Question about IBM Infoprint 1612 Express Printer
The page prints, then retracts back into the printer
The page prints, then retracts back into the machine and appears to print markings on the page the second time.
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
Print appears on multiple pages
check the fuser unit in the back of the machine; typically the shadow effect is caused by the fuser assembly. Inspect your toner cartridges for any leaking toner. Genuine HP or ? ? ? ?
Dec 20, 2012 | HP Color Laserjet 3550 Printer
Ink appearing on the back side of pages prints
This is called duplex printing or two sided printing. If you want to disable it, you can go to
Start>Devices and Printers>Right Click on your default printer>Select printer properties>Click on the box where the check mark appears in the box "duplex printing." This will remove the check mark. Click ok.
Apr 17, 2011 | Canon MP830 All-In-One Printer
My dcp165c printer print quality prints black & yellow colour. i clean print head through maintance 76 but problem cannot be solved
How is the printer printing black and yellow color? Is it a smudge?
When I print, the pages are smudged with ink. What should I do?
Description:
- If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pages settings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Aug 03, 2010 | Brother Computers & Internet
I HAVE AN ERROR MESSAGE FUSER ERROR WHAT SHOULD I DO?
Power down Machine and restart. If error comes back , you need to order a fusing unit or maintenance kit depending on the pages printed. To get the counts for the last maintenance kit press check mark and scroll to information ,check mark then print configuration page check mark.
Oct 13, 2009 | HP LaserJet 4600dn Color Printer
R1800 wheel marks on print
you can try to load your paper by the back of the printer. This problem problably arrived wen you taste a new heavy paper (too heavy?)
Jan 23, 2009 | Epson Stylus Photo R1800 InkJet Printer
Specks on print out of Mono Laser Printer HL2040
If its spots this could have been from the cartridge or the fusser unit...
Do a half print test...send a print page to your printer listen to the printer print as soon as you think the printer has printed some little bit switch off the printer...take the cartridge and view the printed portion can you see the spots..if not.....than its your fusser unit thats marking the paper....remove the half printed paper slowly.....not to tear it......remover the fusser unit(hot unit)........at the back of the printer....towards the top....on the unit it self you will see a Teflon paper ....move the gear on the far end of the fusser unit itself and view if there is any spots....try cleaning this spots slowly as not to damage the Teflon or mark the Teflon.....
Nov 04, 2008 | Brother HL-2040 Laser Printer
Double sided printing Pixma MP520
here's how:
print double sided pages
1. Set your computer software for double sided printing if you have a printer that is compatible. Double sided printers are generally professional style machines, and most offices, schools and libraries will have them. On a PC, go to the drop down "File" menu and select "Double Sided Printing" under the "Preferences" or "Properties" window and print. If you have a MAC, click "Copies and Pages" under the "File" menu, select "Layout" and then click on "Long-Edged Binding" and print.
2.Print double sided with your standard home printer, again, by setting your PC writing software. When you are ready to print, click on the drop down "File" menu and select "Print." From the "Print" window select "odd pages only," or "even pages only."
3.Set your odd and even pages a bit differently if you are working with MAC writing software. Select "Print" from the drop down "File" menu and click on the arrow to drop the "Copies & Pages" menu. Under the "Copies & Pages" menu, select "Paper Handling" and then click on "Odd Numbered Pages" or "Even Numbered Pages."
4.Select "Odd Pages Only" or "Odd Numbered Pages" and then print as usual. It is a good idea to mark the top of your first page with a pencil so that you know the direction and side of the page your printer prints. Use the mark to determine how to turn your pages and place them back in the printer. Select "Even Pages Only" or "Even Numbered Pages" and print again. $('.Article .Steps .Image').each(function(i,e){ e = $(e); e.find('img').error(function(){ $(this).unbind(); e.remove(); }); });
Sep 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Flaws at top of each page when printing
Replace toner cartridge drum is scratched
(Possibly by staple going threw machine if that what each of the five marks look like, all those removed staples always seem to end up in printers)
You can pull it out (I think right top cover opens and cartridge pulls up and to the right)  then .. turn it over and gently pull back cover see drum has same marks as you see on paper, you can gently rotate drum by using gear on edge do not force it only turns easy one way, Do not touch drum surface very delicate and sensitive. Normal disposable item buy a New cartridge here is HP part number for your model  HP C8543X (HP 43X) Toner Cart.
Oct 19, 2007 | HP LaserJet 9040n Printer
IBM Infoprint 1612 Express Printer Logo
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
