode while iPhone is connected via USB, iPhone may not charge.
This screen means to keep iPhone connected so it continues charging. Please note:
If iPhone is not sufficiently charged it will not show up in iTunes
Use a high-power USB port such as the one on your computer, or use your iPhone AC adapter.
Don't use the USB port on your keyboard because it is a low-power port and iPhone will not charge.
Make sure you are using USB to charge. Accessories that use FireWire to charge are not supported with iPhone.
If you see the red part of the battery image flash three times and then the screen goes black, it means that iPhone is not receiving power to charge.
If the above steps dont resolve follow the following steps :
Retry with a different USB port.
Note:
Restart
Try restarting iPhone. To turn it off, press and hold the Sleep/Wake button until the red slider appears. Slide your finger across the slider to turn off iPhone. To turn iPhone on, press and hold the Sleep/Wake button until the Apple logo appears.
Does iPhone appear frozen or stuck? Try pressing and holding the Home button for at least 6 seconds to close a frozen application. Then try restarting iPhone again.
Note: If that doesn't work, try restarting your computer.
Reinstall
Reinstall iTunes 7.7 or later.
Get the latest version of iTunes (7.3 or later) from http://www.apple.com/itunes/download/
Thanks.
Oct 21, 2008 | Lands Phones
Iphone won't charge and now won't work
I left my phone charging for a few hours and it appeared not to be charging as the battery icon was staying at 10% of charge. I was confused because it had the charging icon in the upper right hand corner. If your phone is doing something similar i simply powered the phone down and turned it back on. The charge went from 10% to 100% on the display. This is what worked for me hope this helps.
Jan 22, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
336 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
