A greasy substance getting inside the folds in the ''glass to barrel'' seal and the drain in the bottom of the seal . it also appears to have embedded in the rubber surface and won't wassh off. The substance is a brown colour. the model is an Enhance AL1046T
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
Check its not comming from sink running back..
Posted on Sep 28, 2009
How do I clean inside the 25mm lens - cleaned top & bottom, appears dirty inside
Some lens have a group at the end which can be unscrewed by the user. First determine if this is so by grasping the 1.25" barrel which goes into the focuser clamp, and applying moderate unscrewing effort. You may be able to gain access inside.
After that it is likely that glass is glued or strongly clamped in. Take the lens to a camera, binocular or telescope shop for advice.
Jul 30, 2015 | Optics
How do I remove the main oven inner glass to replace the seal? The screws which appear to hold it in place only do a half turn!
THE SCREWS MAY BE WORN AND STUCK OR THE INNER GLASS HAS BECOME SO GREASY THAT YOU MAY NEED TO USE SOME THING TO GET RID OF THE GREASE AND GUNK TO SLIDE OUT THE DOOR. MIX IN SPRAY BOTTLE WITH ABOUT 3/4 VINEGAR AND THE REST OF THE BOTTLE WITH WATER AND SPRAY INTO THE SCREW HOLES OR IN BETWEEN THE GLASS SEE IF THAT WILL WORK FOR YOU.
Jan 27, 2015 | Ovens
Sealed Glass UNDER the removable glass on Lamona 3650
The glass you refer to will be laminated and the muck is growing in the plastic that bonds the 2 pieces of glass You will have to replace that piece of glass.
Apr 08, 2013 | Cars & Trucks
BMW C600 sport oil leak after riding
It is possible that either a crank seal is leaking or a gear box shaft seal is leaking check for over full in either case first
Jan 12, 2013 | Cars & Trucks
When there heavy rainfall , water goes itno the passenger side door i have to move the rubber on bottom of door to let water out, why is this hapening ?
There are small drain holes along the bottom of the door, and it sounds like yours are clogged. Inspect the window seal along the rear edge and along the bottom window seal where the glass meets the door.
Another option would be to drill small, additional holes along the bottom of the door. If you do, make sure you locate them on the outside of the rubber seal. Otherwise, the water will drain inside the car. Hope this helps.
Aug 17, 2011 | 2005 Cadillac CTS
My Regal breadmaker has begun to release a black greasy substance into my bread dough. Do I need to replace the pan?
The black substance is lubrication oil. The oil lubricates the bearing and shaft that the paddle spins on. Usually this bearing is sealed, but black greasy substance means that the seal is broken and is leaking. Just a matter of time until it fails all together. Time to replace.
Hank
Nov 05, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
The sink leaks at the bottom of glass sink where it connects to the piping
THE PART YOU ARE TALKING ABOUT IS CALLED DRAIN TAIL PIECE. THE DRAIN YOU CAN REMOVE BY LOSENING THE NUT UNDER THE SINK WHILE SOME ONE HOLDS THE DRAIN INSIDE THE SINK FROM TURNING THE OART KEAKING IS CALLED A SPUD GASKET WHICH SEALS THE DRAIN TO THE SINK
Aug 18, 2009 | Magickwoods Black Glass Vessel Sink
Does my belt need replaced?
If it is greasy and not oily, the belt will need to be replaced, there is slight possibility that the bearing seal under drum is leaking oil,
Jul 09, 2009 | Washing Machines
I need a replacement door for a built in Baumatic 720 series oven
I have exactly the same problem and my bottom glass panel exploded. My friends did the same. You can take the inside glass panel out via the two screws and clean the inside of the outer glass once removed. Id replace all the rubber seals to as they perish, particularly the one that clips onto the oven itself that meets the door.
Nov 21, 2008 | Ovens
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
