Question about Janome Memory Craft 9000 Computerized Sewing Machine
I have an 8000 series Nuhome Sewing machine and would like to learn how to embroider freestyle without the hoops..Can u please advise me..
3 Suggested Answers
mohammed387
  • 1952 Answers
SOURCE: sewing/embroidery machine janome mc9700 making
Please be more specific with the clicking noise that you are hearing- when does it make that noise, is the bobbin case in or out, where is it coming from,
Posted on Aug 26, 2009
  • 3741 Answers
SOURCE: My Janome 10000 stopped in
Janmore10000 Stopped Embroidering thenstopped everything just shutting off.
If it is getting no power at all, it is probably a fuse. Thefuse is located in a little black box underneath the base of the machine, butit is NOT an easy job to take the box out, disassemble it, replace the fuse,and then reassemble the whole machine. But in your comment you mentioned that there is power tothe machine that means its not fuse problem.
It stopped embroidering in the middle of a project. the handwheel would notmove at all this means that it wasthread jam. Also check the carriage carriage if it does not move to the rightor left and gor stuck in one position or hardly moving a bit then it is out of calibration.
if your machine is outof calibration it will need to recaliberate . Something is like forcing theneedle through a thread jam would cause this. This is not an expensive repair.But a time consuming repair. Its advisable to get it done by service center,
click this linkdirectly to get the support center help
http://janome.com/index.cfm/ContactUs
This will help. Thanks please keep updated. please dorate the solution positively .thank you for using fixya.
Posted on Nov 29, 2009
I have a Viking designer ruby machine. I am trying to embroider a name. I have the right hoop and the design fits the hoop and I keep getting an error message.
Sometimes machines will not work because even though the hoop appears large enough, there is not enough leeway for the presser foot to maneuver inside the hoop. This is a common issue with embroidery machines. The probably answer is to either shrink the design or use a larger hoop.
Nov 13, 2016 | Sewing Machines
Bernina artista hoop not recognized
Calibrate the embroidery hoop
Note
The embroidery hoop can only be calibrated with the oval hoop.. You'll find the instructions for each machine in the relevant user manual.
Aug 15, 2012 | Bernina Artista 180
Can a memory craft 9000 embroidery machine embroider hats?
I have seen some clever ways on you- tube to make unusual shapes fit into the hoop, using clips etc. You can also buy sticky stabliser so the hoop holds the items without it being in the hoop. I'm sure you can also get devices to help you embroider hats, but i'm not sure they will fit the 9000. try an internet search for more information and possible devices
Sep 05, 2010 | Janome Memory Craft 9000 Computerized...
Do I need the embroidery hoop? does it connect to the thing in the back of the machine and moves areouns?
  1. What do I need to get started at free machine embroidery?
    • A zigzag sewing machine with a drop-feed control. (In other words, you have to be able to lower the feed dogs so they don't try to feed the fabric.) It's nice if you can vary the width of your zigzag stitches too.
    • An embroidery foot or needle with embroidery spring. An embroidery foot helps by holding the fabric down against the throat plate while nevertheless being minimal - it lets you see what you're doing because it has very little surface area. You can alternatively get a needle that has a kind of spring built into it, and the spring holds the fabric in place. These can be nice in that they're even more minimal than an embroidery foot, but they're also relatively expensive and if it breaks you have to replace the whole thing instead of using an ordinary cheap needle with the special embroidery foot. If you use the needle with spring, you don't use a presser foot while you embroider.
    • An embroidery hoop. There are two primary kinds of embroidery hoops on the market. The old-fashioned kind, usually made of wood, has an outer ring and an innter ring. You loosen the outer ring, separate the rings, place the fabric over the inner ring, place the outer ring over the fabric, tighten the outer ring, and pull the fabric tight in the hoop. With the modern type hoop, you squeeze a pair of handles on the inner ring to remove it, place the fabric over the outer ring, place the inner ring (still squeezed) into place and release the handles. The more modern hoop is faster and easier. The old-fashioned hoop provides better tension on the fabric.
