Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Computer will not detect printer. It used to be fine. Same laptop. THe laptop works fine with other printers
  • 8,197 Answers
Have you uninstaled then reinstaled the drivers. If not I would try that. If you do not have software disk you can get the software on line
Good luck
Posted on Sep 28, 2009
I'm trying to scan a photo using my Epson stylus SX425W via wireless to my PC. I've done this before without any problems, but today for some reason i'm getting "communication error W61" and it...
We've just had the same problem, it seemed to have something to do with a kind of Epson drive, within 'my computer' folder, if you can see said 'Epson drive' within my computer, delete/remove it.
We then had to uninstall every Epson orientated software file within uninstall programs in the control panel, and then re-install the software for the printer.
It did take us quite a while to figure it out, but our printer/laptop/internet wifi network now seems to work, bug free!!
Good luck!!
Dec 24, 2010 | Epson Stylus Multifunction Inkjet Printer/...
My olivetti anyway printer worked fine with my laptop,but will not work with my new pc,just reads no device detected
attach printer your new pc. pc on and printer power on. detect your printer than install driver in your new pc through printer driver cd.
if no detect your printer than right click my computer than properties than hardware than device manager than select any and top option scan for hardware changes, detect your printer and install driver.
Mar 02, 2010 | Office Equipment & Supplies
Prin problem
first check usb port is working or not in computer using any usb device ..... insert another usb device like pen drive and usb mouse ....if its detecting and working fine means no issue .... take a new printer cable and check its detecting or not if its not working its may be issue with the printer usb connector .....if your computer usb not working try fix it ...... if
Dec 12, 2009 | HP LaserJet 2840 Printer
Cannot print from computer. printer will print test pages, though
How the printer is connected to PC Via USB or using Network Cable. If it is connected Netwrok cable than printer configuration page and on netwrok configuration there will be IP Address if this is valid IP Address than reinstall drivers and upgrade the Firmware of the printer.
If Printer is connected USB than try different USB Cable and try different USB Port on the computer
If USB port on the computer is working fine and check in Device Manager if the printer has detected as unknown device or not detected at all.
If detected as unknown device than reinstall printer driver if not detected at all than USB Port on the printer is faulty you need to set up hardware repair of the printer.
Oct 16, 2009 | HP Color LaserJet 3500 Printer
Scan to computer not working
Google, enter "HP Photosmart C5180 All-in-One" and you can reinstall the scanner into computer...free.  Under the black apple in the upper corner of screen find "recent Items" and you will find the Photosmart Studio where the scanner icon is used to scan and create a file in thecomputer.
Mar 26, 2009 | HP Photosmart C5180 All-In-One InkJet...
My Mp610 Printer is not detected?
You need Vista driver from Canon web site
Xp drivers cannot work on Vista.
Feb 22, 2009 | Canon MP610 Photo All-In-One Printer
No usb detected
use a known working usb cable to connect the printer, then switch the printer on, the computer should detect it.
Dec 01, 2008 | HP OfficeJet 6210 All-In-One InkJet...
MFC-8669DN FAILURE
Did you check after installing the printer that you have the printer in 'installed printers' in 'control panel'?
Your printer may have been there, but not set as default printer.
Did you also notice a message popping up first time you connected the printer to usb saying new hardware detected?
Try to install and connect the printer on a different computer ( a laptop will be fine), intalling software first as usual.
If it works is either usb channels on original computer or a windows problem.
If Windows does not see the device when you connect usb (ensure cable is ok) to different computer, and you are sure you are doing everything ok, then it is probably usb printer socket that is faulty.
If Windows see that there is a new device detected, but it cannot install printer, even after doing disk setup procedure fine, then there is an issue either with the printer or with the drivers you are using (they may be for a different operative system for example).
An hardware problem of this kind is rather unfrequent, particularly on a new printer. Check that you are doing everything fine, that the printer is not in installed printer, even if not default one, and that you are using the right setup disk, and that this is performing the whole setup procedure.
Regards
Mar 29, 2008 | Brother MFC-8660DN 5-in-1 Laser...
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
21 people viewed this question
old marine
old marine
