Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
How do you take apart the KitchenAid Mixer K5SS to get at the gears? The motor runs but the beater doesn't go around. I have an exploded view, but it isn't clear how to begin disassembling the planetary.
    New Friend:
  • 87 Answers
It quick terms, first remove the head. Take off the band, this is where the two halves join. Undo any screws holding the halves together. Remove the pin holding the planetary in place. Remove the trim disc. The planetary assembly lifts out but you may need to work around it carefully lifting it a little at a time.
Posted on Jan 24, 2010
Testimonial: "I got it apart and replaced the gear and we're up and running again. "
I cannot get the pin out to remove the planitary. I have sprayed it with lubricant but it won't budge. Any suggestions?
Posted on Feb 21, 2013
How can I adjust bowl depth?
KitchenAid K5SS Heavy Duty Commercial Stand Mixer ...
www.fixya.com/...kitchenaid...k5ss_heavy_duty/adjust_beater_height
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust beater height related issues. Get free ... Beater hits bowl beater height adjustment screw does not fix problem ... beater ... ...adjust beater depth-it is scraping the bottom of the bowl.
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Adjust
www.fixya.com/search/p105880-kitchenaid...k5ss_heavy_duty/adjust
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust related issues. Get free help ... How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen ... How do I adjust the depth of the dough hook. how do I adjust ...
How To Adjust the Bowl Height of Your Stand Mixer ' The ...
www.thekitchn.com/how-to-adjust-the-...
Apartment Therapy's The KitchnFeb 10, 2011 - In the world of stand mixers, there's two different types. ... It's easier than you think and will make your appliance last longer and food taste better! ... If yourbowl height is too high, you'll hear the adjustment needing to be made before you ... I have a different issue with my KitchenAid Artisan mixer (tilt head).
Dec 25, 2015 | KitchenAid K5SS Heavy Duty Commercial...
I have a kitchenaid K5SS. The beater keeps hitting the bowl even after adjustment screws was adjusted. What else can I do to fix problem
Check the four large screws at the back of the motor housing. They screw up thru the pedestal into the gear/motor housing. If they are loose that can allow the motor to tilt forwards. Check also the ones under the pedestal base, I have never seen those ones loose though and they would not cause your problem.
Mar 24, 2014 | KitchenAid K5SS Heavy Duty Commercial...
The mixer runs but the beater doesn't turn. Drive shaft?
a gear or gears. their usually plastic and will damage before the drive shaft
Feb 07, 2013 | KitchenAid K45SS Classic Stand Mixer
Motor speed is erratic. Now it makes grinding noises
There is a speed governor on the motor end of the armature (back end of the motor) that may
need replacing. It's one of the few parts still available. on eBay, or mendingshed.com
The grinding could either be the gears in the beater end of the mixer, or the motor bearing on
the back end of the motor.
The gears are available as they are the same as for newer mixers like the K5SS.
The motor end bearing is not available, but I was able to take the bearing out of the motor
bearing plate from a K5SS which is still available, again on eBay or mending shed, and put
it in the motor bearing plate for the K5A. Then you need to soak the felt ring inside the housing
on the back end of the bearing in oil, preferably synthetic like Mobil 1. Also helps to smear
a little moly grease (not out of a tube, not enuf moly content - get some Honda Moly 60, small
tube for $10 at any Honda store) on the shaft when you have it apart.
Jan 21, 2011 | KitchenAid Classic Stand Mixer
How much does a motor cost for this mixer
Hi CAKE_LADY196, Happy New Year! So you want to replace your mixer’s electric motor? Good for you! However, before you start taking your mixer apart, be sure you have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled: “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixers electrical components, along with all the parts. Locate Illus. Nos. 41 and 8, Field Assembly, 115V (the stator) and Armature and Bearing, 115V. You will need these two components to totally replace your mixer’s electric motor, although it is possible, you only need the armature and bearing. Whether you replace both motor parts or just the armature, I would suggest replacing the brushes, too.
Costs will run between $71 ~$99 for repair parts, plus shipping & handling and any sales tax depending on the vendor you select.
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’ online (although I’ve seen automotive bearing grease used too – your call). Prices can vary widely between vendors, so do some comparison shopping.
Once apart you can check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Finally, here are some links to several excellent websites that detail the disassembly/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
Good luck, I hope this helps. Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Jan 18, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Diagram or exploded view for disassembly for 5K5SS mixer
Have you tried this site? I saw it posted on another question/solution.
http://downloads.mendingshed.com/KitchenAid_Service_Manual.pdf
Sep 06, 2009 | KitchenAid K5SS Heavy Duty Commercial...
I have a Kitchenaid Professional 5 Plus Mixer beaters won't turn
It sounds like it has been overloaded and the worm gear has been stripped. You will need to take the head apart to confirm this.
Jun 24, 2009 | KitchenAid K45SS Classic Stand Mixer
K45SS leaks lubricant
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Exploded parts views for all mixers are available at www.kithchenaid.com. Click "Customer Care" in the upper right hand corner of the main page, and then select "Locate Manuals and Guides." You will need to enter the unit's model number exactly as it appears on the bottom of the mixer. It will be listed on a white sticker.
Nov 03, 2008 | Food Mixers
The motor runs but the beater doesn't turn, as though the gear drive has failed. How do I take the mixer apart to check the gear drive?
http://www.fixya.com/support/t636606-kitchenaid_ksm90_stand_mixer
Kitchenaid service manuel gives step-by-step instruction on a stand mixer.
Sep 07, 2008 | KitchenAid K45SS Classic Stand Mixer
Beater doesn't turn
I think this link will help you understand what is needed to fix your mixer.
You will need to purchase a gear. Here is link MarBeck should have it.
You may need to replace some grease. Make sure to use a non-toxic food grade grease.
Dec 15, 2007 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
791 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
