Question about Sony DVP-NC85H Multi-disc DVD Player
I can't turn off the "Progressive Scan" feature. When pressing the progressive scan button it only switches from "auto" to "video" but no other options. I tried turning the unit off and pressing 3, 6, and 9 on the remote with no success. I did tried all of this with the HDMI cable unplugged. Any suggestions on how to turn this feature off so I can use my HDMI cable?
  • 2 more comments
  • constant0003 Sep 28, 2009
    Hi, thanks for the response. Unfortunately whenever I press that button it doesn't give me anymore than the 2 options I stated before. There is no "normal interlaced" setting to switch to like the manual says there should be.From what I've read, I can't use the HDMI feature unless the "progressive scan" is turned off. I've checked the cables and the ports on my tv to make sure they weren't faulty. I'm currently connected using the component hook up. I even tried manually setting the HDMI output on the DVD player to a setting that is compatible with my tv (720p) and still had no picture or sound. I've been trying all these variable with the HDMI cable unplugged and rebooting in between changes.
    I can't disable the "progressive scan" feature on my Sony DVP-NC85H. Apparently, I need to disable this feature in order to use my HDMI cable (which the DVD player will not acknowledge). Pushing the "progressive scan" button on the front of the unit only gives me 2 options: P. Auto and P. Video. The manual says it should also say "normal interlace" but it doesn't. I'm currently hooked up directly to my LCD TV using the composite connections. I tried manually setting the HDMI output to 720p (which is what my LCD is rated) but still got no picture or sound. I've also tried the reset function from the menu but still can't deactivate the "progressive scan" feature. I've double checked my cables and the HDMI ports on the TV and they work fine. When I plug the HDMI cable into the DVD player the indicator LED doesn't light up. I really just want my HDMI to work. Any suggestions?
    Thanks for the response. Can you tell me exactly how to do that because I cant seem to find that option in the menu.
    I'm using the remote but I'm not seeing any option for disabling the progressive scan or enabling the HDMI.
    Top Expert:
  • Sony Master
  • 76,630 Answers
YOU MUST GO INTO THE VIDEO MENU IN SETUP OPTIONS AND TURN OFF THE PROGREESIVE AND SWITCH TO HDMI.
Posted on Sep 28, 2009
  • yadayada
    yadayada Sep 28, 2009
    the setup menu is accessed from the remote control not the players controls
  • yadayada
    select the video options, I know it's there..
  • 4,472 Answers
Http://www.docs.sony.com/release/DVPNC85H.pdf
If you refer to p.21 if you are trying to get the interlaced setting. the hdmi indicator cannot be lit. If your tv has HDMI then you should be able to use progressive scan.
Thanks,
Lee
NO VIDEO BUT HAVE SOUND
Good day! Try to check the rca jack video input.Replace it with new one if defective. Also check the progressive scan features if activated. If it is activated check your TV if supported by progressive scan features, because some TV is not supported by progressive scan.You can deactivate it by turning off or activate the interlace mode.Press the open/close to open disk tray. And press the numeric keypad 1 for few seconds. Hope its help.
Sep 07, 2011 | Philips DVP-3005 DVD Player
Why do my tv screen appears in three sections when i put a dvd disc? it appears normal when i put a vcd!
hi,
check is your tv supports progressive scan, if not switch off the progressive scan mode on your sony home theater system.
For switching off the progressive scan mode do the following in ur home theater's remote.
Do this setting if your connected the component video
1. Press the FUNCTION BUTTON on the remote.
2.Press the VIDEO FORMATE button to select interlace scanning.
If you are connected the HDMI then do the following setting
2.Press the VIDEO FORMATE button to select the resolution
Select 720 * 480p
Jan 17, 2011 | Sony BRAVIA DAV-HDX267W Theater System...
I was using my dvd players component outs for a year but my hi def tv died so when I hooked up my old tv to the single video out I can't get any picture out of it. I think I need to get into dvd player set...
If its an old Sony dvd player then check Progressive Scan button at rear or some may have it on front to turn off to get composite video output (yellow video out)
And if it does not have any manual switch for progressive scan then turn off dvd player by pressing power button on its remote control, press 3, 6, 9 on dvd remote and press power to turn dvd player On.
That will turn off / disable progressive scan mode and you will get video output from yellow video out jack.
Jul 31, 2010 | Sony Televison & Video
I cannot get video picture,But ican hear all audio functions.
put a disc in the player and once it starts to play press stop, then press and hold the stop button for 5 seconds this will turn off the progressive scan feature.
Apr 26, 2009 | Zenith DVT412 System
Not able to turn off Progressive scan feature-sony dvp nc85h
If it works like my sony RDR-GX315 just press the pause button on the player itself and hold for 5 seconds.
Jan 08, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Showing red image
Make sure red is matched up to red, green to green, and blue to blue first. Then, try a different set of YPbPr (component) cables if you have a set available. If it still shows up red, then read this:
If you are using a Progressive Scan TV
(TV must indicate Progressive Scan or
ProScan capability), to activate TV
Progressive Scan, please refer to your TV
user manual. For DVD system Progressive
Scan function, see page 28.
Helpful Hint:
– If your TV does not support Progressive
Scan, you will not be ab le to view the picture.
Press and hold OPEN/CLOSE button and
press ‘1’ to deactivate progressive scan.
Progressive Scan - turning on/off
To select this item, you must set “Video
Output” to Y PR PB and ensure that your
TV has progressive scan (See page 11.)
Follow the steps of “Using the Setup
Menu” and select :
> PROGRESSIVE
OFF
ON
PROGRESSIVE SCAN OFF
TV SHAPE
TV SYSTEM
VIDEO OUT
PROGRESSIVE
SCR SAVER
SMART POWER
OFF
Select this to disable Progressive scan
function.
ON
These are pp. 11 and 28 of your owner's manual for the HTS
If these methods still fail, try turning your TV's progressive scan off or on.
-Tha Mp3 Doctor
Jan 08, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
No video output from rca jack or svideo
The problem is with the p.scan button. It seems if its pressed the video goes off. You need to keep it pushed until you see a message for "progressive scan".
Dec 08, 2007 | Samsung DVDR120 DVD Recorder
Progressive Scan Mode
Per manual, with DVD selected and stopped, press and hold p/scan button on remote for 5 seconds to switch between pscan and interlace mode.
Nov 10, 2007 | GoVideo Go Video DVD/VCR Combo
How do I turn off Progressive scan?
Hi, follow the steps it may help !! Press STOP button. ? If playing a disc, press the STOP button twice so that ?STOP?, appears on the display. Press and hold P.SCAN button on the remote control for over 5 seconds. ? Pressing and holding the button for over 5 seconds will select "Progressive Scan" and "Interlace Scan" alternately. ? When you select P.SCAN, "P.SCAN" will appear on the display. ? To set P.Scan mode for DivX discs, press the P.SCAN button on the remote control for more than 5 seconds with no disc in the unit (?'NO DISC" on the display), then load the DivX disc and play. regards sreejith
Jul 17, 2007 | Progressive DVHE210 210 DVD Player
Progressive scan
Press and hold the play button down for 5 seconds, this will turn the progressive scan feature off. As per the troubleshooting manual.
Jan 13, 2007 | Sanyo DVW-7200 DVD/VCR
Sony DVP-NC85H Multi-disc DVD Player Logo
134 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
