Question about Dryers
I have dryer whirlpool mod. LER4634EQ2, all time is on, don't stop, the timer don't run
  • 909 Answers
The timer will almost certainly be the problem. Very possible the timer drive motor is faulty. Spares for whirlpool are difficult enough to obtain, so i would suggest a new timer as it would be easier to get than a timer motor.Very easy to replace as the timer is normally modulated. (pull wiring plugs out then simply push back in onto new timer).
Posted on Sep 28, 2009
Mod: LGR5620KQ1 dryer keeps running. timer stays the same.
sounds like short to ground and feed back to timer
Aug 31, 2009 | Whirlpool Dryers
Whirlpool Mod LER4634JQ0 has stopped working - you can hear the timer clicking, but does not operate on any cycles
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 09, 2009 | Whirlpool LER4634J Electric Dryer
Element heats, dryer tumbles, no heat in drum, never shuts off
Hi, If the dryer heats but will not advance in either time or auto cycles, you need to change the timer.
You can test to see if the timer is getting voltage. Remove the top rear panel and locate the two wires going to the timer motor. There should be 120V when the dryer is running in time dry.
Please let me know if this helps or if I can assist you further.
Thanks
Vic
May 27, 2009 | Whirlpool LER5636P Electric Dryer
Whirpool dryer won't heat up
You need to replace the thermal fuse and the timer. A bad timer will over draw a thermal fuse and cause it to blow.
Please remember to unplug the dryer before servicing
Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Dryer LER4634EQ2
you can remove the back panel everything is acessed from ther, with a meter you can check for continuity of all the thermoats and heater assy, first one to check is the thermal overload fuse locate d in the middle of unit "white " usually blows when excessive temp is detected( blocked vent)
Mar 07, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool electric dryer
As long as the timer is on your heating element will be on.Sounds like you've have lost both.
Feb 11, 2009 | Whirlpool LEQ9858P Electric Dryer
Air flow and heating problem inside dryer.
???? this doesnt make much sense, can see how you would be measuring air flow within the cabinet??? air blowing out unit strong means your gettin good air flow fom within, that is a direct relation as to the amount of (hot) air being pulled across the clothing
Jan 14, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
167 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