    • Stabilizer. This helps prevent puckering and slipping while you're embroidering. There are a variety of types out there. Some are papery and are torn away from the embroidery when you're done. Only use that on the back side of the embroidery, as it's almost impossible to get it all off. Others are also papery and also tear away but are dissolvable in cold water, leaving only a few easy-to-remove fibers in the embroidery. Your authors like this type of stabilizer. There is also a transparent plastic-like stabilizer which dissolves completely in water. Your authors have this but haven't tried it yet, but hear it's very nice. It's expensive though.
    • Fabric... of course. Make sure that your embroidery hoop fits on the piece you're going to embroider on. If the piece is to be small, you may want to embroider before cutting the piece from the fabric.
    • Thread. Contrary to popular belief, you can use ordinary polyester all-purpose thread to embroider, but it can weaken the fabric you're embroidering on. (If you do use polyester, you may want to fuse some interfacing to the back of your embroidery when you're done.) There is plenty of gorgeous 100% rayon embroidery thread available.
    • Thread for the bobbin. This won't be seen on the surface, so you can use anything you want. Trying to find a way to get rid of that day-glo orange thread you can't remember why you bought? Stick it in the bobbin when you embroider. Some embroiderers feel that it's best to use a softer thread (like 100% cotton) in the bobbin so as to reduce the possibility that the bobbin thread will break the embroidery thread, but your authors haven't had a problem with this to date.
  2. How do I prepare the machine and fabric for free machine embroidery? Drop the feed dogs and set the stitch length at zero. (If you can't set the stitch length at zero, don't panic, it's not that important.) Install the fabric in the embroidery hoop (with any stabilizer[s] you intend to use) so that the surface of the fabric is at the *bottom* of the hoop. (Note that if you're used to embroidering or cross stich by hand, this means you're putting the fabric in the hoop backwards.) When you place the hoop on the table such that the fabric surface rests on the table, the right side of the fabric should face up. Install the embroidery foot or special embroidery needle with spring on the sewing machine. If you're using the special needle, remove the presser foot. Place the embroidery hoop in the sewing area. (Some machines can't lift the presser foot enough to admit some hoops - you may have to remove the presser foot temporarily, position the hoop, and then re-install the presser foot if you're using one.) Set the sewing machine for a straight stitch. Reduce the upper tension until stitches interlock below the fabric instead of above or inside it.
  3. How do I lock the thread at the beginning and end of my embroidery so it doesn't begin to unravel? Make several stitches in place to lock the thread.
Nov 13, 2009 | Janome Memory Craft 9000 Computerized...
Futura ce-200 "parked" in wrong position.
I think you might have damaged the embroidary arm.
Contact these people for some advice.
Gezina sewing machine
(012) 335 0636
Feb 27, 2009 | Singer CE-200 Quantum Futura Computerized...
Janome mermory craft 8000 drop feed dog
I hate to sound dismissive but: read the manual. Duh. It is not as written above: drop dog........
The feed dog is the toothed pieces in the sewing machine deck, under the needle, which move the material away from you when you push the operating pedal.
Dropping the dog - ie making it inoperative - (see manual for how to on your machine) means the material has to be propelled by hand under the needle. This is especially good for freehand machine embroidery as it means you can move the material in any direction whilst sewing.
It can be easier to freehand embroider if your material is fixed in to an embroidery hoop to hold it flat while you work.
Oct 26, 2008 | Janome Memory Craft 9000 Computerized...
Brother Super Galaxie
Does it pucker when you are embroidering or just sewing in general? If its puckering when your embroidering it could be a few things. 1. no stabilizer 2. the fabric stretched in the hoop too tight. 3. check you tension
Oct 23, 2007 | Brother SE-270D Computerized Sewing...
Singer futura ce-100 embroidery machine
Under the embroidery attachement (on the front side) is a lever to engage or disengage the "feed dog control." When embroidering, you need to move the lever to the level to disengage. The feed dog control should only be at the righe side position, or raised when you are not using the embroidery attatchment.
Jan 31, 2007 | Singer CE-100 Futura Computerized Sewing...
Janome Memory Craft 9000 Computerized Sewing Machine Logo
43 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
